Question about Teac PD-H500 CD Player
Cd tray wont open - Teac PD-H500 CD Player
CD function not working on Panasonic SA-HE70 receiver
when you say its not working what do you mean by that?
its got no power.
the tray wont open.
tray trying to open but wont.
or just wont play cd.
if none of the above could you please give me more info please.
Nov 08, 2016 | Panasonic SA-HE70 Receiver
Cd tray wont open
CD/DVD Drive Tray problems
There are two ways to open the CD/DVD drive door if the button just below the drive tray does not work.
Go to My Computer and right click on the drive and click on Eject.
If this does not work then you can manually open the CD/DVD drive tray by -
Straighten a paper clip and gently insert it into a tiny hole below the drive tray next to the Eject button. Push the paper clip gently until the drive tray pops out, then pull the tray until it is fully out, then you can remove the CD/DVD disc.
If you still having problem opening with the Eject button, then the CD/DVD drive is faulty and needs replacing.
Apr 13, 2013 | HEWLETT-PACKARD Hp G62-225dx Laptop...
Y cd driver wont open
just push the button on cd tray... then the tray will open. if won't read then maybe your cd is damage or the cd drive got in trouble unable to read. try restarting your system.
Dec 22, 2012 | HP Compaq nx9420 Notebook
My acer x1700 cd drive wont open.. i can hear it attempt to open. i do not have an emergency bottom or push out hole. please help many thanks
CD Drive Tray problems
There are two ways to open the CD drive door if the button just below the drive tray does not work.
If this does not work then you can manually open the CD drive tray by -
Straighten a paper clip and gently insert it into a tiny hole below the drive tray next to the Eject button. Push the paper clip gently until the drive tray pops out, then pull the tray until it is fully out, then you can remove the CD disc.
If you continue having problem opening with the Eject button, then the CD drive is faulty and needs replacing.
Oct 23, 2012 | Acer Computers & Internet
CD tray wont open! how can i open it?
There is a small hole on the front of the drive. just push a straightened paperclip into the hole and it will pop open.
Mar 20, 2012 | Acer Aspire X1200-B1601A PC Desktop
Help LITE-ON DVDRWSHW-1635S door wont open on Gateway computer
There are two ways toopen the CD drive door if the button just below the drive tray does not work.
Straighten a paper clip and gently insert it into a tiny hole below the drivetray next to the Eject button. Push the paper clip gently until the drive traypops out, then pull the tray until it is fully out, then you can remove the CDdisc.
If you continue having problem opening with the Eject button, then the CD driveis faulty and needs replacing.
Mar 19, 2012 | Gateway Computers & Internet
Cd tray wont open
this problem is due to bad handling of cd tray... tray is not opening whether its motor is damaged or cd tray is resisted by something from opening.... i recomend that send your machine to the company for checking... dont try to solve it manually by opening it if you dont want to cry in the end... opening will void its warranty..
Nov 02, 2010 | Bose Lifestyle 28 System
CD ROM is jammed-wont open
This has happened to me. Sometimes when I'm in a hurry I'll place a CD or DVD in the tray and start to close it without making sure that the disk is seated flat in the tray. If it's ****-eyed the CD wil shatter when the tray is closed. The only way to remove the pieces inside the CD drive is to take apart the CD drive. Might be easier just to replace the unit. They run from about $25.00 to $75.00. One other note: You can try to open the tray manually by inserting the end of a paper clip into a small hole on the front bezel of the drive.
Oct 17, 2008 | E-Machines emachines (emachinees) CD-ROM...
Teac PD-H500 CD Player Logo
54 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
