Question about Samsung Tablets & eReaders
Overheating start to get very heated very fast
My kindle fire overheated while charging now it won't turn on. It goes to the amazon logo then gets stuck on the fire logo.
You may be able to use a fast-boot cable for the fire tablet, google fast boot cable for Amazon Fire Tablet and see if its uses fit your need.
Mar 01, 2017 | Amazon Tablets & eReaders
Why is my rca bought 2013,the screen is steadly jumping
If re-callibrate or a new setup will not help a little suggestion can be that the unit was stored in an unguarded moment in full sunlight.
Then the overheating goes very fast to high heat grade in a short moment, and connectors fcc and capacitors
start the tablet only if it starts not direct with jumping , open the case try to buy a canister coldspray and when the screen is beginning to jump but ONLY THEN spray some on the print on the components on the place if you have luck where it stopped with jumping.
Firmware upgrades are not made for this kind of problems because its should have done it in the beginning, and now the problem is there it must be passive components deformed capacitors or a faultering fcc sheet connection.
Nov 06, 2016 | Tablets & eReaders
FORGOT MY PASSWORD WHAT CAN I DO FAST?
Nothing is fast, faced with such daftness as forgetting your password.
You will have to do a Factory Reset from a computer which erases everything on the device and starts you off with a clean machine. If you can't remember passwords of passcodes, I suggest you don't use one.
Dec 29, 2015 | Tablets & eReaders
How can i prevent my nextbook premium8hd from overheating
Tablets are designed to not heat up much at all, let alone overheat. If it is overheating, there is a hardware problem that is causing that. If it is still under warranty, get it replaced.
Aug 25, 2014 | Tablets & eReaders
GT-P7500
It means that the app has over heated if you want to put it that way. It just means it is stupid and your phone memory is filling up and fast
Jul 23, 2013 | Tablets & eReaders
Is it possible to unsolder a processor from a motherboard without sacraficing it?
Unsoldering with a desoldering pump is easy. The problem will be soldering the new processor without overheating it. You would have to use a little flux and work fast. Perhaps put the heat sink in the freezer before you solder. Very strange to not have the processor in a socket so you can remove it.
Sep 30, 2017 | IBM ThinkPad X41 Tablet PC
My mother board gets heated up while the charger is plugged after 15minutes the system shuts down and does not boot for atleast 10 min why so i doubt whether mother board heat sink fan working properly or...
your Healsink is not working properly....Overheating is a very common problem in HP. I myself have an HP machine and i have replaced my Heatsink three times...
hope this will help...cheers:)
Sep 25, 2010 | HP Pavilion TX1320US Tablet PC
Cooling fan keeps running on m275 gateway laptop
If the fan keeps running constantly, it could be a number of things:
- The interior of your laptop could be dirty or dusty. If you remove the bottom cover and blow some compressed air into the case (when the computer is off and the battery is removed) it should resolve the problem.
- The CPU is overheating. Do you have it overclocked? What do you primarily sit it on when you are using it? You may want to think about getting a cooling pad (either powered or unpowered).
- The fan is dying or dirty, and not spinning as fast as it should. If this is your problem, you'll need to replace the fan, but this is the least likely scenario of the three.
Jun 21, 2010 | Gateway M275 Tablet PC
Tablets & eReaders Logo
11 people viewed this question
Top Samsung Tablets & eReaders Experts
Jaime Hernandez
Jerry Greenberg
Jerry Greenberg
Are you a Samsung Tablet and eReader Expert? Answer questions, earn points and help others
