Question about Dryers
Replacing light bulb on dryer
Light bulb is burned out - where is it located and how do I access it to replace it myself
  • 4 more comments
  • Burse Oct 27, 2007
    Maytag Model LDE612
  • Anonymous Dec 24, 2007
    The light bulb in side my dryer Bosch WTA 3510 burned out.
    Hoe do I change it ?
  • Oinkster May 28, 2008
    Donot have two screws on either side of front panel?? Not one screww either..
  • Steve258 Sep 20, 2008
    My dryer is a Siemens WT6608VGB
    Same problem, can't see how to get to the bulb.
  • AskQ Dec 24, 2008
    Maytag gas dryer Model DG710
    Got bulb unscrewed but can't get it out of opening.
  • lance995 Jan 29, 2009
    What type of bulb can I put in the tumble dryer? I am just thinking about the temperature in there, will an oven bulb do?
Light is located just above the door on the inside of the drum. It has a clear plastic lens on it. The lens has a hinge on the top and a retention feature on the bottom. You can see all of this with a mirror. Simply push the button up and the lens will swing up. You can then access the light bulb.
Posted on Oct 01, 2009
I wanted to replace the light bulb in the Dryer. Accidently the bulb fell in the Unit. Now how can i get it out??
Posted on Aug 15, 2011
Check for two screws down the bottom right and left sides of your dryer (on the front section). Remove teh screws, and remove the front panel by lifting up and out. Watch your fingers since the front will pop off when you get it up far enough. Don't let the front drop, there are wires attached to your start switch (on the inside of the door). You should be able to se the bulb at that point and change the bulb out. One thing you may also want to do is clean out the dryer of lint and other items that may pose a fire hazard when you have that front door open!
Good LUck
Posted on Nov 07, 2007
Dryer light bulb burned out
follow this steps and fix it. God bless you
Light Socket
The light socket can get corroded or a wire connection can come loose. You will need to remove the front panel to access the housing on most dryers.
Door Switch
If your dryer has an interior light, it probably uses a standard 40-watt appliance bulb, but check your owner's manual to be sure. If the bulb is good but the light won't come on, check the door switch, which serves two functions: When the door is closed, it turns off the light and allows the dryer to start. When the door is open, it turns on the light and prevents the dryer from starting. To check the door switch check for continuity. You should have some when the door is closed and none when the door is opened.If not replace the door switch by removing the front panel.
It blows fuses or trips the circuit breaker
Electric dryers use 220 volts or two power lines of 110 volts each. Some components in the dryer need only 110 volts; the heating element requires 220 volts. So it's possible for one part of the dryer to be fine and another part to have a short circuit. Short circuits can be caused by the heating element, the main power cord, or any other part of the internal wiring. Loose connections on the power cord cause failures and or fires. This can be checked with the dryer unplugged and removing the service cover and visually check for burning and mechanically check for tightness.
If the circuit breaker trips or the fuse blows when the dryer is unplugged, it's likely the problem is with the house wiring, fuse box, or circuit box. Contact a qualified electrician.
Jul 09, 2013 | GE Profile Harmony DPGT750EC Electric...
Replacing light bulbs?
Replace the burned-out bulb with a 120 volt, 30-watt incandescent bulb (WB36X10198), available from your GE supplier
  • 1 To replace the oven light,
first disconnect the power at the main fuse or circuit breaker panel or pull the plug.
  • 2 Remove the top grille by
taking out the 2 screws that hold it in place.
  • 3 Remove the charcoal
filter (if present) to access the light cover (see Remove Charcoal Filter section).
  • 4 Remove the light cover
located near the center of the oven that holds the bulb. Remove the bulb by gently turning. Replace with the same size and type bulb.
  • 5 Replace the light cover
and charcoal filter (if present).
  • 6 Replace the grille and
screws. Connect electrical power to the oven.
