Question about Samsung LN Televison & Video
Samsung model LN-t3732H sound but no picture
Sound, no picture
praky16
  • 744 Answers
SOURCE: Black picture, perfect sound
hi...your convergence IC's have gone bad.
These IC's operate at a very high temp, and usually only last 4-5 years.
If you remove the back of the set, you will want to look for the BIGGEST heatsink in there, on that heatsink, you will see 2 large IC's , probably STK392-040, or STK392-120's or something close...regardless - you can go on ebay to order the new ones, but MAKE SURE they are Genuine SANYO IC's and not counterfiet cheapies. the cheap ones may only last 2 months..
You will also need some "Heat transfer paste" - you can pick this up at radio shack.
Once you remove the old IC's, test all the large resistors near them.. pull one side of the resistor out of the board so you can check it out of circuit. they will usually have the value in Ohms, printed directly on the resistor, but you may have to use the resistor color code to find out what value they are....However, usually if there is any damage, the resistor will look like it has been HOT or fried. replace the IC's and any bad resistors, and you should be good to go.
If after replacing the IC's and any defective resistors, the convergence is still bad, make sure to use a multimeter to check ALL fuses on the boards, --- sometimes when the IC's go, they will take out a fuse to the convergence power supply. If you find any bad fuses, replace them accordingly!
Hope that helps u alot...
thank u!!!
Posted on May 25, 2009
ginko
  • 19396 Answers
SOURCE: sound no picture
If an LCD TV has sound but no picture do the following:
Use the source button to ensure that source is not set to the wrong input.
Try unplugging power cord for ten minutes, to ensure it is not a setting problem.
Check all the video cables at the back of TV.
Check Light /Color settings.
If problem persist and does not depend on external receiver or settings, then it is likely an internal fault.
If it has sound but no picture then one of the following parts is faulty, and must be tested and replaced:
Theinverter is the high voltage board that provides variable power to thebacklight lamp. This is the most common. When inverter is faulty youcan get no picture, or a very dim picture that can only be seen bypointing a torch light with a 45 degree angle on the LCD surface fromvery near distance.
The inverter must be tested by reading voltages with a multimeter.
The LCD ribbon cable/LCD display and connectors.
Thisis quite uncommon, but happens. If the TV had been hit or moved the LCDcable may have slipped out, or the LCD connector may be damaged.
The LCD controller board.
Thisis the board that controls the video signal, it is difficult to test,as there is need to read determined values on IC pins. To test thisboard you need to purchase a service manual and follow thetroubleshooting diagrams on service manual.
Input/Output Signal boards.
This are the boards where youconnect the video and audio cables, if a signal board is defective,then you may get no picture on particular inputs located on faultyboard.
If under warranty contact the manufacturer ringing the number on the user manual.
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
Posted on Jul 18, 2009
techman007
  • 1112 Answers
SOURCE: Thmy samsung LN-T3242H - 2 years old - the picture
Hi:
Make sure under your audio options you are in stereo mode and not it SAP, (Special Aided Programing).
Posted on Dec 24, 2009
  • 11 Answers
SOURCE: LN-T1953H picture settings
It all depends on where the set is located. Try looking in the manual. Samsung has them online for free.
Posted on Mar 09, 2010
budmrtn
  • 11361 Answers
SOURCE: Samsung ln-t4042h turns on, plenty of sound, backlight works,...
Check the fuses on the T-CON board and also verify that it does have 12vdc feeding it. If you look at your screen in darkened room you will probably see slight glow on the front of the screen.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Posted on Jul 10, 2010
I have a samsung LN-T3732H television and my picture is solarized. How can I determine if the cause is from a bad T-con board or from the main board or from some other source?
The Tcon is the most likely cause of your problem so try replacing it first. You can get one from Shopjimmy.com or Ebay, just make sure the board numbers match. If the Tcon board doesn't fix it, then replace the main board.
Jul 29, 2016 | Samsung Televison & Video
Samsung LN-S2651D LCD TV no picture
What happens when you turn the TV on? Is there a clicking noise or popping sound?
May 28, 2014 | Samsung LN-T4665F 46 in. LCD Television
Samsung LN-R408D 40 in. no picture
I'm willing to bet you have a backlight problem. Turn on the TV, take bright flashlight and shine it on the screen. Do you see the faint image???
Jul 28, 2012 | Samsung LN-R408D 40 in. LCD HDTV
My Samsung LN-S2651D has sound but no picture
Check with Samsung, this model should still be under the 3 year warranty. You are having a problem with the backlight power supply. You can look on the back of the unit for the manuf. date, if its less than 3 years then go to www.samsung.com and process the online service request form.
I hope this helps,if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
May 20, 2010 | Samsung LN-S2651D 26 in. LCD Television
Turn on sound without picture
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc. Look for 5vdc, 12vdc, and 24dvc.
Parts: http://www.shopjimmy.com/catalogsearch/result/?q=Samsung+LN-S4051D+
Please post back what you find.
Dec 25, 2009 | Samsung LN-S4051D 40 in. LCD Television
Samsung power-up problem
two 2200uF capacitor, two 1000uF capacitors on powersupply board.
Replace it! you will save $300.
Jun 19, 2009 | Samsung LN-T5271F 52 in. LCD Television
Samsung LN-T3732H 37" LCD
T'Con board fault. Check and replace it. If you wish to get some details; visit the site linked here. Pull up older posts.
faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
May 11, 2017 | Samsung LN-R328W 32 in. HD-Ready LCD...
NO sound on HDMI3 port and when playing Blu-Ray DVD's the screen is pink
Go to the samsung website, and find out how to upgrade the firmware for your TV. You will probably need a portable usb memory stick to do so (if your TV is equipped with one). HDMI is an evolving technology, and firmware upgrades can resolve many of these quirky issues.
Here's a possibility from http://www.samsung.com/us/support/faqs/supportFaqList.do?group=&type=&subtype=&model_nm=LN-S4696D&dType=D&mType=UM&vType=R&prd_ia_cd=02010100&acc_ia_fl=&disp_nm=LN-S4696D
Which Samsung LCD TVs Have The HDMI 1.3 Interface? spacer.gif Of the LN-T series Samsung LCD TVs, those models whose last two digits are 61, 65, 66, 69, 71, or 81 (for example, LN-T4071F or LN-T466F) have the HDMI 1.3 interface.
Samsung LCD TVs with HDMI 1.3 interfaces also have HDMI-CEC (HDMI - Consumer Electronics Control). For information about CEC, click HERE.
For information about individual Samsung LCD TVs with HDMI 1.3 interfaces and HDMI-CEC, click HERE. When the Samsung LCD TV web page appears, select the TV model you want information about by clicking the drop down list under Product Finder on the left side of the page.
Though other series of Samsung LCD TVs (LN-R, LN-S, etc.) have HDMI connections, none have models with the HDMI 1.3 interface.
Feb 18, 2008 | Televison & Video
Televison & Video Logo
51 people viewed this question
Henry  Thomas
Henry Thomas
