Question about Garmin nuvi 2455LMT 4.3" GPS Navigator with Lifetime Maps & Traffic Updates
Garmin nuvi 2455lm wont turn off
Do i let the battery drain ? why will it not turn off?
SOURCE: garmin nuvi 350
Heres what to do:
- Connect to computer using USB cable
- Flip up antenna and hit reset button.
- The unit should power up.
- Then put unit on wall charge to get a full charge.
That should do it if not call 1-800 800 1020.
Posted on Jan 07, 2008
RixsFixes
  • 2200 Answers
SOURCE: Charging Garmin Nuvi battery for first time
The Garmin Nuvi 855 uses a Lithium-ion battery. It is a very clean system and does not need priming as nickel-based batteries do. The 1st charge is no different to the 5th or the 50th charge.
In other words there is no memory effect with these batteries and it should be safe to charge it for as long as you like on the first charge. I would estimate 4 hours will give you a full charge if you wish to do this from the outset.
Posted on Jun 21, 2009
SOURCE: replace a battery in garmin nuvi 650
Batteries are not replaceable.
Posted on Nov 15, 2009
pabloloco
  • 2335 Answers
SOURCE: My garmin 255w nuvi keep turning off and wont turn on
It is a good idea to perform a hard reset on your Garmin Nuvi after updating the software.
The Hard Reset procedure has been known to delete your Favorites, so back them up beforehand.
  1. From the Nuvi drive, copy '/Garmin/GPX/current.gpx' to a backup location on your computer.
  2. After the hard reset, copy your backed up 'current.gpx' from your computer back to the '/Garmin/GPX/' folder on the Nuvi, but be sure to rename it 'temp.gpx'.
  3. On the next power cycle, the Favorites will be read from 'temp.gpx' into the non-user accessible memory area on the Nuvi where they are actually stored.
Perform the Hard Reset:
*Note that this will clear all user selected settings on the unit
  1. Power the unit off.
  2. Remove the battery and wait several minutes.
  3. Install the battery.
  4. Press and hold (and continue to hold) the bottom-right corner of the screen while powering the unit on.
  5. Continue to hold the screen until the "Do you want to erase all user data?"prompt appears.
  6. Press "yes" and the unit will reboot. This resets all your location settings and user preferences.
Posted on Jan 02, 2010
pabloloco
  • 2335 Answers
SOURCE: Garmin Nuvi 205w and now it wont turn on.
You can restore the Nuvi 205 system software to its factory condition by running Garmin's WebUpdater service. You may also want to try a hard reset of your Nuvi.
I hope that helps.
Posted on Jan 17, 2010
Wont stay on
Have you tried resetting it? My old Garmin started doing this, and resetting helped. You reset it by hold lower right corner while powering on device. Please note that all user data will be gone. This can also happen if device was on for long time and battery was drained to much
Jun 07, 2012 | Garmin Nuvi 660 GPS Receiver
NUVI 2455LM WON'T TURN ON
I use the plug in to the computer and it will work for a while until I have to do it again. 2stars
Feb 23, 2012 | Garmin GPS
My garmin nuvi 770 won't turn on, either on switch or car 12V plug. What can I do now?
Holding the switch does not always work. The problem is that the Garmin batteries wear out very quickly and if you don't charge them every few days they drain completely and the voltage drops to zero. The problem is the brilliant Garmin engineers designed the Nuvi 700s so that the charging circuit doesn't activate when you plug it in if the battHolding the switch does not always work. The problem is that the Garmin batteries wear out very quickly and if you don't charge them every few days they drain completely and the voltage drops to zero. The problem is the brilliant Garmin engineers designed the Nuvi 700s so that the charging circuit doesn't activate when you plug it in if the battery voltage is zero. See the Catch 22? Also, even if you replace the battery, if the new battery is not already charged, you are in the same boat! I solved it by taking the Nuvi apart and zapping the battery with 5 volts across the red and black terminals. It's very difficult because the plug has tiny holes smaller than a typical pin. You have to be very careful too because the lithium polymer battery could catch on fire or explode! I used a very low current to lessen the chance of this. After doing this for about a minute and raising the battery voltage to about 3 volts, I plugged it back in, put it back together, and it was able to charge.
Mar 12, 2011 | Garmin (010-00583-00) for nuvi 750/760/770
My garmin 1250 wont turn on
check the battery first, it might be very weak, that's why its not turning on.
Please let me know if other wise.
Take care.
May 15, 2010 | Garmin nuvi 1250 Car GPS Receiver
Will not turn on
I have a garmin 255W when turning on all itdoes is go to a white screen with black dot thatsay Press dot .It wont turn on how do you fix this
Jan 19, 2010 | Garmin nuvi 255W GPS Receiver
Dec 29, 2009 | Garmin nuvi 255W GPS Receiver
I hope that helps.
Dec 28, 2009 | Garmin nuvi 205W GPS Receiver
Keeps powering down immediately after turning on
I have a similar issue, it does not even power on even connected to ac adapter.
May 22, 2009 | Garmin Nuvi 680 GPS Receiver
Will not turn on
Hold the off button (to the left) for 10 seconds... the system will restart and your garmin should work fine!
Sep 13, 2008 | Garmin (010-00583-00) for nuvi 750/760/770
Garmin nuvi 2455LMT 4.3" GPS Navigator with Lifetime Maps & Traffic Updates Logo
16 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
