Question about Proform 595LE Treadmill Walking Belt
Need to adjust belt - Proform 595LE Treadmill Walking Belt
Why does the belt slip forward when I run on it?
Adjusting Tension on a Treadmill Running Belt It is necessary to properly tension a treadmill belt when it is replaced. After time, a belt can stretch and may begin to slip. When this happens, it is necessary to adjust the tension of the running belt to stop it from slipping. Manufacturers of treadmills generally agree on one of three procedures for how to tension a treadmill running belt.
  1. Adjust for no slippage of the treadmill walking belt on the front roller (Often referred to as the "Stomp Test")
    1. This procedure works well for a previously installed belt that is now slipping.
    2. Underside of belt should be free of any glazing/wax buildup.
    3. Rollers must also be free of wax buildup.
    4. Be sure belt tracking/centering is correct before proceeding.
    5. The most popular speed for this adjustment is 2mph to 3mph.
    6. Try to slow the belt by applying pressure with your foot against the belt movement while grasping the handrails. If the running belt slow, slips or stops (and the front roller does not) adjust BOTH adjustment bolts 1/4 turn clockwise. Test again and repeat adjustment if necessary.
  2. This procedure requires two belt gauges or calipers
    1. This procedure works well when installing a new belt.
    2. This procedure requires you to stretch the belt. Depending on the manufacturer*, this varies between .4 and .6 percent. A dial on the gauge or caliper will indicate the amount of stretch. *Consult the owner/service manual for proper tension.
    3. If you are working on a previously tensioned belt you will need to release the tension before attaching the gauges or calipers.
  3. Gauges or Calipers unavailable
    1. Release the tension on the belt.
    2. Using a yard stick or tape measure, place two marks on the left and right edges of the belt and deck 36 inches apart (or 50 inches if you prefer).
    3. Adjust the left and right tensioning bolts until both sides measure 36 3/16 inches (or 50 1/4). This is equal to .5% of stretch.
    4. Test for proper tracking and tension, adjust if necessary.
How to Tension Treadmill Walking Belt that Slips
Sep 15, 2015 | Exercise & Fitness
Where is the lawn mower belt adjustment? Need to tighten belt.
There are no belt adjusters on most mowers, they gave spring loaded constant adjusters..if the belt is coming off it because the belt is worn..your mower should have one or two adjustable belt protectors around the the motor and deck pulleys they keep the belt from coming off during on and off operations the design is to be set close enough to the pulleys that will not allow the thickness of the belt to pass through...so if the belt is Worn too much or the proctectors are out of adjustment the belt will come off..usually during non mowing or just when engaging the deck or drive..kind of tricky to get at..but can be done yourself...do check them out if they are more then about 1/4-3/8 inch they are out if adjustment..if not the belt is worn out...good luck..
Jun 03, 2015 | Garden
How do I adjust the walking belt on my treadmill, it's going to the left?
belts always move to the highest or tightest point . to adjust move one adjusting screw while the belt is running and you will see the belt move across the roller to the highest/ tightest point
adjust the screw until you get it to run in the proper position
May 14, 2015 | Sportcraft TX 4.9 Model 4041 Walking Belt
I have a broken belt that goes on the same pulley that another belt is already on. What all do I have to remove to be able to put the belt on. I guess the belt that needs put on is for the heat & air...
A/C Compressor Belt
  1. Remove the alternator/power steering and water pump drive belt to gain access to the air conditioning belt.
  2. Loosen the tensioner pulley locknut, then turn the adjusting screw to raise or lower the tensioner pulley assembly. Remove the belt.
To install:
  1. Install the belt.
  2. To adjust the belt, loosen the tensioner pulley nut and adjust the belt tension by tightening the adjusting screw. Tighten the pulley nut to 40 ft. lbs. (54 Nm) after adjustment.
  3. Install the alternator/power steering and water pump drive belt and adjust.
  4. Start the engine and check for proper belt alignment and any abnormal noise.
Nov 01, 2010 | 1995 Dodge Intrepid
Belt is slipping,
It might just need a simple adjustment of the running belt that can eliminate the slipping refer to you owner's manual for the procedure. It will be close to all treadmill running belt adjustments.
