Question about GE Profile Prodigy WPSE4200A
How to disassemble an eletric dryer
Squeaks and squeals
Why is dryer squeaking,belt sprayed but still squeals.
If the belt is to lose it can slip and squeal. worn out belts do the same.
Jul 12, 2014 | Eureka 431BX Bagless Upright Vacuum
Dryer
Squealing could be a loose belt very seldom see this squeaking more than likely the drum rollers
Mar 22, 2014 | Kenmore Elite HE4 Electric Dryer
Dryer sqeaks while it's running
This could be the result of a loose/worn belt, or worn drum roller bearings. Is it a constant squeal or a squeak......squeak.........squeak, basically in time with the RPM of the drum? If that is the case, get new drum bearings. If the former is the case, get a new belt.
May 24, 2011 | Maytag Neptune MDE5500AY Electric Dryer
My dryer is squealing and have to run it twice to get my clothes dry
the squealing/squeaking noise is more then likely your drum rollers:
http://www.partselect.com/dryer+dryer-tears-clothes+repair.htm
the drying twice is a venting issue:
http://www.partselect.com/dryer+wont-dry-clothes+repair.htm
Feb 16, 2011 | Whirlpool LEW0050P Electric Dryer
Dryer squeals then quites then squeals
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Oct 25, 2010 | Maytag MDE308DAYW Electric Dryer
My dryer started making a squeaking sound. It's
Belt needs to be replaced,have you ever had a car drive by and heard a squealing noise? dryer belts "glaze" and squeal due to wear just like the ones in your engine
Apr 01, 2010 | Frigidaire Electric Dryer
Dryer making load squeaking and squealing noise when starting it up..sometime it stops after awhile,but now it does it all the time.
heatman101
eue
Jan 22, 2010 | Maytag MDE508DA Dryer
Inglis Citation dryer still squeaks
just an idea.....try to match the squeak to the revolutions of the drum or the guide pulley.
if the squeak is fast it is probably a guide pulley or a roller that the drum rides on. if the squeak is farther apart then the drum is wearing in one spot and rubbing on something. check for wear spots around the drum area.
hope this helps.........jay
Mar 21, 2009 | Dryers
Dryer
Your machine uses a belt tensioner of the type that the belt 'glides' on, creating a squeak noise that #1 will get worse and #2 is wearing out the belt. Replace the old tensioner with the one pictured here. The squeak will go away and the belt will last longer.
If you need further assistance, or instruction on disassembly, let me know
Regards,
reg501
Jun 27, 2008 | Roper RGX4634KQ Gas Dryer
Washing Machines Logo
18 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
