Question about Intermatic EI200 Electronic Auto Shutoff Timers
My EI200 is shutting on its own - Intermatic EI200 Electronic Auto Shutoff Timers
  • Intermatic Master
  • 5,089 Answers
Just replaced the circuit board after a technician told me that was the problem. White Rodgers 50A56-956. Getting the same result as the old board: clicks on, shuts off
White Rodgers relay clicks shuts off Surveillance Cameras ...
www.fixya.com > ... > Tags > relay clicks shuts off > Surveillance Cameras
White Rodgers surveillance cameras relay clicks shuts off related questions and answers. Ask your White Rodgers questions. Get free help from surveillance ...
White Rodgers car will start up but shuts off Surveillance ...
www.fixya.com > ... > car will start up but shuts off > Surveillance Cameras
White Rodgers surveillance cameras car will start up but shuts off related ...Thermostat works, clicks when turn on heat, shows Stage 1 on display (hooked up .
relay clicks shuts off Surveillance Cameras Questions ...
www.fixya.com > Forum > Tags > relay clicks shuts off
Surveillance Cameras relay clicks shuts off questions and answers. Ask your relayclicks shuts ... I have a white-Rodgers 1F86-244 thermostat. When I ... a new ...
Jan 16, 2016 | White Rodgers Home Security
Intermatic EI200 Timer doesn't work
Check wiring for single-pole timer:
http://waterheatertimer.org/How-to-wire-timers.html
Check if timer is rated for load... this timer is rated 1/4 Hp and will work with incandescent and CFL and small fan motors... but not rated to operate bathroom heater.
Use Spring-wound timer for heavy-amp loads like bathroom heater and 1-2 Hp motor loads
http://waterheatertimer.org/Countdown-timer-horsepower-ratings.html#digital
Gene
Apr 16, 2014 | Intermatic EI200W Electronic Auto Shutoff...
Fantech FD60EM electronic timer control makes a loud buzzing sound and does not operate the fan
This timer appears to be Leviton LTB60
Timer has 1 year limited warranty, evidently from manufacturer.
If timer is making humming sound, then it is defective, possibly receiving undervoltage on the line, or wiring installed incorrectly.
Switch noisy timer with one of the other timers, and see if problem follows the timer, or is related to the specific location.
Otherwise replace with LTB60 from Amazon for $24.
Or buy Intermatic Ei200 timer, or replace non-electronic with spring-wound timer such as 60-minute Intermatic FD60, or 30-minute FD30, etc.
Nov 18, 2012 | Fantech FD60EM Electronic Timer Control
How do I reset the intermatic EI400 light timer
Copy following link to identify Ei400 series programmable countdown timer and download possible manual:
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#Ei200
Hold down ON/OFF button and fully press-and-release small round reset button using paper clip.
Keep holding ON/OFF button until display changes
This timer uses CR2 battery installed in tray below the buttons.
Reset timer after installing new battery.
If functionality is not restored after new battery install and reset, then timer has gone bad.
This timer has 1 year limited warranty through Intermatic for defects in workmanship.
Ei400 can be wired for single-pole or 3-way.
Timer requires no neutral wire since battery operates the timer and relay circuit
Nov 13, 2012 | Day-Timer Intermatic Ei600c Digital 7 Day...
I have a 3 gang box: a is for hall light switch
Timer is not identified. Battery-operate timers wire differently than timers that require neutral wire.
For 4-wire battery-operated Intermatic EJ500, ST01C, and Ei600, Ei400 wiring:
http://waterheatertimer.org/ST01C-program.html#ST01C
For 4-wire Intermatic Ei200 series, KM-series, Ei500 that require neutral wire
http://waterheatertimer.org/Programmable.html#wire
Add a comment with model number for more specific information
Jun 19, 2011 | RTO Intermatic Digital 7 Day Wall Switch...
Pool pump cannot be turned off with timer switch. Pump runs constantly. I can turn off with breaker switch but not with switch on timer.
You posted under Intermatic EI200 series countdown timer.
Intermatic EI200 series is rated for 1/4 HP.
Check nameplate on motor for HP. Pool pump is probably 1 HP.
Open following link for countdown timer ratings:
http://www.intermatic.com/products/timers/in-wall%20timers/electronic%20auto-off%20timers.aspx
Add a comment and say what kind of timer you are using and say specifically what you want timer to do, and I will locate correct timer for that specific need.
You can also add a contactor to the circuit.
Timer controls contactor, and contactor turns pump on-off.
http://waterheatertimer.org/Water-heater-contactors.html
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Apr 04, 2011 | Intermatic EI220 Electronic Auto Shutoff...
Our Intermatic EI200W is 1 1/2 years old and it has stopped working the way it should. It turns on the fan unit, it runs for 5 seconds and shuts off, it can be re turned on but again it only lasts for 5...
The problem could be the Load and not the timer.
I discovered that if there is a problem on the circuit, that these electronic timers can malfunction.
Buy circuit analyzer from home center, test nearby receptacle that is on same circuit.
If there is a ground fault, for example in your light-fan-motor, you have to track this down with multimeter or some other testing device.
If the circuit is clean, and your electronic device has malfunctioned, then bad news: There are no repairs for in-wall electronic devices.
I test timers: 4-6% arrive defective. Many go bad first year or two. Some last quite a while.
Some programmable timers can be reset and the timer recovers.
Intermatic page below shows countdown timers.
Sample manual shows 1 year limited warranty for your product:
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/ei200%20-%20english.ashx
If I can make a replacement suggestion:
Manual spring-wound countdown timer lasts for 10 years because it has no electronic parts.
I have three of these and they work without a problem even on circuits that have small ground faults.
http://www.electricsupplyonline.com/prod/intermatic-springwound_timers.php
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on timer, or any household problem.
Jan 05, 2011 | Intermatic EI200W Electronic Auto Shutoff...
I cannot shut down or restart my PC using the start menu prompts. The only way to shut her down is a hard shut down (manually turn her off).
There is a program that is failing to shut down in general, which is delaying the computers ability to shut down.
The next time you shut down, make sure you have no programs open. Then, while attempting to shut down, wait until Windows pops up window asking you to close a non-responsive program. When it does, take note of the program that it mentions, then close it and see if Windows shuts down. Note: sometimes this takes a really long time.
Try re-installing the non-responsive program and see if your computer can shut down normally again.
Aug 07, 2009 | Acer Computers & Internet
Replacement Cost
For a pretty simple work it should cost something like 200 dollars. For a more complicated work it can get to around 500-600 dollar.
Aug 27, 2008 | Intermatic EI200 Electronic Auto Shutoff...
Intermatic EI200 Electronic Auto Shutoff Timers Logo
42 people viewed this question
Top Intermatic Hardware & Accessories Experts
Gene Haynes
Jay Finke
Jay Finke
Steve
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
