Question about Acer Computers & Internet
Acer p206hl BD version May 2013 My monitor started to show a black bubble (2x2") at the bottom, a few weeks ago. It has now grown across screen and is 2.5" wide. What is the problem and can it be fixed?
sandrew
  • 2961 Answers
SOURCE: Monitor goes blurry, colours/pixels start shaking across screen
Do you have your screen saver enabled, i so turn it off and se if it still does it. Secondly boot your pc in safe mode(pressing F8) on boot up and select start windows in safe mode. See if the monitor still does it, if so a monitor fault or loose/faulty vga lead. If it is ok then your graphics driver may be corrupt and need re installing.
Posted on Dec 30, 2006
SOURCE: HP mx705 17 in.CRT Conventional Monitor vertical goes bad
it seems that youre monitor has a dry solder problem, try tapping it if the picture resumes to normal for a while than get it resoldered from a technician. if it soesnot solve problem than look out for a burnt resistance.
Posted on Jun 26, 2007
SOURCE: Blurry vertical lines
Try changing the monitors refresh rate setting. I had this same problem and fiddled about with the display setting - I found that my monitor had blurry strips across it and the desktop didn't fit the monitor until I changed the refresh rate to 75hz
Posted on Jul 15, 2008
SOURCE: monitor black screen
I experienced a similar problem with my MAG LT776s. As a "band-aid" fix, I have found that if I turn the monitor brightness to near zero my problem is minimized. Meaning - the monitor goes on after a little wait (~ 20 sec) and will stay on.
The trick is to turn the brightness down when the monitor is black and you cannot see the screen menu. In my case I:
- turned the power off and then back on again. This allowed the monitor to be on for about a second when I can press Menu and see that the manu had actually come on.
- the menu will start in the brightness setting. Even if the monitor had gone off by now, press menu again to enter into the brightness setting.
- press Down button many times to ensure the brightness is down all the way or nearly all the way since you will not be able to see the setting now that the monitor is off.
- press Menu button again to leave the setting menu.
- Turn off, then back on again.
- worked for me - monitor came on and stays on.
Posted on Jul 30, 2008
Fix-4U
  • 293 Answers
SOURCE: monitor stops display
Hi...there,
It's seems your LCD Monitor backlight inverter it burnt out. Need a new inverter. Have a nice day!
Posted on Sep 08, 2008
I have a 40" Toshiba
Any kind of black or colors lines on the tv LCD screen panel,not causes by u it appear by itself only can be repair by replacing the board that call the T-CON board.This T-CON board sit in the middle at the bottom of the tv LCD screen panel.Tries websites like Shopjimmy.com,Ebay.com to buy the refurbish T-CON board for the replacement.
Jun 24, 2011 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Good day, I have an Acer AL2423W monitor. When I turn it on, for the first few minutes all I get are vertical coloured lines. After a few more minutes the screen images start to become visible, but...
Hi Friend, In this case what I would recommend you is to connect any external monitor to the system to check if you have the same issue with the external monitor as well or not.
If yes, then it might be the issue with the video card so, you can try updating the video drivers for the system.
If no, it means that the original monitor has some issues with itself..
Also what I would recommend is try to lessen the screen resolution instead of 1920 x 1200 to lower resolution and restart the system and check if it makes any difference..
Also update the video drivers for the system.
Jan 04, 2011 | Acer AL2423W LCD Monitor
My acer monitor was working fine when I turn it off in the evening. in the morning my monitor color had gray mix with black patches and the line have dots and also some areas the dot form crosses with dots...
on your desktop screen, right click mouse, go to properties then settings and change the colour or resolution settings there, apply and save and that should be you sorted. Hope this helps ;)
Mar 18, 2010 | Acer Computers & Internet
I have more and more tiny bright blue dots
hello it may be the light engine that's faulty
shaun
Sep 19, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Monitor often will not power up when power button is pushed. Disconnecting power for 90 seconds corrects problem. This is an intermittent problem that is occuring more frequently over time. Condition...
I think there is a problem in Monitor's Power Supply unit which integrated in the base board of Monitor. If u expertise with the service then carry on. else Pl contact a Local Service professional to solve the problem
Aug 23, 2009 | Computers & Internet
Acer lcd monitor ''no signal''
It is screen resolution problem.
when you power up the computer press F8 key thene nter in enable vga mode then go to diaply property and set screnn resolution to 1024*768 thenh apply and ok.
Jul 12, 2009 | Acer AL1916W 19" LCD Monitor
Picture problems with the Sanyo Vizon 42" Plasma TV
can you contact Sanyo tech department and ask them, it maybe as simple as a menu button got switched.
Oct 03, 2017 | Televison & Video
Horizontal lines on Screen
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Feb 14, 2008 | Gateway FPD2275W LCD Monitor
Black screen on Acer 5100, but will work with external monitor
It sounds like the control board or cable for the LCD may be damaged. If you're still under warranty, you'll need to send it back to Acer to be repaired.
Feb 13, 2008 | Acer Aspire 5100 Notebook
Computers & Internet Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
