Question about Pool & Spa
Lay z spa vegas
I have just got my lay z spa back out again after packing away for a couple of months this winter. It worked initially but the plug seemed to get very hot to touch. We were in the middle of heating up the water and had an EO5 error come up on the panel. Is this a catastrophe and have we no choice but to take advice from Bestway or has anyone any experience of this or advice for us on how to fix the problem.
22yooper
  • 828 Answers
SOURCE: Kenmore side by side model 106.55512400 inside frame hot to touch
There is an electric heater in the center which is called a mullion heater. If you have an energy saver switch on your model turn it to the saving position.
Posted on Jul 17, 2008
  • 3 Answers
SOURCE: Panel reads "water sensor opened"
I had the same problem. The water sensor is on a pipe running into your pump. It will have a circular clamp around it. Remove the clamp and pull the sensor out of the pipe. The wires should run into your control box. disconnect the wires and replace. My water sensor was part 7790. Not sure if you have the same one. Do an online search. bestbuypoolsupply.com has them for $50 plus 9 for shippng. Hope this helps.
Posted on Mar 12, 2009
SOURCE: Heater will only heat spa water to luke warm.
the water in my arctic spa hot tub took 2 weeks to get to 102 should it take that long ?
Posted on May 02, 2009
  • 5 Answers
SOURCE: Pential Easy Touch Pool/Spa remote says the water
you can change the calibration on the temp. or how did you check the sensor
Posted on Oct 05, 2009
  • 366 Answers
SOURCE: our artic spa hot-tub is showing HL in the panel
HL is normally a "high limit" fault. If your filter is clean and you have sufficient flow, you may have a faulty high limit sensor. It should be mounted on the heater itself. The high limit sensor shuts the heater off if it senses excessively hot water. Check to see that you have sufficient flow, clean the filter, and make sure the filter pump is running. If everything else is running properly, you may have to replace the high limit sensor.
Posted on Dec 28, 2009
Where can I buy a replacement thermometer for my lay z spa Vegas pump 2012? Error E04 showing on pump.
Check pool supply centers or go online to the manufacturers web site.
Jun 19, 2015 | Pool & Spa
How do you deflate a portable spa
To deflate the portable Therapure spa 050006 is easy. The trick is to realize that the black valve used to inflate is in fact a double valve. Remove the square threaded cap to inflate it.
1. To deflate the spa leave the black square threaded cap and below that you should find a round or winged coupler.
2. Unscrew this coupler off and immediately the air will start to escape. It shouldn't take more than about 2 minutes to deflate and you are ready to pack it away.
3. Return the valve (before doing so you could use a vacuum to suck out as much air as possible.)
4. Lay out the spa floor in a circle
5. Fold the three sides to the centre
6. Then lay the power unit on the folded sides.
7. Remove the coupler one more time to squeeze out any remaining air and then return it.
8. Roll the up the side to the original size of the spa before you opened it the first time.
Nov 23, 2013 | Therapure Pool & Spa
Lay z spa pump impeller replacement
Perhaps an inquiry of Lay Z Spa will yield an answer
Jun 01, 2013 | Home
Winter closing instructions
Winterizing your Spa or extended period shutdown If you don't have plans to use your spa during the winter months, you should drain it completely well before the temperatures get low enough to produce a hard freeze.
Hot tubs that are heavily used by bathers should be drained every 3 - 4 months. When it's time to drain, either drain to a sanitary sewer or use the water for lawn irrigation. Make sure no chemicals have been added for at least 48 hours before draining.
Water in spas filled with sprayed foam insulation will still freeze if not heated. Finding and fixing leaks in that foam is a nightmare! These recommendations could potentially save you a lot of money!
These basic steps will ensure safe, effective shutdown of your spa for the winter months or any other extended period with out use. Factors such as spa installation, location, type will affect the steps and procedures.
Use these recommendations as a guide.
  • Disconnect the spa from the power supply.
  • Open the drain valve (if installed) or pump out all water.
  • Remove the filter cartridge(s). Clean & store in a dry place. (FILTER FLOSSER)
  • If possible attach a wet/dry (shop) vacuum (capable of blowing air as well as vacuuming) to the hole in the bottom of the filter housing.
  • Using the blower function, blow out any excess water through the plumbing system - allow a good 5 minutes of blowing time.
  • Use the shop vac to remove any water blown through the jets into the tub or towel dry any remaining water from the spa, until it is completely dry.
  • Leave drain & gate valves open, if you have rodent issues we recommend MOUSE AWAY.
  • Close the spa cover and fasten with tie down safety locks.
This is not a job you want to do in freezing conditions, give yourself enough time. Make every effort to ensure ALL of the water is removed - including remnants in the pump lines and jets.
These are common sense steps always be safe around water and electricity.
Sep 20, 2012 | Pool & Spa
Leaking lay z spa pump
Firstly try some Fix-a-leak spa leak repair.
If the suspected leak is less than 1/8" that should fix it.
Or remove the paneling to find where it is coming from, there is no easy solution.
Jul 25, 2012 | Pool & Spa
Bestway Lay Z Spa pump not working!
check recirculation pump and heater element
Oct 23, 2017 | Pool & Spa
Sony Vegas 8.0 Freezes when "Initializing Audio Engine"
Have you upgraded you Sound Drivers? Tried reinstalling Vegas? or Looked to see if a Patch or Update is available for Vegas?
Apr 04, 2009 | Sony Vegas Movie Studio Platinum 8
Pool & Spa Logo
49 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
