Question about Janome 6019QC Mechanical Sewing Machine
How do i insert my bobbin case into my janome sr100
  • Janome Master
  • 1,388 Answers
Posted on Apr 22, 2014
mallow1
  • 35 Answers
SOURCE: jI have a Janome 1100,
When you put in the bobbin case, be sure to press it in firmly until you hear it click into place. If you can't press very firmly, or are afraid of hurting your machine, simply lift the latch from the bobbin case, holding it open while you firmly insert the case into the machine. Then release the latch. You should be good to go. Hope this helps!
Posted on Aug 16, 2008
  • 5 Answers
SOURCE: Bobbin problems
Are you using a size "A" (Class 15) bobbin? If you are using pre-wounds and they are not this size... they will jump around alot. The size of an "L" is very similar, but they are not as tall (height off the table when laying flat on the round side... like when sitting in the bobbin case.) There are tricks to using the thinner bobbins... See if you have a "taller" size "A"/Class 15 and if that corrects the trouble. tjsews2008@gmail.com
Posted on Mar 02, 2009
Mongo32
  • 111 Answers
SOURCE: inserting bobbin
needle's in backwards
Posted on Jun 01, 2009
Tally Girl
  • 1122 Answers
SOURCE: janome 6500 jamming - cleaned out bobbin case - no
Have you removed the bobbin holder and then put it back in lining up the little red markings on the right hand side? If the case has moved slightly then it will keep jamming and the bobbin thread won't clear to form a stitch. The case is held in place by a magnet and a stopper but it will dislodge if you have a bad thread jam, then it keeps happening even if you have removed all the thread because its not in position.
Check this solution for image how to remove and replace the bobbin case. http://www.fixya.com/support/t9289728-bobbin_seems
When you take out the bobbin case, carefully inspect it for any damage and burrs in the black plastic, if there are any then file them carefully out with a nail file or fine sandpaper, a burr will keep catching thread too. Or you may actually need to replace the bobbin holder if it has been pierced by the needle badly, they are about $35 or so.
You may also want to get it serviced. On my 6500 during its last service the technician added a little piece that is a Janome "after sale replacement" part. It is slightly longer than the standard part, and is a little metal bit on the left hand side of the rotary hook area which is holding the bobbin holder in place better. Haven't had a major jam up since this was fitted so you may want to get this fitted on yours too.
Posted on Jul 19, 2011
baughhouse2
SOURCE: Janome MC11000 - my bobbin case becomes dislodged
My bobbin case was jumping all the time...had it in for repairs and would bring it home and even though the tech had attached a test sew piece with different colored bobbin and top thread I could not get it to sew without the bobbin jumping. I thought that he had lied about that being sewn on this machine...finally, I found that you should start with plenty of thread in your hand when threading machine...so that once you feel it click into the tension...DO NOT PULL the thread, it pops it out of the tensioner...just loosely thread and hold tension with your thumb and forefinger while using the needle threader.
Posted on Dec 05, 2012
My Janome harmony sewing machine is totally jammed
1. Try to take out the needle. If this doesn't work take out the bobbin carefully so you don't get stuck by the needle. Also remove the bobbin case. (thing that the bobbin sets in)
2. Once you have the two out try to turn the hand wheel. It should turn.
3. Replace the needle. Clean the bobbin area thoroughly. Oil the race where the bobbin case rides. One drop is all it needs.
4. With the needle inserted and no bobbin inserted turn the hand wheel.
5. If it turns ok then insert the bobbin case and bobbin.
6. Does it turn? If it is a problem turning then you will need to get it timed from a maintenance person.
Nov 13, 2016 | Janome Sewing Machines
The bobbin won't stay in the case. How might I fix it?
The bobbin case needs to be "latched" into place. Bobbin cases have a spring-loaded latch that needs to be open when the bobbin case is inserted, but when it is seated, the latch is released, thus locking it in place.
How to Set Up Sewing Machine
Inserting the Janome Front Loading Bobbin Case
Apr 18, 2016 | Sewing Machines
Bobbin shuttle fell out
About 8,950 results (0.69 seconds) Search Results
    Inserting the Janome Front Loading Bobbin Case - YouTube
    ? 1:46
    https://www.youtube.com/watch?v=Mz7-k4G9HFg
    May 8, 2013 - Uploaded by Janome Canada
    Learn how to insert a front loading bobbin case. It's easier than you might imagine. Janome ... Janome HD-1000, Beginnersewing machine.
    How Do I Fix My Sewing Machine: Troubleshooting Your ...
    www.craftsy.com > Blog Home > Sewing Blog
    Nov 7, 2014 - Well, I've been teaching on Janome machines for about 6 years, and I ...Take the Trouble Out of Sewing Machine Troubleshooting! ... has fallen out of the take-up lever, which can happen if the machine was jammed along the way. ... of thread through the bobbin winding tension at the top of the machine.
    Bobbin Case Keeps Falling Out of a Sewing Machine ...
    www.thriftyfun.com/Bobbin-Case-Keeps-Falling-Out-of-a-Sewing-Mach...
Feb 09, 2016 | Janome Hd1000 Sewing Machine
How can I open the Janome Sewing Pretty with Hello Kitty machine to put in bobbin?
There is a removable tray on the front. Pull it to the left. This will expose the bobbin door. Lift the clip on the bobbin case to remove and replace it on the hook.
Mar 05, 2015 | Janome Hello Kitty 11706 Mechanical Sewing...
I have a Janome mc 6500 and the bobbin thread keeps getting stuck around the feed dogs?
try changing the needle
clean under the needle plate area for lint or threads
try rethreading the bobbin,making sure the bobbin is inserted correctly into the bobbin case.
May 16, 2012 | Janome Sewing Machines
The bobbin (or bobbin case) rattles while sewing.
Do you have the right size bobbin inserted? Is the case inserted correctly? If these are not the problem, I would call Janome and find out what is causing this if it has just started.
Jan 03, 2011 | Janome Memory Craft 9000 Computerized...
My Janome one step is jamming on the first stich under the foot. I think it is the bobbin holder that has moved as it now comes out easily but do not know how to put it back in so it is secure
Raise the needle to it's highest position and this will position the shuttle so it is the correct position for the bobbin case to be inserted.
If this is a drop-in bobbin, the line-up is easy to see. Refer to the maintenance section of your manual.
If this is a rotary bobbin, make sure to hold the lever on the back of the bobbin case out as you insert it into the shuttle. The "arm" on the bobbin case points up.
May 01, 2010 | Janome Sew Precise Mechanical Sewing...
How do I adjust the bobbin stitch on my sewing machine janome ms 2522
If the stitching is loose on the bottom, it is not the bobbin that needs adjusting.
Always thread the machine with the presser foot up and this will be eliminated.
Check your manual to be sure the bobbin is inserted into the bobbin case correctly.
Mar 14, 2010 | Janome Sewing Machines
JI have a Janome 1100, and I have a problem with the bobbin case. I will be into my embroidery project and the bobbin case will jump and turn around sometimes causing my project to turn, and the needle to...
Jun 22, 2008 | Janome D'cor Excel 5018
Janome 6019QC Mechanical Sewing Machine Logo
22 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
