Sony d34 schematic
Will not play a cd. Either with ac or batteries
PSP NOT WORKING?
If the psp play without the battery when plugged into ac wall unit chances are you need a new battery
http://www.amazon.com/Sony-PSP-Battery-Pack-3-6v-2200mAh/dp/B000FZYY3E
Oct 13, 2013 | Sony PlayStation Portable (PSP) Console
I have the Sony S2 Sports ZS X1 and it will not turn on.
Before confirm transformer fault, load batteries and see whether it works. After loading batteries, pull out its AC cord from its AC socket at it back side. With AC cord connected at the back of the set, battery supply won't connected to the set. There is a cut - off switch at the AC socket. Only after removing the AC cord, the set will work on battery.
Try this. If it works with battery, make sure that transformer or internal mains fuse has blown out.
May 29, 2012 | Sony S2 Sports ZS-X1 Radio/CD Boombox
I get a error code 30:23 on my HDR HC3 and it won't play or
Sony is pretty secretive about the :23 code. It can't be found anywhere. Sony recommends you do the following:
  1. Turn off the camcorder.
  2. Remove the battery or disconnect the AC power adapter for 120 seconds.
  3. Insert the battery or reconnect the AC adapter.
  4. Turn on the camcorder.
  5. If the error message appears, service may be required.
Nov 12, 2009 | Sony Handycam HDR-HC3 HDV Digital...
Do i need a special charger for the NE-720 internal battery
It needs AC-ES3010K2 ac charger to charge battery.
Click HERE and download user manual of Sony D-NE720 for further details.
Feb 08, 2009 | Sony D-NE720 Personal CD Player
Flashing lights
This sounds similar to a problem I had. I brought the camera in under warranty and the repair shop fixed it. They shop text is cryptic.
Problem: Camera light keeps flashing, not charge
Solution: Troubleshoot to intermittent switch block control, replace with new one, test OK.
Feb 17, 2008 | Sony Handycam DCR-HC20 Mini DV Digital...
Sony psp problem
Remove the battery for 15 minutes, connect the AC Adapter and install the battery again.
It that doesn't work, remove the battery again, wait 15 minutes, install it and plug the AC Adapter.
It's a weird problem but in my PSP i get around that way.
Feb 07, 2008 | Sony PlayStation Portable (PSP) Console
Schematic / service information for Black and Decker VP 130 battery charger
Power supply for the VP130 is a 4.32v 210ma AC transformer.
The AC supply is fed to the charger battery box where there are two diodes one for each battery.
each battery is 3.6 volts.
Jan 17, 2008 | Dewalt DW056 18 Volt Cordless Impact...
 Grubhead
Grubhead
