Question about Toshiba Computers & Internet
REFUSE TO BOOT, BLACK SCREEN !!!
I have done this procedure before with no problem. Following factory instructions I attempted to reset my, nearly new, laptop to factory settings. When the procedure was completed and re-booted I got a black screen which says " Checking media" then "[Fail]". Less than 30 seconds later "No bootable device-Please restart system" I have tried by changing the Bios to USB, DVD, HDD, and using various types of media. Nothing will boot this laptop. I have even tried to boot with a installation disk with negative results. What can I do? This laptop is a Canadian Toshiba C850 Satellite with windows 8. I am a Disabled Veteran and I do not have much money, can you please advise me on what I can do ?
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 140 Answers
Laptops with reset buttons or features usually have a partition where boot files and the operating system are located. If these are corrupted, the system cannot find them anymore, thus the "No bootable device" message. I suspect your hard disk itself is defective or damaged due to the "Checking media" message. I suggest you check the laptop's hard drive first for defects. One easy way is using a "live" linux OS such as Puppy Linux ( Puppy Linux Community Home Getting Started ). You may need to ask a friend to download a free and legal copy of this and burn it to a cd or dvd disc. A live version do not install to the hard drive, only to the laptop's memory so it doesn't matter if your hard disk is dead or not.
Posted on Mar 30, 2017
SOURCE: cannot boot from cd rom drive/ dell inspiron 1150
try to installed dell print
Posted on Mar 25, 2009
rcirone203
  • 70 Answers
SOURCE: Black Screen after bios Load
There is nothing positive about this. You can try to load windows in "safe-mode" by holding the f8 key when you start windows. Then you can try to do a system "restore" to a date BEFORE this happened. If that doesn't work you will need to load a new operating system on your laptop. Good Luck
Posted on Aug 04, 2009
bronk50
  • 27725 Answers
SOURCE: Laptop powers on fine ,
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test the leads that attach to your ((hard drive from the motherboard)) or replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your ((motherboard to hard drive))
or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
Posted on Jan 13, 2011
SOURCE: I have an Acer TravelMate 4500 512Mb Ram an 80GB
1. Remove or Unplug any recently added hardware.
2. Remove and replace the battery.
3. Press and hold the power button for 7-10 secs to power ON the computer.
4. Try booting to windows Operating System in Safe Mode. (Press F8 key as soon as you restart).
5. Check if the Hard Disk is detected and listed with its capacity of 80GB in BIOS. (Press F2 as soon as you restart).
6. Reset BIOS to default values.
7. If computer boots to windows in Safe Mode, then perform a system restore to an earlier date.
8. Install any updates available for BIOS.
9. If Hard disk is listed in BIOS, perform system recovery using the recovery partition or the recovery discs.
10. If Hard disk is not listed in BIOS, contact any nearest service center to get the computer serviced.
Posted on Jul 23, 2011
jcrowder0846
  • 470 Answers
SOURCE: How to Replace Bios? Boot & Reformat Attempts Hang (on every HDD) - I guess BIOS is Corrupted
You can go to the manufacturer web site and go to support then to drivers and downloads there should be a BIOS flash software utility at their site. Click Here to go there. Select your model and make sure it is the correct one. I would also go for the automatic driver update, this will find and seek any drivers for your laptop that are needed, missing, or upgrade them.
If that does not provide the info you need their is also a support number as well as live chat at the link above. I hope this assisted you in some way. John
Posted on May 02, 2012
HOW CAN I RESET A RCA 55 SMART TV MODEL SLD55A55RQ, WITH A BLACK SCREEN
There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Oct 07, 2015 | RCA Class 1080p 120Hz Smart Back Lit LED...
My screen is locked so I did a factory reset and now it is frozen, what do I do?
iF THEDEVICE HAS FROZEN AFTER A RESET IT MUST HAVE HAD A FAULT BEFORE YOU ATTEMPTED THE PROCEDURE.
aT THIS POINT YOU SHOULD REFER TO THE MANUFACTURER FOR SUPPORT IN THIS MATTER. The reset procedure is there for the end user to correct minor faults at a low level, it corrects such faults where there is no hardware fault or where the software has no fundamental installation issues. If the hard reset has not corrected the issue one or both of these issues must be present.
