Question about Shuttle AV49PN VIA PT800 Socket 478 ATX MB w/SATA (AV49PN322) Motherboard
Usb won't recognize
No drivers
Computer won't recognize external usb hard drive
Format drive NTFS sounds like its corrupt, use mini partition wizard...
may also need 3TB Unlocker from manufacturer of Hdd
Dec 27, 2012 | Toshiba HDWC130XK3J1 Hard Drive - Canvio 3...
Iomega floppy usb-powered external floppy drive on windows 8
Hi, Sounds like driver related problem to me. Try use this tool to update the drivers: Driver Update Software for XP Vista 7 8. Wish you best of luck.
Nov 30, 2012 | Iomega Floppy USB-Powered External Floppy...
My computer won't recognise my USB cable (code 43 error)
Its maybe the printer is not compatible with your computer, will to try several steps to determine a solution,
1 try another USB to see if it recognizes it,
2 download and install the driver from the printer manufacturer
3 try another USB device into the same USB port to see if it recognizes it if it does then the USB on your computer works as it should,
if it does then the fault is either software or the printer compatibility.
4 follow step 2 if the problem persist then the answer is your printer is not compatible and will need to order one that works for your system.
Kronoguy
Aug 18, 2012 | Computers & Internet
It won't recognize USB ports
Please check this, Go to My Computer and right click. Select manage from the menu. Select device manager on the left hand side and see if there are any ! of any kind that may show missing drivers. If this is the case you may need to go to HP's website and download drivers for your hp mini.
Mar 16, 2012 | HP Mini 1000 Vivienne Tam Edition
Computer won't recognize my vivitar vivicam 25
First install u r digital hd video camera driver and then camera software then your pc will recognise your camera and connect with cable usb.
Feb 06, 2012 | Vivitar ViviCam 25 Digital Camera
I just connected the dvd drive to my mac desktop and it won't recognize the dvd player/recorder. cd that comes with drive says it is for windows only
If its usb connection u need the drivers....if its internal make sure the dvd Rom is MAC compatable if it is you might need the drivers
Sep 15, 2011 | Computers & Internet
Im running win7, and it does not recognize this device which is a usb hub 4 port
A lot of times it won't recognize these devices until you plug something into them. Have you tried plugging in a flash drive, printer, etc to see if it's recognizing it but not showing it?
Jul 19, 2011 | Eforcity 4Port Octopus USB 20 Hub Black
My Sansa M250 is only 1 month old and won't recognize Music folders now when I plug it in. My PC does recognize the device but now it only shows Audible, Config and Record. Before it showed playlist,...
reset the device to factory defaults thats it....
check your usb ports are working properly in not i recommend to re instal the usb device drivers also
Jun 27, 2011 | SanDisk Sansa m250 MP3 Player
I can't access my drive, even though all my tests say it's fine.
Right click on my computer and click manage then click on disk management. Find your drive and give it a drive letter. It probably just needs a drive letter so you can recognize it in my computer,,,Good Luck and let me know if this works...Darren
Oct 11, 2009 | Verbatim 500GB USB Desktop 500 GB Hard...
Shuttle AV49PN VIA PT800 Socket 478 ATX MB w/SATA (AV49PN322) Motherboard Logo
14 people viewed this question
Top Shuttle Computers & Internet Experts
Iqbal Husain
Iqbal Husain
David
David
Alun Cox
Are you a Shuttle Computer and Internet Expert? Answer questions, earn points and help others
