Question about Breville & Sealed Bcg800xl Smart Grinder With 25 Grind Settings
Breville smart grinder no longer grinds course it is now medium grind?
Grinder no longer grinds course for french press.grinds medium and cannot get french press plunger to plunge anymore.grinder suddenly stopped grinding course
  • comp_dad463
    comp_dad463 Oct 19, 2014
    Quality of beans... and or the system has had a jam and jumped a cog
EsWorld
  • 1618 Answers
SOURCE: severe clogging
Try using long grain white rice works better than minute rise, if that does not help, then the burrs need to be replaced on grinder.
Posted on May 14, 2009
SOURCE: Why is the grind from my Breville BCG450XL in the
The Breville was designed to be used with Pressurized Portafilters, which most Home Espresso Machines have. These filters use a courser grind, so when it says Espresso on the Breville, it's really closer to Drip. The Turkish setting is barely fine enough for Espresso. There is a limiter on the Breville that prevents the user from going any finer, if you crack it open and remove the limiter, you can go as fine as the Solis. Becareful though, the burs can come so close to each other that they can chip and break.
Posted on Jul 10, 2009
SOURCE: Hi. On the Breville CG10 coffee grinder, is the
Yes, 1 is finest and 9 is coarsest.
From the manual: 8 - 9 Percolators 4.5 - 6 Espresso Machines - Steam System 3.5 - 5 Drip filter coffee makers 2.5 - 4 Espresso machines - pump system 1.5 - 2.5 Espresso machines - semi automatic pump system
Posted on Dec 28, 2010
ginko
  • 19396 Answers
SOURCE: I ground some nuts for
Hi.
The problem is not the motor.Coffee grinders must only be used with coffee. Even the beans used must be of quality suitable for the grinder. Too oily blends will result in a jammed grinder, as happened after grinding the nuts.
The repair is done disassembling the grinder, cleaning mechanics and reassembling. Unless you have disassembled a similar appliance before (eg. a blender gear box), there is a good chance that the attempt of fixing the grinder will result in more problems.
Rather than disassembling, a good alternative for the user is calling the Breville number listed on the grinder manual, and discussing repair with the manufacturer.
Regards.
Ginko.
Posted on Feb 01, 2011
  • 5 Answers
SOURCE: My grinder does not grind anymore. The machine
im only guessing here but id assume that the space between the burrs is likely controlled with a spring or something which has probably broken leaving the burrs as far apart as possible, if you gut the machine you may just be able to fix it with no parts if its simply a spring thats come off, the only other possibility i can think of is that your burrs or whatever they connect to are broken somehow, but all these are only guesses as im not familiar with your machine, my motto is if its broken you may as well pull its guts out to see if you can fix it, youve nothing to lose and youd be surprised how often it works
Posted on May 15, 2011
Why do I get lots of static electricity which causes ground coffee to spew all over the place
you are on the fine grind setting and the coffee dust is flying out? right!. change the setting to something a little more course, and empty the dust from the last grind.
Sep 01, 2014 | Breville Bcg450xl Conical Burr Grinder...
Grinder does not grind coffee properly
sounds like the motor is loosing efficiency,,,I.E. motor going out.
Jan 13, 2014 | Bodum Antigua 5670/5671 Electric Burr...
I have a Breville BES860XL and the grinder is not working. If i overide the interlock, It will spin, but does not have enough power to grind beans
It seems there's a fault in the grinder gearing in this particular model.There's no solution but to take it to Breville repair...
I have the same problem and so does a friend of mine. The grinder will spin without beans in the hopper but as soon as beans are introduced the grinder makes a loud noise. Like the gears are slipping and there's not enough power to grind.
Jun 10, 2011 | Breville BES860XL
Whatever the setting is at the grind is always fine. What can I do to re-calibrate the grinder?
