Question about 2004 Mustang Factory Wiring Diagrams
I want to connect a bosch alternator to 1987 opel kadett
    President:
  • 1,702 Answers
Hi, It should work so long as the bracket and belts fit properly. (Alignment of belts).
Posted on Nov 28, 2014
How to remove inner cv joint on a 1988 opel kadette
a round c clip holds the joint in the box. Use a pry bar or short crow bar with flat end wedge it between the joint and gearbox casing to pry it out. Or if the cv joint casing has a ridge on it rest the pry bar securely against it and hammer the pry bar to pop it out.
Aug 11, 2016 | 1988 Opel Kadett
Opel kadett 1995 engin light comes on but goes off afte some time
Go to your local parts house. They have a free service to hook up to the access cable and read the code that is causing the problem. That needs to be attended to as it more than likely will cause failure creating a bigger problem. They can tell you how to fix it as well. Some even will print it out or you.
Feb 13, 2015 | 1995 Opel Kadett 200is
I have a opel kadett 1.8 lt 1987model have no power from coil to spark plugs and looking for a wiring diagram for the opel kadett
the coil most likely blown get a new one and then try testing if will start ,is very problematic and time consuming when a new part like this is going to be a few dollars, then take it from there keep me posted if you wish
Oct 20, 2014 | Cars & Trucks
Replace ignition lock cylinder
Hi Alex, The ignition assembly is mounted onto the steering column with blind bolts. These are special bolts designed in such a way that the heads break off when tightened to the correct torque. We usually remove them with a cold chisel and hammer. An alternative is to cut a slot into which a screw driver can be fitted. Regards John
Jul 16, 2014 | 1995 Opel Kadett 200is
Want a wiring daigram on fan of opel kadette 1993 model
Buy a copy of the "Vauxhall TIS" dvd from eBay. These have wiring diagrams for all Opel cars
Apr 28, 2014 | 1995 Opel Kadett 200is
How can I take off the engine light when removing the air filter plug and then connecting
disconnect the battery for more then 5min, or with the fault code reset tool. all opel dealers have 1.
Jun 18, 2013 | 1995 Opel Kadett 200is
Opel kadette repairs
Check the tank vent hoses on the filler pipe in the wheel arch, if the show hair cracks replace the lot up and down the tank, very common problem with the Kadett.
Jun 04, 2013 | Opel Cars & Trucks
1996 Opel Kadett/Astra 200i no power to ignition coil
do you have coil trigger on either wire to the coil? if so then apply 12 volts to the other wire to see if car will start.
May 23, 2012 | Opel Kadett Cars & Trucks
Do you recommend bosch super 4 spark plugs for a 1999 opel kadett 200iS 8 valve?
Absolutely not
You always use, only what came with the vehicle,
when it was new
Those 4 prong & E3 type plugs, will not work
in some vehicles,especially those with COP
Individual Coils
May 21, 2012 | Cars & Trucks
Torque setting on Opel kadett gsi back wheel bearings
Not even sure who makes those cars but this should hopefully help you
http://vsmus-origin.skf.com/Files/Brochures_in_PDF/457377.pdf
Please take a moment to rate this solution.. thanks
Jan 27, 2009 | 2005 Audi A3
2004 Mustang Factory Wiring Diagrams Logo
52 people viewed this question
Top Ford Vehicle Parts & Accessories Experts
xxxxxx xxx
Thomas Perkins
Thomas Perkins
Colin Stickland
Colin Stickland
Are you a Ford Vehicle Part and Accessory Expert? Answer questions, earn points and help others
