Question about HP Photosmart M547 Digital Camera
Lens willnot extendlens error - HP Photosmart M547 Digital Camera
How do I correct lens cover error?
nikon coolpix s52 lens cover error Questions & Answers ...
www.fixya.com > Forum > Tags
Nikon COOLPIX S51 Digital Camera When I turn the camera on the lens cover willnot slide open. The screen displays a message that say "Lens Cover Error!
Nikon COOLPIX S52 Digital Camera - Fixya
www.fixya.com/support/p926575-nikon_coolpix_s52_digital_camera
Recent Nikon COOLPIX S52 Digital Camera questions, problems & answers. Free expert DIY tips, support, ... How do I correct lens cover error? Nikon COOLPIX.
Fixing a nikon S52 camera lens cover?? PLEASE HELP!!!? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Apr 4, 2011 - ... broke my lens cover on my nikon coolpix s52. when i try to turn it on it says Lens cover error and has a ... Can i fix it myself? What would be the approximate cost of repairs? ... How to fix Nikon Coolpix L6 digital camera lens?
Lens Error message ' Nikon Knowledgebase
Aug 31, 2015 | Nikon COOLPIX S52 Digital Camera
SD-P1700SE just laods willnot play
Either the lens is bad or you have a bad DVD.
Apr 30, 2012 | Toshiba SD-P1700 Portable DVD Player
My ps2 has trouble reading the disk or freezes during play
it requires cleaning of the lens as it willnot read the disc if it has dust particles
Oct 04, 2011 | Sony PlayStation 2 (PS2) Console
Cyberhome ch-dvd 300 player willnot come out of standby and willnot reset after holding reset for 30 sec
Possible failure of the processor. You can shut down, power off the unit completely. Allow time - few hours - for the voltage to drain off thereby resetting any error voltage on the processor. Now repeat the resetting when you power and if there is no response the chances of the processor or motherboard having errors/damaged components are high which will require a voltage/signal/logic trace in the processor
Oct 03, 2011 | Cyberhome CH-DVD 300 DVD Player
My DVD player willnot play commercial disc. It says no disc,bad disc,or no disc found. It is rejecting every disc I put in.
It is possible that the optical lens on you dvd player is dirty or worse it has gone bad. There are discs that are made to clean the lens. Here is an example : http://amzn.to/8Y4qSe
Mar 04, 2011 | GoVideo Televison & Video
Error message shows F -- with lens attached. Lens was cleaned with compressed air, now willnot work. Lens type Nikon 28-80 AF
Check to see that the lens aperture ring is set to the smallest (largest numerical) aperture setting (usually f22 or such). Nikon AF cameras have to have their lenses set at the smallest aperture for most of their program modes to work. Nikon AF lenses have a small slide or twist lock adjacent to the aperture ring to lock it in place at the smallest aperture. This may have been unlocked during the cleaning.
Another possibility is that the lens's electrical contacts were damaged during cleaning, so the body is not "seeing" the lens. Do you have another lens you could attach to the body to test this theory?
Aug 06, 2009 | Nikon N50 35mm SLR Camera
Cameera lens will not open (expand) when turned on.
Please check whether you're using a fully charged battery.
After fully charging the battery if the issue still persists, please try Power Resetting the Camera.
To Power Reset the Camera.
First, please turn OFF the Camera.
Then, remove the battery pack from the Camera.
Then, press and hold the POWER button on the Camera for 30 seconds.
Then, reinsert the battery pack and check whether the issue is resolved.
Jun 15, 2009 | Sony Cameras
Benq vad6038 blew canned air into unit. unit willnot read disks. unit is removed
The lens may be faulty, you can try a lens cleaner disc, wet/dry it might help, but most likely there is a fault in the lens or other mechanis of the drive. Best to get it serviced, if you have warranty, that will cover the fix.
Nov 15, 2008 | Video Game Consoles & Games
Pc willnot read disk at all, I can not download any cd.
your cd-rom drive lens might be weak or damage.however,
try to perform a manual lens clean-up or give it to a local pc technician to do them for you.
if it persist,replace your cd-rom drive with a new one
Apr 03, 2008 | Computers & Internet
HP Photosmart M547 Digital Camera Logo
20 people viewed this question
Top HP Cameras Experts
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