Here is a generic procedure for adjusting the belt:
If the walking belt slips when walked on. Run the treadmill @ 3 to 4 mph, walk for a few minutes, Using the allen wrench, turn both rear roller adjustment bolts clockwise, 1/4 of a turn. Then repeat adjusting procedure until walking belt is properly tightened.
Jul 06, 2010 | Life Fitness 9000 Next Generation...
Loud squeal noise from serpentine belt on 99 dodge truck with 318 motor when its cranked up
If you have an manual adjuster you need to tighten or replace the belt, belt treatment may help.
If you have an automatic adjuster. You can try belt treatment, if it doesn't work you'll need to replace the belt and maybe the adjuster.
Jun 06, 2010 | 1998 Dodge Ram 1500 4WD
My nordic track treadmill's walking belt stops when I start walking on it but the motor is still running although the front roller is not moving when I start walking on the walking belt. Do you think the...
Unplug the unit remove the motor shroud inspect the drive belt if the rubber feel slick then my recommendation is to replace the drive belt. Adjusting the drive belt may take care of the problem if you do not need to adjust it too tight. If you choose to do the adjusting and feel you have adjusted the running belt thinking it would resolve the slipping, then back the tension down until it the running belt is slipping then adjust until the slippage is resolved.
May 17, 2010 | Nordic Track Exercise & Fitness
Everything seems to work fine except a small slip in the track about every 30 seconds or so. Is there something that needs to be tightened?
The walking belt may be too loose. If you have made recent adjustments, lubricated, or had repairs, a belt can slip if not tightened. The belt can slip if you have too much friction or if the belt has been recently lubricated. If lube does not help your problem and you have exhausted all other possibilities, the walking belt is most likely worn out and must be replaced.
To adjust the belt: Less Belt Tension: turn both adjustment bolts on back of treadmill in a counter-clockwise direction. More Belt Tension: Turn both adjustment bolts equally in a clockwise direction. Center Adjustment (moves belt center to the left): Turn left-side adjustment bolt counter-clockwise. Center Adjustment (moves belt center to the right): Turn the left-side adjustment bolt clockwise.
An over tightened walking belt can raise the amp draw of your treadmill, contribute to seam separation on the walking belt, or both, so do not over tighten the walking belt.
You should be able to lift the belt in the center on the side by approximately 2” to 3”, if you cannot lift it by 2” to 3”, the belt is too tight.
Feb 20, 2010 | Nordic Track NordicTrack Treadmill, A2550
HOW DO I ADJUST FAN BELT ON1998 Z3 bmw?
serpentine belts dont need adjusting they have a tensioner pulley that is spring loaded / you may need a new tensioner pulley or belt . hope that helps
Jan 30, 2010 | 1998 BMW Z3 Roadster
1998 dodge neon airconditioning belt adjustment?
This procedure involves correcting the tension on the power steering accessory and A/C compressor drive belt.
1. Loosen the power steering pump locking bolts A and B and pivot bolt C(Illustration 1 and 2 ) to allow adjustment of belt tension.
2. Using a 1/2" breaker bar, adjust belt tension by applying torque to the square hole "D" on the power steering pivot bracket. Adjust the tension as follows:
Belt tension with no belt replacement: A. Using the Belt Tension Gauge Special Tool Kit C-4162, adjust the belt tension to 100 lb.
B. Tighten in order, first tighten the locking bolt A to 27 Nm (20 ft. Ibs) then, bolt B to27Nm (20 ft. Ibs). Finally tighten the pivot bolt C to 54 Nm (40 ft. Ibs).
Belt tension with belt replacement:
A. Using the Belt Tension Gauge Special Tool Kit C-4162, adjust the belt tension to 135 lb.
B. Tighten in order, first tighten the locking bolt A to 27 Nm (20 ft. Ibs) then, bolt B to 27Nm (20 ft. Ibs). Finally tighten the pivot bolt C to 54 Nm (40 ft. Ibs).
C. Start the engine and allow the vehicle to idle for 15 minutes to allow the belt to seat.
D. Repeat the belt tensioning procedure, set belt tension to 135 lb.
click here for picture 1
click here for picture 2
Jun 13, 2008 | 1998 Dodge Neon
Proform 595LE Treadmill Walking Belt Logo
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Electro Med Services...
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