The manufacturer should ne able to advise you on further action
GOOD LUCK
Jun 18, 2015 | Tablets & eReaders
Reboot my galaxys from black screen
Run a Hardware Factory Reset A hardware factory reset should be used as a last resort to fix a GS4 . The process will delete all stored information on the GS4 and return the device to its factory configuration; you won't be able to back up your data if you're getting the BSOD. Prepare the phone for the hardware factory reset process by performing a battery reset and pulling out the memory card. You can remove the back panel by pulling on the indentation near the power button. You can leave the SIM card in the device. After you've closed the device, plug it into the charger to avoid losing power during the reset process. To initiate the recovery menu, boot the GS4 by holding the "Volume Up," "Home" and "Power" keys. On the "Recovery" menu, use the volume keys to select "Wipe Data/Factory Reset." Then press the "Power" key to initiate the hardware factory reset.
Jan 03, 2015 | Samsung Galaxy Cell Phones
How to factory reset with only remote, while screen remains black w/ 5 thin horizontal colored lines streaking. Why is screen black?
Without a proper screen, you can't do a factory reset to this set. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 07, 2014 | Samsung PN42B450 Plasma TV
Coby not working
1. Turnn completly off the tablet.
2. With the tablet turned off, holding the return button while turning on the tablet-pressing power button. Keep holding the return button until you see the Hard Factory reset screen.
3. Confirm the hard reset procedure. Once done, simply wait until process has finished-the tablet will restart. This process can take up to 30 minutes, so it's very important that the battery of the tablet is completly charged before attempting the hard reset. If you can connect it to the charger while resetting, even better.
May 28, 2014 | Coby Tablets & eReaders
Android System Recovery
Obvious question is what the tablet had been doing during its' last use.
Was something newly installed, was system or apps updated, etc. ?
Were all the APPs and or system shut down properly ?
Did update or installation recommend restarting system, prior to use ? Were multiple installations / updates performed ?
Your device appears to be in a recovery boot-loop.
As stupid as this may sound ...
Is the power adapter connected ? Let battery charge for at least 30 minutes and try again.
If battery is low, it may not complete the reset. - you should have seen something on the screen, denoting " wipe and reset " procedure and completion - prior to (#1) Rebooting device
Per your post, you have already (#4) wiped the data and instructed the device to reset to factory settings, then (#1) Reboot system.
That is the generally accepted reset method
This problem is not all that uncommon, it generally results when attempting reset, internal boot commands error for what ever reason. ( can not find the factory restore / recovery file set ).
This problem is more common when "fixes ", Specialty " Roots " or "mods" have been installed by the user - making changes to the boot program and commands OR when manufacturer files have been deleted / moved from system access. - Common suggestion is to work backwards through the mod processes and / or attempt to re-install mod or follow the special mod recovery method.
Without having available the proper ROM " flash " update / installation file(s), and you may " brick " the device.
I recommend you go to manufacturer site and check for available ROM files, reset / reinstallation processes ( memory card method ? )
You state the tablet is less than six months old. You may want to contact manufacturer for possible warranty service.
They will most likely ask the referenced obvious questions, to better understand the cause / nature of the device failure and recommend the best immediate possible solution.
This may not be what you seek, I hope it will provide better direction.
Apr 20, 2014 | Hannspree SN10T1 101 Tablet
The screen on my Kocaso M9200 stays black even though I have it connected to a viable charger. I NEED this to boot!!
Kocaso M9200 User Manual FAQs states ...
"Why won't my device turn on?
Make sure your tablet has been charged for at least four hours prior to use. When plugging in the cable, make sure you are not accidentally plugging it into the headphone jack. Also, the power button is on the side (for tablets) and not the one on the front of the touchscreen. The button on the front is for navigation".
