Question about Car Audio & Video
I want to transfer vinyl records to my macbook pro with a usb manual turntable
SOURCE: Zennox USB Turntable
send it back----it's faulty
Posted on Sep 20, 2008
  • 3 Answers
SOURCE: Arm does not track properly but skips across records
Just guessing, but it sounds like you haven't counterbalanced your tone arm.  When a tone arm skips, it's usually because there's too much counter weight on the rear of the tone arm.  You want between 3-5 grams, but first you have to calibrate your tone arm (balance it so you know where zero is).  If you don't know how to do this, refer to the Ion directions called "Tonearm Setup" in the instructions.
Posted on Jan 04, 2009
robmcd27
  • 423 Answers
SOURCE: Proper cleaning of old vinyl record albums
Get yourself a nice carbon fiber brush. Purchase some record cleaner or just get some isopropyl alcohol 90% (it has less impurities). Secure the arm of the turntable so you don't scratch the record and put the record on it. Put some of the cleaning solution on the brush..not the record. Put the brush on the record and turn the platter counter clockwise to work the dirt loose. Check the brush and clean it if need be and repeat. Take the record off and clean the turntable. Flip the record over and repeat the cleaning process. That should do it. Thanks for stopping by and come back if you need more help. If you don't mind, rate my answer appropriately. Thanks.
Posted on Feb 20, 2009
  • 1348 Answers
SOURCE: YAMAHA P-220 VINYL RECORDTURNTABLE SPEED PROBLEMS:- HOW CAN I
if you open the bottom,there is variable potentiometers for the speed adjustment.you need a strobe reference disc if you want it exact.
Posted on Aug 15, 2009
Grubhead
  • 5487 Answers
SOURCE: Digitech turntable - skipping stylus and arm
You might need to apply more pressure to the stylus. There should be a weight on the end of the arm, it should have a control to move it up and down. The only other thing is the stylus damaged from transit?
Posted on Feb 02, 2010
Ringing when recording into mac
This sound like it could be somekind of feedback hum, or earthing problem. Check all the connections.
Mar 14, 2014 | Numark ttUSB Turntable
Music volume low when digitizing vinyls
The software itself should come with an sound imput level control. But if you can't find it or it's on full then there are ways round it. However it depends on how the turntable is connected to your computer. Most turntables require in an amp to have a magnetic cartridge pre-amp to boost the level to that say of a tape. Rather than mess around sometimes it's better to get one of these pre-amps and have that between the turntable and the computer. Then the sound should be the same level as a tape signal. You will have to bypass that pre-amp if you are recording anything else such as tapes to your computer. Or you will get a noisy loud signal!
Just search for a "magnetic cartridge pre-amp" on the web.
Jan 31, 2014 | Music Hall USB-1 - turntable
Bad sound quality
You cannot connect the turntable via a microphone port. You need to connect via a USB port. If you have not got a USB port to connect it as the others are in use, you can buy an extension USB socket which, will allow you to put more devices via one USB port.
Sep 04, 2013 | ION Audio Vinyl Recording Turntable
How to best record to computer
For the software I would recomend Magix Audio Cleaning Lab. You should find several different versions on Amazon.
Jan 29, 2013 | Stanton STR8-80 Turntable
Can't hear audio while playing or recording from my Numark to Audacity yet I can hear the audio when the transfer to Audacity is complete.
You will have got the audio muted in your windows recording mode. If you right click on your speaker icon it will say recording devices. Click that and you will be able to see all the devices and if they are activated.
Jun 08, 2017 | Numark ttUSB Turntable
Not all of the sound/music is being transferred from the LP.Hard to explain, but its when the LP has sound coming out of each speaker independent of one another, only one side is coming out on the recorded...
I know this is an old post, an I dont' have a solution yet, but t seems the same problem as on my Ion USB recorder - One of the input channels is not working. Like you, I found one of my music tracks not plying right - there was only the instrumental and no vocal. When I experimented, and changed round the jacks on the cable coming from the turntable (red and white plugs), I then got only vocals and no instrumental. Obviously one of the input sockets on the USB recorder is no longer working (I already checked the turntable and cable itself by playing back he same track with both stereo channels through my amplifier). You can either get the item replaced if its still under guarantee, or fix it yourself, if you have the necessary skills, neither of which apply to me.
Apr 22, 2011 | ION Audio Vinyl Recording Turntable
I purchased a Vibe Sound 3 Speed Turntable w/USB to PC and it does not have sound when I plug it in to the USB. The record is spining and I can hear sound from the needle.
The turntable won't make sound on its own when connected to the USB port. There are probably some drivers on the CD packed with the table that you'll need to install, and then you'll need to select the device in the Windows sound control panel. You'll also need some software to record and edit your vinyl if you want to transfer your records to CD.
I'm not familiar with the brand of turntable you have, just the ION, but it probably came bundled with some application on a CD. The ION table comes with Audacity, as well as some trial versions of audio processing (click and pop filter, hiss remover, etc.). Audacity is free, open-source software you can download here if you want it. It allows you to listen to and record your vinyl audio as wave files, then edit it, split tracks, add effects, and other fun things.
Feb 13, 2011 | Computers & Internet
Transferring Vinyl from Kenwood P26 Turntable to PC
Argos has a turntable for 90 pounds which converts Vinyl to MP3 or wave . There are similiar versions for cassette tapes. If you need help finding one. let me know
Mar 14, 2008 | Audio Players & Recorders
I cannot access the turntable thru my USB hub.
I received an updated driver from Numark but that still did not solve my problem. It turned out to be some sort of incompatability with my USB 2 card. When I plugged the turntable into my old USB 1 slot, my computer recognized it immediately. The new Audacity and MixMeister programs that were sent as a fix from Numark are just burning programs and not drivers for the device. I can now convert my old vinyl with ease.
Mar 10, 2008 | Numark ttUSB Turntable
Car Audio & Video Logo
792 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
