Question about GE Hotpoint RGA724PKWH / RGA724EKWH Kitchen Range
My stove won't shut off rga724ek1wh - GE Hotpoint RGA724PKWH / RGA724EKWH Kitchen Range
Stove won't turn off
defective switch most likely
Dec 12, 2012 | Stoves 600SiDOm Gas Kitchen Range
My maytag freestanding stove won't turn on. The clock works but the stove or oven won't turn on.
Need more in fo-gas or electric: If electric,I have seen problem in electrical box over time the screws where wires are connected over heat and get loose or break check both ends and disconnected electrical cord before doing this.Check all wires.
Sep 15, 2012 | Maytag Stove / Oven / Range Cooktop -...
Maytag accellis 2x stove won't heat-up, does power-up, light comes on but no heat
Buy a new stove element. If you open the stove look in the back. It should be black. It might have a crack or be clearly broken. This is a cheap fix. If you want to be sure that it is working at the connection unplug the element and pull it out. Put a volt meter into the prongs. Turn stove on and see if its putting out voltage.
Jun 02, 2012 | Maytag Stove / Oven / Range Cooktop -...
Ignitors won t shut off
Hi jddmd,
The ignition switches probably got wet.
Please follow my below Tip on how to fix it:
GAS STOVE CLICKING PROBLEM...
Kind Regards
JEDEMEYER1
* If this solution helped you, please accept it
Sep 20, 2011 | Bosch Cooktops
Stove reads F3 and won't cancel and oven won't shut off?
Hello & Welcome to FixYa
F3 error code indicates a open/shorted oven temperature sensor and to solve this problem the sensor needs replacement. If you wan to be sure before replacing the sensor then you can test it with a voltmeter for around 1100ohms....if it reads more then this then it needs replacement however, if the reading is around or less then 1100ohms then it is the control board that needs replacement. Please get back to me if you have any other questions.
Kevin
Jun 15, 2011 | Frigidaire Ovens
What are the install recommendations for the franklin stove model 98?
Best recommendation is - don't install it. This stove was manufactured originally by Martin Industries. They were a very good company. I did business with them for 10 years. However, they have been out of business for 5 years, now. In addition, that old a stove does not meet the current EPA, NFPA or Home Owners Insurance standards. It's efficiency rating is less than 60%. Although the stove may look new, in the end, it won't be what you expected. It was good in it's time, but now, depending on where you live, it can't be legally installed
One other word of caution. If you do decide to proceed with the installation, check with your Home Owners Insurance carrier, to see if they will cover a loss, as a result of a wood stove. Many won't.
Apr 20, 2011 | Heating & Cooling
GE Hotpoint RGA724PKWH / RGA724EKWH Kitchen Range Logo
22 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
 Fix Your Board
Fix Your Board
Are you a Kitchen Range Expert? Answer questions, earn points and help others
