Question about KitchenAid Toaster Ovens
Oven has power light on, but won't heat on any switch position
What can I do as my oven stopped working yesterday whilst heating up .Both hotplates work. No lights coming on oven switch. No fan working. Help please
If the oven is not working, the fan is not working, and the light is not working, it suggests that the oven switch is faulty as that is the only common part for all 3 things. It might be a broken wire or a faulty switch. You will need to dismantle the oven to gain access to the switch and then use a multimeter to test it. if you do not know how to do this, then get an electrician or oven repair company to help, as there are dangerous voltages inside an oven than can give you a shock or kill you.
May 23, 2016 | Russell Hobbs 13824-10 Mini Kitchen with...
Oven works but is not heating up what can I do or check for to restore heat
Check for correct power at the heating elements, if its there, the elements are burned or shorted.
Mar 07, 2015 | Lincoln 1301/1346 50" Electric Impinger...
Not heating, but light works? How do I fix this problem?
Your oven is obviously getting power if the light is on. If your heating elements are not getting hot you may have had a switch go bad, a wire come off it's terminal, or possibly a fuse that blew if your unit has one. There is really no way to know exactly where the problem is without taking the unit apart and visually inspecting it. If all the connections and switches look good, some electrical diagnosing is needed to see where the problem is. If you find any wires or switches that have any melted or burned plastic, you will need to repair the connection or replace the switch. If there is no obvious problem, you should have it looked at by a technician who can properly diagnose the unit.
Apr 21, 2014 | Euro-Pro TO160L 1380 Watts Toaster Oven...
Power light out and doesn't heat
Ticking sound when unplugged? It sounds like a mechanical timer. Check the timer / control setting is actually on a cooking cycle. The unit may be set on delayed start? If there is no power to the unit, there may be a fuse inside it. You may have to take the back / side off to see.
Nov 08, 2013 | Hamilton Beach 31199xr Countertop...
Unit power on light is illuminated but no heat from heating element,
The thermostat may have failed. It could be adjustable mechanically but not electrically.
Nov 06, 2013 | Anvil SAA8003 Stainless Steel 3000 Watts...
Delonghi xr640 toasting-finished chime not working
follow this steps and fix it. God bless you
f the oven doesn't work at all, make sure the circuit breaker or fuse is on at the electrical service panel and test the electrical cord . If the oven doesn't work on its toaster and oven functions, test the main switch . As needed, check the fuse .
If the toaster function doesn't turn off unless the door is open, test the solenoid, the switch and if necessary, the thermostast.
Location of the typical toaster oven's thermal fuse.
If the toaster oven stays on when the door is opened, check the main switch . If the oven doesn't heat, test the heating elements.
Oct 27, 2013 | DeLonghi XR640 Retro 1500 Watts Toaster...
My toaster oven has no power
This can be due to three reasons:
1. It can be fault in the wire to the oven, if the plug is faulty or the wire has opened out.
2. Secondly if the switch to activate the heating coil is bad it will not connect the power to the coil
3. Finally if the coil is OPEN , then it can be checked using a multimeter as also the wire connection to the heating coil.
Aug 25, 2011 | Black & Decker CTO649 Toaster Oven with...
The blue light does not go on and the heating element does not wo
The problem is most likely the timer switch. They are very poorly made and tend to overheat causing eventual failure. B&D will be of no help and you will not be able to find the original switch. There is a switch made for Delonghi ovens that will work if you need a timer. The part # is 5218104600 and can be purchased for $10.98 at the Gourmet Depot website. This switch has a toast timer only if you turn it clockwise and turn counterCW for oven ON. Timer is only about 13 minutes. There is another switch that has a 120 minute timer. It looks the same and the part # is Delonghi 5218101800. May be harder to find. Another solution and a much cheaper one is to replace the broken switch with a single pole single throw toggle switch rated for 20 amp's at 120 volts. You will need to turn the oven on and off manually and you will no longer have a timer but at least you will be able to use your oven!
Apr 23, 2010 | Black & Decker CTO649 Toaster Oven with...
Toastmaster Toaster Oven 357 is not heating when door is closed?
Mine just broke too - it won't heat - everything else works - lights, timer ect. but no heat can't cook
without it - love my oven - any solutions ( I guess it's the heating element ) Hope I can get a new one.
Aug 29, 2009 | Toastmaster 357S Cool Wall 1400 Watts...
Timer switch on Dualit 89100 1500 Watts Toaster Oven does not work so oven cannot be used. Any advice?If you turn timer all the way to 120 minutes and hold it the light in the oven will go on but no heat.
The timer switch is likely bad. Small convection ovens are notorious for this problem and switches may be difficult to find. Try smallapplianceparts.com or search "small appliance parts" for a few places that sell parts. You will need the make and model # of your oven.
Feb 22, 2009 | Dualit 89100 1500 Watts Toaster Oven with...
Toaster Ovens Logo
133 people viewed this question
Top KitchenAid Toaster Ovens Experts
Think Crucial
Think Crucial
Tom Chichester
Are you a KitchenAid Toaster Oven Expert? Answer questions, earn points and help others
