I am having problems locating my security key on my lap top to enable wifi on my tv
    Novelist:
    Scholar:
  • 131 Answers
The security key you need to enable wifi on your tv is not in your pc but in your wireless router. Your wireless router serves as a "hub" for your network and controls access to your wireless network. However, you can access your wireless router from your PC by doing the following:
Open a DOS Window (just put "cmd" into a search and look for command prompt). Once you get a DOS prompt open, type the following "ipconfig" (without the quotes since they are there only to tell you what to type) and press the enter key. You may have to scroll up and down in the window but somewhere near the top you will find some IP address, Subnet and Gateway, each followed by some numbers. The Gateway number is what you want. Write it down. It has 4 parts with periods between each part. Example 192.168.1.1 (this is a very common one so don't be surprised if it's what you see). Once you write this down you can close the window. Now open any browser and put these numbers into the address bar. If you are connected to the Internet a box will pop up asking you to log in. Here you put in the user name (usually "admin") and the password (which may be on the router as some kind of ID number or which may have been given to you when the router was set up). After you log in go to the wireless section and either reset the password (i.e. wireless security key) or see what it is. Do write it down and you should get your TV hooked up in no time.
Good luck with this.
Posted on May 29, 2014
5 Suggested Answers
SOURCE: Problem with my Dell vosro 1510 wireless
RESTART THE COMPUTER IN SAFE MODE AND ACTIVE THE LINE CARD
Posted on Apr 23, 2009
trikha_karan
  • 66 Answers
SOURCE: Acer Aspire 5100 won't connect to secure Verizon Mifi 2200
Delete the previous wireless connection than changed the key in router and than try to connect.
Posted on Jul 29, 2009
Mike258
  • 1498 Answers
SOURCE: I used The FN and F5 key and it worked
Hi Trump,
What you are experiencing is the resolution settings of one device being used on the other.
Right click on the desk top
Click properties
Click the settings Tab
On the lower left increase the screen resolution (only a little at a time)
If you can read the screen that comes up, click OK.
If you can't, DO NOTHING. The original screen will return in 15 seconds
Click apply or OK
Hope this helps
Mike
Posted on Sep 07, 2009
rcw1962
  • 2571 Answers
SOURCE: my acer lap top is asking me for my security key
You will find it in the routers settings.
If it is asking for YOUR security key, you must have set one when you first installed the router.
Log on to your router / wireless / security
And check what the passord is..... OR
you can use free software to recover your wireless key if you have ever used the key on that computer http://www.nirsoft.net/utils/wireless_key.html
Posted on Aug 04, 2010
I m unable to connect wifi for my samsung 65 led tv
Does the TV have WiFi enabled? Is it in range of your WiFi router? Is the place where the TV is located a WiFi dead spot? Does the TV see your WiFi router, and is it the strongest signal in the TV's locality? Are your neighbours using the same WiFi channel as you? Have you got the router set to block MAC addresses? Is the TV set to use DHCP? Is the router handing out IP addresses? What security level are you using? Are you putting in the correct WiFi password? The list goes on and on.....
Sep 06, 2014 | Samsung Televison & Video
How to enable wifi
hi , ensure wifi is enabled in BIOS setup , ensure is noted in Device Manager and is enabled , look for any keys denoting wiki or a slide switch located somewhere - and enable
I do not own one of these and there appears no owner's manual, so am guessing
Mar 13, 2014 | Dell Precision M90 Notebook
Im using samsung NP-R540 lap and i recently formatted my computer so than i installed all the drivers but my wifi is not still working why is that
is it enabled?
control panel>network and internet>manage wireless connections click adapter properties and then configure, click the drivers tab and check that it is enabled. there may also be a function key combination on the keyboard: Fn key and one of the F# keys to turn on wifi.
also, check the device manager to make sure the network adapters wifi driver installed correctly.
Mar 10, 2012 | Samsung R540 Laptop
I have just bought a Google Android Tablet 7 inch and we are having trouble connecting WIFI. We've connected a different tablet and my daughters ipod touch with no problems as well as many lap to
True to the above.. also if you have tried to connect several times you may want to delete the saved Wi-Fi connections an start again. Example.. Open Wi-Fi connections and find for network. If you already have it saved, click"forget" then retype your credentials.
Jan 05, 2012 | Google Android
I had to reboot my lap top and now my wifi on it wont work
just click the restart.by clicking start menu/shut down/restart.
to on your WiFi.press the fn key and the WiFi key located on the f keys at the top of the keyboard.some laptop have a lock on the side to open the WiFi.just check your laptop on both side.you don't need to press fn/WiFi key it is having the WiFi lock on the side.
Sep 23, 2011 | Toshiba Computers & Internet
We have lost the product key when we moved home and we are after using a wifi conection with a lap top
Libby,
Do you want a product key to get on to the WiFi at the new location? If so then you need not worry as the person who come to install the new router will ask you what new password you want to use to be able to connect the laptop to the internet.
If the problem is different then please clarify.
Feb 10, 2011 | Computers & Internet
I need to et my user name and logon domain i dont rmember them . i just got my lap top repaired and need to reconnect to my router
Router Login: http://192.168.1.1
Login Name: admin
Login Password: password
>If you've forgotten the Router password, then press the Router Reset button (a small point) located next to the Ethernet port to restore the Router to factory settings.
>Please click on Wireless and click on Security to check the Security key for the Network.
>If the Router is reset to factory settings, then it is required to enable the Wireless feature under Wireless settings and enable the Security key.
Good Luck!!!
Jul 02, 2010 | NetGear WNR2000 Wireless Router
Acquiring network address
all that you need to do is to delete the preferred networks list from the computer,
and try to scan and connect to the network again....make sure that you are typing the correct security key.
still if the problem exixts, then add the network manually...the problem will get off for sure....
also if there is any facility like wi-fi protected security is enabled in the wireless router, go ahead and disable it...
Apr 03, 2010 | Linksys WRT54G2 Wireless Router
Belkin router wifi with i phone and g1 will not connect the lap
this is because of the security type WPA enabled in the router...youo can login to router setup page by typing 192.168.2.1 in the internet explorer...click on security (found in the left side, if it asks for password leave it blank and click submit) and change the security type to wep64bit and type any 10digit number as your password in key1...dont type anything other than that in any other boxes....click on apply changes...
now scan and connect your network from iphone and enter security key and login....
also delete the preferred networks from your laptop and scan and connect again....
rate me if it is useful....
Feb 14, 2010 | Belkin Computers & Internet
Just bought a new lap top have a wireless router on my PC but want to connect to the internet on my new lap top which is wireless enabled, it has picked up the router which is still named as default but...
From your PC (not your laptop):
Click START
Click RUN
Type CMD and press ENTER
Type IPCONFIG and press ENTER
Find the line stating "gateway 192.168.xxx.yyy"
Start Internet Explorer
Type http://192.168.xxx.yyy
Login to your router
Click the "wireless configuration" button
Set a new security-key or passphrase.
Now, try connecting wirelessly from your laptop, using the new security-key or passphrase.
Sep 19, 2009 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