Grind Adjustment Tools required: Large blade and medium Phillips head screwdrivers In order to adjust the grind, follow these steps (Refer to figure A): 1. Remove all coffee from the hopper. 2. Set selector knob to the finest setting (Espresso or Turkish) depending on the model. 3. Loosen both knob retainer screws in selector knob one turn only. 4. While pressing the bag switch, located behind the spout, press the START button so that the grinder will run during adjustment. 810 model - Press the ON or START button so that the grinder will run during adjustment. 5. With the grinder still running, turn the adjusting screw in the center of the selector knob slowly to the right until a slight clicking noise is heard. Immediately turn the adjusting screw to the left one grind setting. This is the finest grind obtainable. 6. Tighten both of the knob retainer screws. Once the ESPRESSO grind has been set (Turkish for Model 835, 875, 890), the other grind settings will automatically set correctly. 7. Press the STOP or OFF button. IMPORTANT: Always be sure the grinding burrs are not touching while the machine is running on the ESPRESSO/TURKISH setting. Otherwise serious damage to the motor may result. dr_buckhead.png
Nov 19, 2010 | Grindmaster 810 T Electric Burr Grinder
Coffee grinder will not turn on
I recently had this same issue - it turned out that the lock switch no longer engaged because the spring came out of alignment after the unit was dropped. Chances are you have a similar issue. You can test this by using a small screwdriver to press down on the safely latch and then pressing the ON/OFF (careful of the blades!!). then you can easily fix it.
Dec 26, 2009 | Hamilton Beach 80355 Custom Grind Coffee...
Breville Die Cast 800ESXL Espresso Machine: Problem... Watery espresso. My machine worked great for a year, then all the sudden, the espresso is watery and the basket where the grinds are is full of water...
Personnaly, when I use the big filter, the grinds are dry after the extraction, but for the small filter, it's all soggy. If you look at the documentation, ( http://kitchen.manualsonline.com/manuals/mfg/breville/breville_coffeemaker_product_list.html) they say wet coffee grind after extraction is normal.
But did you change the coffee brand ? Or the grinding level ? How do you grind your coffee ? I had big troubbles once with a commercial grinder at my grocery store, it's when I decided to buy my own Breville grinder.
Good luck,
JF
Oct 16, 2009 | Breville Die Cast 800ESXL Espresso Machine
Cannot get the grinding ring option to turn
This is a set screw. You need to take this out.
You can access this to either clean the burr
grinding wheel. Maybe this needs changed.
If you google the Kitchenaid A-9 Burr grinder you can get instructions to download on this machine.
Mar 05, 2009 | KitchenAid A-9 Electric Burr Grinder
Parts and Grind Selection
The current Kitchenaid A9 burr grinder glass jar is interchangable with the original Hobart/Kitchenaid A9 glass jar; therefor, the gasket should also interchange - contact Kitchenaid customer service to order a gasket.
Setting the grind is accomplished by grasping the body of the ginder in one hand and the grind-selector ring (collar that the jar screws into) in the other. Hold the base tight and turn the selector ring clockwise for a finer grind, counterclockwise for coarser. Be careful not to completely unscrew the selector ring; if you are not sure how much adjustment is left, screw it all the way clockwise until it stops (finest grind); then, back it off, up to one full turn to make the grind coarser.
The selector ring has the words coarse, medium and fine cast into it; these are rough postition markers. There is a triangle cast into the body of the grinder, just above the brand name, that can be used to diral in a preferred level of grind. I use a medium-coarse grind for drip coffee makers; to do likewise, position the selector ring so that the triangle is pointing midway between the words coarse and medium.
Dec 21, 2008 | KitchenAid A-9 Electric Burr Grinder
Breville cafe roma
Obviously the problem is with your grind, not the Breville. SImply adjust your grind to finer.
Nov 14, 2007 | Breville ESP8XL Espresso Machine
How to select grind courseness for a DeLonghi DCG39 grinder
Go to delonghiusa.com. customer care. manuals. They have yours to download.
Aug 18, 2007 | DeLonghi DCG39 Electric Blades Grinder
Breville & Sealed Bcg800xl Smart Grinder With 25 Grind Settings Logo
206 people viewed this question
Top Breville Coffee Makers & Espresso Machines Experts
Steve Banks
Tally Girl
Tally Girl
Are you a Breville Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
