Question about Technics SL-BD22 Turntable
How to cancel cueing technics
I need advice on how to cancel cueing on a Technics SLQD22 turntable
  • 274 Answers
SOURCE: Drive Belt - Technics SLBD22 turntable
Try http://www.vintage-electronics.net/ttbelt.html
Posted on Jul 16, 2007
  • 7 Answers
SOURCE: turntable technics sl-bd27
You have 4 wires coming from the needle pickup to the cables which connect to the amplifier/receiver. I would check the needle, the pickup unit, and the leads from the pickup to the cables. You can probably run a continuity test or ohm test for verification. If that checks, pickup and needle is your next step.
Posted on Dec 18, 2007
ScottSwan
  • 33 Answers
SOURCE: all my vinyl sounds warped on turntable
Most common problem is the belt getting soft, especially if it has sat for a long time. It will get a weak spot where it sat on the drive pulley and every time the turntable goes around and hits that weak spot it will slow down a little making it sound like a warped album.
The belts are usually very easy to replace. Usually just lift off the turntable or there might be a small clip on the center pin, then it lifts off. Replacement belts can be ordered from several places, as shown in this search... http://www.google.com/search?&q=SL-B200+Technics+turntable+belt
Posted on Feb 17, 2008
SOURCE: Technics SL-23 belt driven turntable (NOT SL-1210 but I had to enter something)
Howdy Ivy:
An Adobe PDF format service manual for the Technics SL-23 turntable can be downloaded from
http://www.servicemanuals.net/
for about $16.
Paul H.
Posted on May 21, 2008
hondo73162
  • 132 Answers
SOURCE: Technics SL-J1 turntable drive belt
Hello Cliff,
You will need 2 belts, if the turntable belt is gone the other is not far behind . One for the turntable size 23.6 inch by .188 and one for the tracking motor that is in the top cover part, is a 3.0 inch by .046 belt. best place to get them is at kenselectronics.com part numbers 1407-201 and AV-SBS3.0 if you have been checking around you will see other sizes, I have a SL-J1 and have used these and they work perfectly.
Tony
Posted on Nov 13, 2009
How do I get the Autocue function to work on the Technics SL-D202 direct drive turntable?
When you say that the auto cue does not function properly,do you mean that the arm will not lift from the rest onto the record or do you mean that the set down point of the arm on the record is not correct? Or does it not work at all?
Jun 29, 2014 | Technics Audio Players & Recorders
Platter stops when back-cueing
? so you take whole the platter with you when back cueing ..... i would buy some good suzuki slipmats and don't stop and spin the platter backwards , that's allways bad and why pushing that hard....
Dec 06, 2013 | Technics SL-1200MK2 Turntable
Tone arm cueing problem on technics sl 1210
The turntable may not be level and consequently beyond the ability of the balance and antiskate adjustments to correct
Jun 26, 2013 | Panasonic Technics SL-1210MK2 Turntable
Technics SL-1700 Mk2, tonearm doesn't lower, cueing doesn't work
There's a rubber belt or O ring that broke. I couldn't find one at Technics, so I took the old parts to the hardware store and found an O ring in plumbing parts that was very close. Been working for years just fine!
Eddie
Jul 16, 2009 | Technics Audio Players & Recorders
Technics 1210 tonearm skates when cueing vinyl backwards
I've seen this on technics turntables before. Try tightening the screw on the arm.
May 20, 2009 | Technics SL-1210 Turntable
Tone arm cueing problem on Technics SL-BD27.
the auto stop mechanism needs adjusting
Apr 07, 2009 | Technics SL-BD22 Turntable
Cueing Problems on Technics SL-1300MK2
Usually the damping fluid is to let the tone arm lower slowly, lifting is usually a mechanical link. Read THIS.
Hope that helps...
Geno
Apr 01, 2008 | Audio Players & Recorders
Technics SL-BD22 Turntable Logo
43 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
