Question about Alba LDVD1538WDCH LCD TV
My picture is like a colour negitive
The tv was working ok then the picture was like a colour negitive.We haveva extension from our sky box andd the picture is perfect.then when we put it on terestial it does this.
  • 74 Answers
Solarisation of screen most likely screen failure or ldvs card on top rear of screen replacement required
Posted on May 24, 2014
Proline LVD TV and DVD player problem. Hi, I can't get a picture using the RF option. I'm not sure what input I should select for this but I've tried them all and no joy in seeing the sky picture from the...
Hi Greg, i think your missing something simple.
Pick a channel number you want the Sky on, then in the tv set up
manually tune that channel to 68, or if it's showing lots of numbers for the frequency then just search towards the end and it should pick up. On the Sky box leave a menu showing so it's easier to spot when it gets to picking it up.
Nov 10, 2014 | Televison & Video
Why does the picture do this. Press sky on remote and all colours seem to b wrong but when tv button is pressed the pic is fine but not hd
If you are getting your video picture (t.v) through a cable box, satellite dish etc. you will have to adjust the internal settings of that box to match the HD settings of the T.V. as well.
Nov 27, 2013 | Televison & Video
Have sound and a black / white picture ? through our sky box
change the output to pal or ntsc on the sky box, then it should display in colour. If that doesnt work change the input on the tv to pal or ntsc.
Apr 17, 2011 | NEC 60XP10 TV
EasyCap - ''no input signal or signal is unclear'' Please Help!!!
In the ULead VideoStudio Application. Go to "Capture" tabbed panel. Select "Options" then "Video and Audio Capture Property Settings...". A window should pop up.
In the "Source" tabbed panel. Change the "Input Source" drop down menu to either "Video Composite" or "Video S-Video" depending on whether you are using the yellow or S-Video picture lead.
Change the "TV System" combo-box to PAL for colour and NTSC for black and white. On my computer S-Video option is showing black and white when using my Sky HD box, don't know why this is yet.
Try the above and you should get a picture. You can also change the frame rate and other compression techniques etc.
If it still doesn't work try changing your digital/sky/vcr/xbox picture settings to PAL for colour or others for picture preference.
Hope this helps.
Goodluck
OAC
Mar 06, 2010 | Ulead Videostudio 8 for PC
How do i set up my plasma tv just to watch sky on the tv i was given a tv pioneer pdp-42mve1 and have got the power lead and a lead with a scart and 6 push in leads coluers are green blue blackyellow red...
Hello Paul,
all you need to do is plug the power in, put the scart lead into the back of your Pioneer tv, the other end of your scart into the bottom scart of your sky box named TV.
you will also need to connect the sky cable to the box to receive your signal. its a F type connector ie it screws on.
The other cable you have with the 6 push in coloured leads they are Component cable and the red and white ones are Audio cables. You will not need these cable unless your sky box is a HD box then i would suggest you get a HDMI cable instead of using component (less cables showing) dont be fooled into buying gold plated HDMI cables as they do not make any difference to the picture Quality as the back of the sky box is alley and so is the telly. So please dont waste your money on that type of cable.
Hope this Helps
Little Dish Fitter.
Sep 02, 2009 | Fujitsu Plasmavision PDS-4222 42 in....
Sky+ DVD Recorder Tuning
You need to connect up the Sky+ to your recorder via scart. This will eliminate poor picture quality. The Sky box will be on ext1 on your recorder or something like that
Oct 12, 2008 | Televison & Video
Black/Green Distortion - Picture Quality - Wharfedale
This is no solution but a point in a probable direction.
A tech guy told me ALL the LCDs they have seen in their repair shop have "swollen" capacitors, this is due to voltage instability. Lowering the internal voltage regulator and replacing the swollen capacitors (which eliminate noise) apparently restores the LCD to new working quality. Without actually "seeing" my problem the tech said that should repair it. I have not tried this yet but eventually will begin that way.
Mar 11, 2008 | Televison & Video
Samsung LE32R7 Picture Flashing
You need to get your sky box changed! just ring them up and tell them your problem. the TV is a known issue with certain boxes.
Feb 14, 2008 | Televison & Video
Ratio
Does the sky box have a setting for output ratio? If so try adjusting it and see what the TV does.
Jun 08, 2007 | Polaroid FLM-2632 Television
Polaroid FLU-2632
I had the same problem. It's caused by the picture setting on your Sky box. Go ibto Services, select Picture Settings and set the mode to PAL not RGB.
Jun 07, 2007 | Polaroid FLM-2632 Television
Alba LDVD1538WDCH LCD TV Logo
55 people viewed this question
Top Alba Televison & Video Experts
Rod
Rod
Robert Crombie
Robert Crombie
Level 1 Expert
Are you an Alba Televison and Video Expert? Answer questions, earn points and help others
