Question about Sewing Machines
Threading the bobbin on a singer tempo 60 machine
  • 155 Answers
SOURCE: Singer 6217C Bobbin Thread bunching
please check out this link
http://sewvacdoctor.com/cate.asp?categoryID=6#1082
goodluck
 thanks.
Posted on Oct 26, 2008
  • 4 Answers
SOURCE: singer quantum sewing machine won't pick up bobbin thread
Try changing your needle
Posted on Dec 13, 2008
SOURCE: Singer Pixie - trouble threading bobbin
look at the bobbin direction. if it dont pick up that way, change the direction
Posted on Jun 26, 2009
Maggie_B
  • 3 Answers
SOURCE: how to thread the bobbin on a singer simple sewing machine
Drop-in bobbin: Note: thread must change direction when entering bobbin shuttle notch. Usually bobbin will turn counter-clockwise when threaded properly.
1. hold bobbin so that the tail of thread is facing to left.
2. drop bobbin into bobbin shuttle.
3. pull thread toward you.
4. guide thread into notch and pull to left so that slot engages thread.
5. pull thread diagonally across shuttle toward back of machine.
6. draw bobbin thread up through needle plate with threaded needle.
Posted on Oct 31, 2009
SOURCE: bobbin singer stylist zig zag model 477
Check this web page
http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Singer_Sewing_Machine_Threading/singer_477_threading_diagram.htm
Posted on Jan 23, 2010
Why is bobbin not catching thread?
It could be that the hook timing is adrift but quite likely that the machine is misthreaded or the needle bent. Get a NEW needle, check your handbook for how to insert it and re-read how to thread your machine. The upper thread could be misthreaded or the bobbin not threaded correctly. The bobbin may look like its threaded OK but if the thread is coming off the bobbin in the wrong direction the machine will never see. Hope this helps.
Jan 21, 2016 | Singer 5400 Sew Mate 60-Stitch Sewing...
Singer 7462 not picking up bobbin thread
it's very possible that the machine could be out of time & needs to
be checked by a sewing machine technican
Jul 29, 2012 | Singer 3820 Mechanical Sewing Machine
14SH654: Singer 247 Machine runs fine and then bottom bobbi...
Try using a style 60 or 66 bobbin. I had the same problem at first, and someone on-line suggested the different bobbin. I use a style 66; instead of having a flat bottom and top (and all those holes), it's shaped something like a bagel. Now my machine works beautifully.
May 16, 2010 | Singer 14SH654
My Brother SE270D keeps jamming up and getting thread all tangled up The feed is not advancing either.
Make sure you are using 60 weight bobbin thread only in the bobbin, also make sure you are using only SA156 ( SFB-XA5539-151) bobbins, the size 156A are not for this machine. I have used Singer size 15J bobbins with no problem. The bobbin should have slightly rounded ends, not flat like a regular bobbin. This helps the thread over the bobbin at high speeds.
I threw my machine out of time the first three times I used it for embroidery and decorative stitches. Had I read the manual, I'd have known to use 60 wt bobbin thread. I have also used 90 wt with no problems...60 wt is what comes with the machine.
If you have to take the machine in for service, make sure to take sample of the problem and the embroidery unit, thread you used, etc. Take it all and tell them to test it all.
My Brother dealer felt these Disney machines were great little workers..and said they are not hard to repair...some dealers don't know enough about how to repair the thread cartridge, so tell you the machine is not worth repairing. It is...I've had mine for 4 years.
Hope this helps some. You may have to take the machine in to be timed / cleaned...once that's done and you are using proper thread and bobbins (upper thread - you can use any, bobbin it's 60wt)...you will love your machine.
Apr 14, 2010 | Brother SE-270D Computerized Sewing...
Singer 5430C bobbins thread always loopy
"Birdnesting" occurs when there is no tension on the needle thread to pull the bobbin thread. This is easily corrected by rethreading the machine, following the threading path carefully and making sure the thread is fully engaged in the tension mechanism.
Feb 15, 2010 | Singer 5050 Mechanical Sewing Machine
Threading bobbin for singer 8734
NEW MACHINE, THE NEEDLE WON'T PICK UP THE THREAD. WHAT WRONG?
Jan 11, 2007 | Singer Drop-In Bobbin 758B-28BH Mechanical...
Sewing Machines Logo
43 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