The full owners manual can be found here: http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-40474.pdf
Mar 07, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
I can not figure out how to get into the rear light bulbs (Stop light, etc). The manual says to remove two (phillips) screws to disengage the housing from the body. There's even a a picture. However, on...
To access the rear lights, you access them from inside the trunk. Pull down the carpet at rear of trunk near latch. There should be the screws the manual is referring to. Once you locate and remove all screws, gently pull the light assembly away from body. Replace the needed bulbs then gently push assembly against the body, replace the screws and set carpet back in place.
Nov 14, 2010 | 1995 Toyota Camry
Whirlpool Dryer 3.5 years old has power but will not turn on. Not a breaker problem. has electricity. Drum turns by hand. No noise is heard.
we had a very similar problem on our DLE3777W LG clothes dryer. It would power up normally, all drying options and speed and heat selections behaved normally but when you tried to start the dryer the start button and the time remaining indicator would flash until the unit was turned off. Called LG and Best Buy and they could only tell us to contact a repair shop. But I realized that the light was burned out inside, so I replaced it myself to avoid being charged by the technician I was about to call. The burned out light bulb WAS the problem, as soon as it was replaced the dryer worked perfectly. I think I saved a couple of hundred dollars with a $4 light bulb. I would have been mad to have the technician show up and charge me $120 just to show up, then an hourly rate and then the bulb.
Jun 26, 2010 | Whirlpool WED5800S Electric Dryer
Replacing brake light on a subaru outback limited wagon 2000
How To Install Replace Change Taillight and Bulb 2000-04 Subaru Outback
Apr 07, 2010 | 2000 Subaru Outback
Please tell me how to replace a burned out head light, high beam.
To replace the headlamp, turn signal, or parking lamp bulb:This information should be in your owner's manual.
Turn the wheel to access the wheel well.
  1. Remove the fasteners located on the wheel liner. To access the headlamp and the turn signal/parking lamp bulbs.
  2. Reach in behind the wheel well liner and locate the bulb to be changed.
  3. Turn the bulb socket counterclockwise and pull it straight out of the lamp assembly.
  4. Pull the old bulb straight out of the bulb socket.
  5. Push the new bulb straight into the bulb socket until it clicks.
  6. Push the bulb socket straight into the lamp assembly and turn it clockwise to lock it into place.
  7. Reinstall the wheel well liner using fasteners.
Nov 11, 2009 | 2006 Chevrolet HHR
Replacing burned out backup light on 2004 acura mdx
This can be done by yourself no need to pay a mechanic 30 dollars an hour to do it ....Just twist the connector out of the back of the light housing and replace the bulb but dont touch the bulb itself just touch the metal or use gloves the natural oil from your hands can cause the bulb to burn out again. If this helped please vote fare
Nov 04, 2009 | 2004 Acura MDX
My 2002 Troy Bilt 18 hp garden tractor has a voltage spike which burns out the light headlight bulbs. Actually, we received this tractor as a donation for sale at a charity auction. It needed a few repairs...
Locate and replace the voltage rectifier this is a voltage limiter than can go bad, trace the wire that comes out of the motor's shroud it should go to a small box that then has a wire that leads to the battery this small box will be the voltage regulator or rectifier they are similar devices, replacing this box should solve the problem however before replacing the light bulbs again after replacing the regulator or rectifier hook up a voltage regulator to the positive terminal of the battery while the tractor is running at a high rpm or engine speed, if the voltage reads higher than 14 volts the light bulbs will burn out again but this is a simplistic electrical system and the voltage rectifier or regulator restricts the voltage from exceeding 14 volts so replacing it should do the trick.
Oct 21, 2009 | Garden
Interior light
No. If you see that the bulb was burned, you can replace it yourself, you dont need to take off the battery terminal since taking it off might cause more trouble to your car. dont worry you cant be electrocuted by a 12V dc by just replacing the bulb
Oct 20, 2008 | 2004 Toyota Corolla
Dryers Logo
4,967 people viewed this question
Top Dryers Experts
Marvin
Marvin
