Question about Nespresso Computers & Internet
Nespresso pixie - after descaling , the flow of water does not stop
SOURCE: water leaks from the top of the C190 Espresso Machine
in our case the problem was fixed easily: the metal piece in which the capsule sits is screwed in on the top. When it became loose our machine started to leak water from the top. So the problem was solved by retightening it!
Posted on Feb 02, 2009
  • 109 Answers
SOURCE: Ventilate message
Press the hot water button and allow water to flow from the steam arm until ventilate disappears and warming up appears on the display.
Ventilate after descale is normal.
Posted on Feb 24, 2010
micromatikal
  • 2777 Answers
SOURCE: I need the instructions for
It is fairly complicated, but luckily I found the manual for the device that goes into detail on exactly how to descale it. You want to go to page 8 of the manual. I will provide the manual at the end of my answer here...
Please make sure you rate my answer 4 thumbs up, it is extremely important to me. I would be forever grateful if you could do so. If you need more help on this question please just respond to my answer here and I will get right back to you.
http://www1.nespresso.com/precom/sav/pdf/HD_RO_en.pdf
Thanks
Tim
Posted on Oct 13, 2010
EsWorld
  • 1618 Answers
SOURCE: Water comes out when I remove the center bolt
Hold the shower screen up to the light make sure you can see through all the holes if not, use an open flame to clean screen.
Posted on Sep 23, 2011
espressonist
  • 1711 Answers
SOURCE: I want to know if my Nespresso Pixie D60 has a fuse protection because i plugged my 120 volt 60hz machine into a 220 volt 50 hz power supply without a converter.has my nespresso completely burnt and r
There is not a fuse for protection from this insitent. However the damage on your machine is deoent from how long you left it on with 220v. It can be damage full but it can also not hapent anything. Have you check it again with 120V, since there is a chance that it can still work normal but in any case if not working you may need only a small repair by an eperience percon.
Posted on Sep 23, 2012
The 2 buttons keep flashing & the water won't heat up
You must re press both buttons at once again sow you will remove mashein from descaleing mode
Oct 09, 2016 | Nespresso Coffee Makers & Espresso...
1.My Nespresso Pixie Lights never stop flashing. 2. I also want to reset to factory settings because the cup portions are off. 3. I feel the water temperatures is never hot enough for the coffee
1: Depending on how long you've had your machine, it may need descaling. The machines are preset for hard water - if you're in an area with soft water, try pressing and holding the Lungo button while you turn the machine on. Hold until the lights stop flashing.
2: The Pixie can be reset to factory settings by holding both buttons down before and when you turn the machine on, again until the lights stop flashing - this will reset to factory settings.
3: The temperature is preset to be the optimum temperature for the extraction process. If, after following the above steps, the temp is still too low, call the Nespresso Club and they will advise you.
Hope this is of help to you!
Mar 18, 2015 | Nespresso Coffee Makers & Espresso...
Cleaned nespresso machine and now get white water
These machines are designed to be descaled ONLY with the genuine Nespresso descaling kit. It would be worth trying this. But never vinegar - never!
Feb 15, 2015 | Nespresso Coffee Makers & Espresso...
Why won't my Nespresso Pixie red low water indicator light go on when tank is near empty?
merely out of curiosity is the light or lights bad? If there's a separate red light you'd need to take it out and use an inexpensive voltmeter to see if it's getting a signal.
Either that or look at it closely next to a light. If you see a bad filament then the bulb needs replacing.
Nov 27, 2017 | Nespresso Pixie D60-US-AL-NE Aluminum...
Nespresso pixie c60 cup stuck
Can't make the coffee and can't open the lever of pixie nespresso machine
Feb 10, 2013 | Nespresso C60 Pixie Electric Titan Single...
Nespresso Maestria pump isn't primed
We had the same problem and were ready to return the device when we were able to fix it. Here is what we did:
1. Fill the water tank all of the way and place in machine
2. Let the tank sit in position for a few hours (we let ours sit for 3)
3. Run the descaling option
4. Run a few cycles of the "longo"
5. If the machine is still not working repeat the process (Ours started to run after the 2nd cycle)
It just appears that the pumps are shipping with air in them and needs patience to get it out. Once you get it going though you won't regret it :)
Dec 20, 2012 | Nespresso Maestria Rosso
Nespresso citiz won['t exit descaling mode
I had the same issue, and took it to the repair shop, where the guy did the same thing, just pressed both cup buttons for 3 seconds. It worked. He said the Lungo button had to be pressed a little harder, as it had some connection problem, and thats why it didnt work for me. If you have the same problem, the machine will start buzzing for about half a sec if you press the lungo button while in descaling mode.
Nov 29, 2012 | Nespresso Citiz C110
Very slow water flow, barely filling tea cup
It could be a problem with an air bubble or with scale deposits.
It is recommended that you first run a descaling cycle using the proper descaling product. Do not use vinegar as it can damage your machine. Information on descaling can be found here:
http://www.nespresso.com/fileadmin/shared/_img/manuals/Nes_DescalingKit_CBU_internet_081216.pdf
To find more help with your product go to the website below:
http://www.nespresso.com/#/no/en/coffee_machines/selecteur_gamme/machines-le-cube/le-cube-nespresso-auto-d180---110-v-1
Feb 28, 2011 | Nespresso Le Cube
Krups Nespresso FNA2 coffe/cappucino machine
First thing to try is a descale. Run the machine normally using it (as if making a cup of both types) a couple of times with a 50/50 mix of white vinegar and water. Leave the machine off but uncleaned overnight. run a couple of cycles with just water, and if there is still a slight vinegar taste then run a cycle with a teaspoon of baking soda in water, then flush with just water again. If this doesn't solve the problem, try again with 75% vinegar. If still not working, there is either a control board problem (may be solveable), or the valve/solenoid that stops/allows the water is sticking, almost certainly solveable by taking that apart and cleaning/lubricating. Definitely solveable by replacement. Let me know what you get after a descale if no luck. Hope this helps :)
Aug 20, 2007 | Nespresso C190 Espresso Machine
Computers & Internet Logo
296 people viewed this question
Top Nespresso Computers & Internet Experts
David Payne
David Payne
Are you a Nespresso Computer and Internet Expert? Answer questions, earn points and help others
