Question about Electrolux EIED55H Dryer
How do i take apart the electrolux dryer to repace the heating element
2 Suggested Answers
inaniae
SOURCE: Electrolux Dryer quit and has a code E 63
Mark, the heating element is underneath the drum, on the left (as facing the front of the unit).
Per the Dryer Tech Data Sheet:
E63 Error Code indicates: [Fault] Heater to Earth Ground [Possible Fault Conditions] Heating element or wiring defective [Possible Solutions] Check heater coils and connections for short circuits to the cabinet. Replace heater and/or wiring and retest.
To open the cabinet is quite difficult, speaking as a non-professional. There may be easier methods than what I used, but I was successful. First I removed all the screws from the back (there are many). This got the top and the back panels removed. The left side (where I could see the heating element was) gave me considerable trouble until I realized I had to remove the door trim to reveal one last screw. Finally got the side off and swapped out the heater. Much much vacuuming for me. I am still trying to figure out how to clean out the bottom of the duct (underneath lint filter), but that's another post.
Also, just in case you don't have the manual and/or need to order parts, I will include a link.
http://www.searspartsdirect.com/partsdirect/part-model/Electrolux-Parts/Dryer-Parts/model-EIED55HIW0/1412/0151200
For some reason, the Sears Parts Direct website lists the dryer as a Gas dryer, which it obviously isn't, as the part in question is very clearly an electric heating element. Hope this helps.
-Nick
Posted on Mar 04, 2014
Kenmore heavy duty plus dryer modle number 886573130 works fine just stopped heating up.
Gas dryer no heat means the heating element broke or fell apart, need to install new one, go to sears hardware and order a repacement....model # in hand.
Feb 22, 2015 | Kenmore Dryers
How do I repace heating element on a electrolux model eied55hiw?
remove top and front and remove drum they are behind the drum. some of the newer models have the element in a tube going into the tub.
Jan 03, 2015 | Electrolux Dryers
Why is 6kg Electrolux Dryer EDV605 not heating
No heat can be several things, first check the voltage to the dryer.
You need 240 volts ac for it to heat. Just because it tumbles isn't proof of the correct line voltage. The heating element could be open, the high temperature fuse could be open. door switch could be bad, heat relay on main board could be bad. If you have a meter there is a schematic or wiring diagram in the dryer somewhere. Make sure you UNPLUG the dryer before taking it apart. Use a meter to check heating circuits. If you do not know how to check continuity, you will need an appliance repairman.
Sep 01, 2014 | Dryers
-Nick
Mar 03, 2014 | Electrolux EIED55H Dryer
Electrolux
Hello Curtis - Typically, error code E61 indicates a Heater Relay failure. At first the heater was grounded, and now possibly the heater relay. When the heater grounded it could have shorted the relay as well. Generally it is a good idea to have a professional take a look at it to get to the root cause. Cost of parts and technical expertise entailed in these types of replacements can be a bit tricky.
May 01, 2013 | Frigidaire Electric Dryer
HOW DO I CHANGE HEATING ELEMENT ON MY ELECTROLUX DRYER?
You might try this step by step process. It is not for Electrolux, but the process should be similar. Changing the Heating Element
Apr 08, 2013 | Electrolux EIED55HMB Electric Front Load...
How do i change the heating element in my dryer
it's way to hard afor a lay person,call for repair-mike
Jun 19, 2009 | Kenmore 62602 Electric Dryer
No heat in dryer
Make sure all the wires were replaced correctly and check the circuit breaker two control an electric dryer one for go one for heat. if all the wires were not replaced correctly you may have tripped one or it may have caused the prolem without tripping one . I'd start with the wires.
Jan 11, 2009 | GE Dryers
Electrolux EIED55H Dryer Logo
16 people viewed this question
Top Electrolux Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
John
Are you an Electrolux Dryer Expert? Answer questions, earn points and help others
