Question about Kyocera Mita Office Equipment & Supplies
My printer (Kyocera EcoPro EP 3700N) is printing blank pages or only prints on the left side of the page. the right side is blank? what do i need to do to fix it?
Is it the ink cartridge? I print a high volume amount of paper on a daily basis. could that some how be apart of the issue?
mediatecar
  • 60 Answers
SOURCE: My printing displays wrong ink levels and prints blank pages
If your cartridge is new (or full) and you know that not just from ink levels display, then you did not used the printer for a while (at least a month) and the nozzles of the cartridge are clogged. If u used the cartridghe 4 or 5 moths ago, then the whole cartridge is dryed out, so get out and get yourself a new cartridge.
If it's just a month, then you should put a paper-tissue on a small plate (like a coffee-cup plate), then put some boiling water on it, just 2~3mm of water over the tissue.
Put the cartridge with the nozzles part downside on the tissue, in the hot water.
Let it stay there in the water 30 min.
Put the cartridge in an other clean tissue, than shake it strongy as if you want to force ink to get out trough the nozzles. Then clean gentle the nozzle part of the cartridge on some sheets of tissue.
Install the cartridges it in the printer and run a few cleaning processes from the printers maintenance software.
If the cartridge is new and just installed in the printer, and you have the inklevels but it does not print, then get it out of the printer and back to the store, they should replace it for you. I hope you removed the protective plastic stripe that covers the nozzles before installing the cartridge?...
OK, let ne know please how things evolve.
Hope it helped you, rate the solution.
Almoust forgot: ink levels are displayed by Lexmark inkprinters by estimating the ink consumed trough you printing process, it has no sensors in the cartridge. It's just kind of a counter, you can evan set an empty cartridge to be seen as a full one.
Posted on Feb 15, 2008
SOURCE: printing blank pages
I am working on the same problem. While you will not like the
answer here it is for the canon mf6530. What is causing it
is the shutter over the laser is failing to open. There for
it blocks all exposer. A temperary fix is to carefully lift the
shutter and tape it open using black electrical tape. Then
try a few prints you should have an image if this is your
issue as it is mine. I do not recommending running it in
this condition very long. When I find the final answer I
will attempt to post it.
Posted on Sep 09, 2008
jilpeshpatel
  • 259 Answers
SOURCE: HP J4580 Printing blank pages
fist click the start menu
and click the printer and fax
and select the hp printer and rith cilck the proparties and seat the print colar coular that time
select only black...............ok
Posted on Apr 08, 2009
  • 55 Answers
SOURCE: Hp 2820 prints only on right side of page
Yes, you will need to replace the drum unit as well. be sure to shop around so you can get the best price because some people mark up the price for that part. You can check the status of your supplies from the printer itself by pushing the "menu" button the printer and scrolling through until you see something about supplies status then press the check mark button.
Posted on Jul 31, 2009
  • 7 Answers
SOURCE: My CLP-350 Samsung printer only prints black ink
Here is my solution, hope it will solve your problem.
From your post, I believe your CLP-350N printer has enough black toner. The black cartridge is on the far right side of the printer, so the black toner is harder to go to left side of the roller than right side. Everytime we start the printer, it will move some toner of each color to the roller before it shows ready to print.
Because we always use B&W printing when we start the printer, but less Color printing. The result is there are always enough toner on the 3 color rollers, but the black toner is lean on the black roller. When this gets worse, the left side of the black roller may hardly get any toner at all -- so it only print black on the right side fo paper.
Step by step solution
(CAUTION: Never loss balance while tilting printer! You may drop and damage your printer! Hold the printer firmly all the time! Ask someone to help you if needed!)
Here, front of the printer is where you can access the cartridge, back of the printer is where you connect the power cord and USB cable, left is your left, right is your right.
1.Lift the front to keep the printer tilt to its back at about 45 degree
2.Power on printer while it's tilted back, wait untill green light is on
3.Open the front door, red light will be on, then close the door, printer will start up again,wait untill green light is on
4.Repeat step 3 once again, then put the printer back to level position
5.Lift the right to keep the printer tilt to its left at about 45 degree
6.Open the front door, red light will be on, then close the door, printer will start up again, wait untill green light is on
7.Repeat step 6 once again, then put the printer back to level position
8.Print some test page to see if there is any improvement of black print quality.(Hold the printer button for 3-5 seconds, it will print the test page.)
You may try several times and print several pages each time before you finally cure the problem.
Good luck! And do it safely!
Posted on Feb 10, 2010
Printing only left side of a page, right side totally blank
What application are you using to print text? Word?
Try a simple application, like Notepad or Wordpad, to print some simple two-liner text.
Does printer print ALL the text on left side or just the half of printable material?
Even if you are indicating that page size is correct, looks to me some problem with the selection of print area.
Oct 03, 2015 | Dell 926 All-In-One InkJet Printer
When I send my job to the printer. The printer will print but only on 1/2 of the page. it looks like the printer think i want two sheets on one page
Is the whole page you want printed on half the page is just half the data printed? If the whole page is printed on half the paper then the problem is software. If the page only prints the left side or the right side blank on the other side then the problem is most likely the fuser assembly. Can you take a picture of the page and email it to us, we will email you back with what needs to be done next.
Tech@ccl-la.com
Apr 30, 2010 | HP LaserJet 2300 Printer
Kyocera Mite KM-1510 printing on half pages instead of full pages
It sounds as if the paper size at the machine is set incorrectly. Try checking to ensure you cassette or bypass if that is where you are printing from is set correctly.
Feb 16, 2010 | Kyocera Mita KM 1510 Laser Printer
-Laser Printer printing NEAR blank pages\
if this is an fs3900 tray rerunning the developer thru the machine.
Do this by going into the menus..up and down untill you see others..than right arrow..now up and down untill you see service...right arrow..than up and down untill you see developer..once you see developer hit enter twice...power off than back on machine..it will than recoat the mag roller with toner...good luck
Jan 30, 2010 | Kyocera Mita KYOCERA/MITA - FS-3900DN Mono...
Only prints on one side
Hi, You have to remove the Catdriges from the printer and clean both catdriges and the roller. This might sort your problem. Secondly before printing check the pagesetup of the particular file.
Mar 09, 2009 | HP PhotoSmart 7150 InkJet Printer
Kyocera FS 1010 is printing blank pages
You may need an imaging unit. VERY expensive.
Sep 12, 2008 | Kyocera FS-4000DN Laser Printer
Left side of page prints blank
Hi there in the paper handling menu check the paper size settings as it maybe as simple as the incorrect paper size has been set in the machine
Hope this works for you
Thanks J
Dec 12, 2007 | HP LaserJet 2820 Printer
16 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Henry Gertcher
AAAA262430
Level 1 Expert
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
