Question about Sharp R-1610 Microwave Oven
Door latch will not latch closed seems like a spring is broken or out of place that would put tension on latch hooks
MicrowaveSvc
  • 9047 Answers
SOURCE: Sharp Carousel Microwave door latch stopped working door won't stay closed
Normally the problem is not the spring, but a broken spring mounting tab on the door latch head (hook) assembly or the inner door panel.
If it's the door panel, it's usually easier and cheaper to use epoxy and some kind of hardware to fashion a new spring mount.
The door latch head (hook) is easy to replace or repair if that's the issue.
We have *critical* safety & disassembly info at our site, linked here: http://tinyurl.com/yzjozk
We also have this full service manual at our site: http://www.microwavedisplay.com/R1480_R1481_R1482_sm.pdf
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Apr 18, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: door latch on sharp 1480 microwave over the range oven
We have the service manual for this model and have uploaded it to our site here to help you. You will need the free Adobe Reader to view or print it.
Normally you have to separate the door panels (as shown in the manual) and then you'll see the screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
The best place to order Sharp parts is Tritronics.
Posted on Aug 09, 2008
MicrowaveSvc
  • 9047 Answers
You will need the free Acrobat Reader to view or print it.
Posted on Sep 16, 2008
  • 6 Answers
SOURCE: Door won't latch/microwave won't turn on
The door does come apart. Open the door and where the hinges are, there are openings where the hinges enter the door, this plastic piece (goes all the way around the door) With a small flat blade screws driver VERY carefully pry it (plastic) off, once off, check the latch end for the spring, typical failure for a Sharp is the little tab that the spring hooks to on the door, the only way to repair this so it will last is to replace the door frame. they are not too expensive, about $50 or so Part# FCOVB166KIT
is the door frame assy
Posted on Jan 07, 2009
SOURCE: spring for the door latch is broken
As a follow up to MicrowaveSvc: first thanks for the insight. Second I found the spring mount entirely broken off from the door. I did find an anchor point molded in the door near the bottom. I tied a length of waxed whipping twine between the anchor point and the spring and adjusted the length to make the spring firm. I have a picture if you can tell me where to send it. David Smith
Posted on Sep 08, 2009
Door does not stay closed
If you gently push up on the door latch heads (hook-like devices sticking out of the door) there should be spring tension. If they just flop right up, the spring is off inside.
The service manual for the R-408LS (the model you posted it under) is here.
You can order parts from the Sears Parts Direct Web site.
Oct 26, 2013 | Sharp R408LS Stainless Steel 1100 Watts...
Sharp R-308J microwave door will not latch
If you gently push up on the door latch head assembly (hook-like devices sticking out of the door) there should be spring tension. If they just flop right up, the spring is off inside.
We have critical safety & disassembly info at our site, linked here.
The best place to order parts for this brand is Encompass (formerly Tritronics).
Or you can call them toll-free at 866-779-5835.
Jan 11, 2009 | Microwave Ovens
Sharp R1480 - door won't close
Very much so.
If you gently push up on the door latches (hook-like devices on the door) there should be spring tension. If they just flop right up, the spring is off inside.
You will need the
free Acrobat Reader to view or print it in case you don't have it.
The best place to order Sharp parts is Tritronics. Or you can call them at 866-779-5835.
Dec 14, 2008 | Sharp R-1480 Microwave Oven
Sharp R1480 door won't close
Very much so.
You will need the
Door won't remain closed and therefore won't operate. ? Problem with door locking mechanism
If you gently push up on the door latches (hook-like devices on the door) there should be spring tension. If they just flop right up, the spring is off.
The best place to order parts is Tritronics. You can also call them at 866-779-5835
Nov 21, 2008 | Panasonic Microwave Ovens
Door does not latch when closing on Sharp Carousel model R1480 Ser.# 221885 Microwave oven
If you gently push up on the door latches (hook-like devices on the door) there should be spring tension. If they just flop right up, the internal spring is off.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here but the best place to order Sharp parts is Tritronics.
Nov 05, 2008 | Microwave Ovens
Door latch on sharp 1480 microwave over the range oven
Sep 13, 2008 | Sharp R-1460 Microwave Oven
Aug 08, 2008 | Sharp R-1480 Microwave Oven
Panasonic inverter door won't shut, light stays on.
Thanks for the tips - here is what I did (my wife calls me the Canadian McGuyver!) After taking off the plastic frame (using instructions in Solutions noted above) I used the metal part of a key ring and hooked one end to the spring and looped it around the thick finger/protrusion at the bottom. _197.jpg
Jan 28, 2008 | Microwave Ovens
Door latches to microwave broken
I assume you're talking about the spring that keeps tension on the door hooks (latch heads, as they're called by Sharp). When you shut the door, the "hooks" are held down by this spring to actuate the door switches. To fix this, you'll have to separate the door panels. You can download the service manual from my Web site. There's a loop built into the latch head assembly and sometimes the loop breaks. If so, you can drill a tiny hold in it and reattach the spring there. There may also be a loop on the innner door panel to hold the spring. That one can break, too. If it's broken, you'll have to find a way to secure the spring to the panel. If the panel material is thick enough, a tiny screw eye could be inserted, then epoxied overnight to secure it. I've attached a diagram to this message that should help you. If that doesn't help you, I have the service manual for the R1600-series microwaves on my Web site at: http://www.microwavedisplay.com/R1610.pdf Repost if you need more help.
Nov 15, 2006 | Sharp R-1610 Microwave Oven
Sharp R-1610 Microwave Oven Logo
43 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Ed Mac
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
