GoldStar Window AC - Not Kicking Cooler On
Purchased the unit in may or june.. Had no problems with it til recently.. came home from work about a week ago, the fan works and constantly is on no matter the degrees 60 - 86 always the same cool.. but it wont kick on the compressor.. so is it a freon thing, a thermostat problem, or something else... please let me know wat you think.
  • 86 Answers
Check selector switch n cirkit board
Posted on Mar 17, 2008
LG LW2416HR window AC / heat unit problem. Compressor will not shut off or cycle. It runs all of the time. Please see below for details.
Has to be a stuck relay or contactor. I'm sure it's a relay on a circuit board so likely the whole board will need replaced. Never opened one up and don't see a wire diagram. But, if you need heating, unhook the compressor. Obviously wrap any bare wires, obviously cooling works but will have to turn off breaker to shut down. Temporary fixes obviously but will get you by. Best wishes!
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Aug 15, 2017 | LG Heating & Cooling
My frigidaire a/c is set 73fhrenheit after running for a time the temp. on the unite drops to 60 degrees by it self what is the problem ?
AC units, no matter if they are big/small, window or big central units. They will only cool the air in the room, or home, to about 15 degrees cooler than the outside air temperature. If you live in Georgia and it is 100?F+ outside, you will be lucky if the unit will reach 80?F even running all day.
Jul 22, 2012 | Frigidaire FRA186MT2 Window Air...
My goldstar 6000 btu window ac is dripping into the house
Sounds like you're using it when the outside temp is cooler than the inside temp. when this happens, frost will build up on the condensor. Turn the unit off until the ice melts off with a shim under the unit tilting it back towards the outside of the window to drain. If it continues to drip after melting all the ice off and letting it dry out, you have a small leak in the condensor, (unit must be old or worn out) that the freon pressure has leaked out causing it to condensate more. A good checklist would be to check the level of the unit, make sure the coils are clean and not bent, the age of the unit and for small areas of corrosion or white marks on the condensor before replacing it.
Aug 28, 2011 | Goldstar KG6000R Window Air Conditioner
Where is the drain hole on goldstar window ac my ac keeps dripping water inside the house
Hello, make sure the unit is tilted toward the outside a bit, if it is level the condensate will collect in the front and start dripping inside the house. Also, if the unit has a drain make sure it is clean so the water can drain out properly.
Jun 07, 2011 | Goldstar KG6000R Window Air Conditioner
Goldstar 6000 AC
Be sure the condenser coil is clean. I use a foaming type cleaner.
Jul 26, 2010 | Goldstar KG6000R Window Air Conditioner
Sony KV-36FS120 No Pic/No Sound 4 blinks
You need to have the flyback on the main board replaced (a very comen problem)
This should fix ya!
Dec 12, 2008 | Sony FD Trinitron WEGA KV-36HS420 36" TV
Goldstar Window A/C Unit Model GWHD5000
I recommend that if you have animal and you want to have the unit on all day that is fine if you have an ac unit with a thermostat and it is big enough to handle.  The unit that is in the window is ok if your home but it could cost alot if there is no thermostat because it will run and run and run.  Then if it don't cool the house enough means its not the right size.  The unit / compressor could overload and kick on and off and might not work when you get home and the house will be like a firecracker.   Best bet would be to replace it with a unit for the size needed for the apartment.  It would be effecient. if we can help further just let us know.
Jul 15, 2008 | LG Goldstar GWHD5000 wall/window Air...
Buttons
F1, F2, and F3 are the strength of the fan blowing the air conditioner. F1 circulates the least amount of air, F3 the most. I generally find that if the air conditioner isn't getting the job done on F1, F2 will do it. I typically only use F3 if I just want to circulate air fast in my place for awhile. As far as what is "better" with closed vent or open, that depends on what you want to do. If you are using air conditioning on a hot day, then vent closed is better because it will cool only air circulating in your place. Vent open will allow fresh air in from outside, and if it's a really hot day, the air conditioner might have a harder time cooling off the fresh air than the circulating air inside your place (as it's continually being cooled repeatedly by your air conditioner).
Jun 10, 2008 | Goldstar M1003R Air Conditioner
Heating & Cooling Logo
184 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Marvin
Marvin
john h