"Should I perform a Firmware Update?
Not necessarily. This is actually intended if obscure issues with the tablet occur. Unless you are having issues with the tablet which a
Factory Data Reset has not resolved, it is not advised that you perform this step. However, if you are sure you wish to attempt this procedure, please visit the following link for available firmware downloads and the instructions on how to perform the update:
http://mymidpad.com/firmware/"
Link for M9200 .. Support Firmware. Please read details and only attempt firmware upgrade as a last resort. Its always best to get it done at a Kocaso service center. Hope this helps.
Feb 09, 2014 | Computers & Internet
My Cisco IP Phone 7945G keeps rebooting after I did a factory reset. Is there a way to fix this?
According to Cisco, when initiating a factory reset procedure certain information from the IP phone is erased while other information is reset to the factory default value, as shown in the list below:
Information Erased:
  • CTL File (Certificate Trust List)
  • LSC File (Locally Significant Certificate)
  • IP Phone Call History (Calls Received, Placed, Missed etc)
  • Phone application
Information Reset to Default:
  • User configuration settings (ring tone, screen brightness, sound levels etc)
  • Network configuration settings
t is highly advisable to follow the firmware upgrade procedure in a non-working environment to ensure other phones are not affected (in case of an accidental reboot), and to avoid the freshly factory reset ip phones obtaining the working environment's settings.
Please use the link below and follow the instruction http://www.firewall.cx/downloads/cisco-tools-a-applications/cisco-ip-phone-a-ata-firmware-downloads.html
Aug 28, 2012 | Cisco 7945G IP Phone
My micromax x600 mobile asking input phone lock code
visit www.hard-reset.com or see the result.Hard reset
Cold boot method: Hold the "Power Button" of the Pocket PC with one
hand while holding the stylus tip to push in the "Reset Button" with the
other. Simultaneously release both the "Power Button" and "Reset Button".
Appropriate situation: If a previous reset has already been attempted and
the Pocket PC is still unable to maintain normal operations, has no
response, or if the screen is frozen.
Before executing the preceding "Cold boot method", please carefully
consider the following instructions and then decide on the cold boot
method.
1. After a cold boot is performed, if no buttons are pressed, when Pocket PC automatically completes the system startup process, the last display will be the Today screen. This is identical to the reset result.
2. If a previous reset has already been attempted but the Pocket PC is still unable to maintain normal operation, consider the following solution:
After cold boot, hold the End Button eten_glofiish_x600_hard_reset_soft_reset_5.jpg on the bottom right of Pocket
PC until the system inquiry screen is shown, and then release the End
Button. Next, please read thoroughly through the instructions on cold
booting before continuing carefully.
Erase all data and load default?
The default is "No." If Yes or No was not
selected, after a few seconds the system will
automatically execute the default No.
If you long press Left Soft-Key for a few
seconds to select "Yes," then the system will
erase all data and load default. After your
Pocket PC restarts, follow the instructions on
the screen to complete.
Caution!
1. After performing a cold boot, the system will retain Microsoft Windows
and pre-installed programs. If you answer "Yes" to the question displayed
after a cold boot, other items such as the user's input data, newly installed programs and user settings will be lost.
2. There are two ways to retain your data, loaded default and registry:
Perform a Reset.
Performing a Cold Boot, and answer "No" when the above question
displays.
Jun 27, 2012 | Eten E-Ten GloFiish X600
How to rest to facory settings?
Hello Sir,
There can be 2 resets which can be done. The one is BIOS Reset and the Other is the OS Reset. If you want to get the Laptop to Factory settings then you have to do a OS Reset. For this you need to get the Operating System Recovery CD. Insert the CD and boot the CD. The Recovery Procedure will automatically start and the Computer will guide you through the rest of the Procedure. Follow the Computer's instructions and the laptop will be restored to Factory Settings. ' Reply me if you have any doubts or problems.
Thank you Sir, Have a nice day.
Oct 18, 2009 | Compaq Presario Notebook
Computers & Internet Logo
66 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
