Question about Frigidaire FFLE1011MW Electric Washer/Dryer Laundry Center - White
Frigidaire stack dryer turns off after few seconds
  • Frigidaire Master
  • 5,323 Answers
CHECK MOISTER SENSOR AND OR THERMISTOR. THERMAL CUT OFF AND CYCLING AND HI LIMIT THERMOSTATS
Posted on Apr 01, 2015
SOURCE: directions on stacking dryer on washer
get a stacking kit from your local appliance strore that sells frigidaire. they ARE EASY TO STACK WITH THE KIT.
Posted on Nov 16, 2007
geemarie
  • 876 Answers
SOURCE: need new washer to stack on my dryer!
measure your dryer carefully and check with the dealer where you wish to purchase a machine, regarding
the stacking kit. It may work. They are general standard sized. Don't ry to gerry rig anything or you may have big problems. In your case I recommend using a well known SMALL appliance store that does theri own installations, so they will bring what they may need, but if yours works, they can still use it.Good Luck
Posted on Aug 13, 2008
huuum
  • 750 Answers
SOURCE: stacking a frigidaire washer and dryer
This stacking part is all you need. It is a white plastic bracket that attaches from the rear of the two appliances. And it should have come with instruction too.
Posted on Dec 05, 2008
badfrankie
  • 92 Answers
SOURCE: i have a frigidaire glet1142cs0
UNPLUG THE MACHINE. Take the back off the dryer, usually 4 to 6 screws. On the backside of the panel you just took off should be a schematic showing where the thermo fuses are.
Take an ohm meter and check across the prongs sticking up, you may have to unplug them to get good contact. They should show 1, open, if they show 0, short. they need replaced. There are online parts companies that can help you get the right part.
It is unlikely that the element is bad, but if the thermo fuses show open, then you should be able to see the element, and replace it.
Posted on Mar 27, 2011
  • 14 Answers
SOURCE: need part break down for frigidaire FEX831CS top
go online to frigidare's web site,or contact sears parts central
Posted on Dec 19, 2011
I have a stacked Frigidaire FEZ831CA washer/dryer combo and when running the dryer it makes a very high pitched (AND LOUD) screeching sound. Any ideas as to what might be the problem? Thanks, Sean
screeching sound
Sean, Bad felt gasket body to drum, if belt drive on dryer, it could be worn and slipping, making a screech, or if not the belt, the drum may have a worn bearing on its hub allowing it to run crooked and rub where it should not.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Disassembling reassembling stacked clothes dryer
Frigidaire Stacked Laundry with Noisy Dryer
How to Replace an Electric Laundry Center Dryer Drive Belt Kenmore...
Mar 29, 2016 | Frigidaire Washing Machines
How to stack dryer LEQ1442ES1 and what stack kit to buy?
Hello Friend, that's a great question!
The recommended stacking kit for your Frigidaire dryer (LEQ1442ES1) is part number STACKIT2. Further information regarding the stacking kit and directions can be found in the installation instructions listed below. Hope this helps! - Z
Frigidaire Manual Search Results
Sep 05, 2014 | Frigidaire Dryers
Frigidaire model fex831cso serial xe34800123
Hello friend, we appreciate your post!
It appears you have a laundry center FEX831CS0 and that your dryer is not working. Can you provide me more specific details? Is your dryer not heating, not turning on, or not completing a cycle? For instance did you notice any strange functions or odd noises prior to this issue? With this information I can better address the issue at hand. Thank you - Matt
Jul 19, 2014 | Frigidaire FEX831CS Top Load Stacked...
Turn off buzzer on frigidaire dryer LGR331SO
Good Afternoon Friend,
I understand that you want to turn the buzzer off of your Frigidaire dryer, model# LGR331SO. With your model dryer, you are not able to turn the buzzer off. I hope this is helpful.
-Best Regards-
WP
May 30, 2014 | Frigidaire GLEH1642DS Front Load Stacked...
Frigidaire FEX831CS Top Load Stacked Washer / Dryer will not spin - burn smell
The transmission is burnt out. Happened to my mother in law a few months ago.
Nov 13, 2011 | Frigidaire FEX831CS Top Load Stacked...
Stacking Frigidaire dryer on washer using stacking kit 5303937141
i have the two brackets but have no idea how they attach. does the top come off the washer?
Mar 23, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Frigidaire Gallery Front-loading Dryer Stops Tumbling
I have a stacking Frigidaire washer/dryer. The dryer will not start at all.
Thanks for any info you can offer.
Dec 23, 2007 | Frigidaire GLEH1642DS Front Load Stacked...
Stacking Instructions
You will need a stacking kit 5303937141 to stack them, Feel free to ask for any more advice.
Nov 24, 2007 | Frigidaire FEQ332E Electric Dryer
Directions on stacking dryer on washer
Nov 12, 2007 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire FFLE1011MW Electric Washer/Dryer Laundry Center - White Logo
91 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
