Question about British Telecom Lands Phones
Bt product help
I cannot connect to my incoming calls,phone keeps on ringing, and if I try to call anybody phone display says please check line cord
  • 38 Answers
SOURCE: Toshiba DKT2010-SD won't ring
ask the provider to program the ringging assignment. It wont ring couse dint assign a ringging assignment.
Posted on Feb 27, 2009
divatif
  • 39 Answers
SOURCE: uniden 5.8Ghz phone.
You need to reset the main base unit. Unplug the power from the back of the base. While the power is disconnected, press and hold the delete key while reconnecting the power. Wait for a long beep tone. When the display shows 88 or P, press play button one time. If you have a phone without an answering machine, disconnect the power from the back of the base, press and hold find hs button while reconnecting power.
Posted on Mar 17, 2009
SOURCE: My BT Verve 450 digital phone set won't ring out /incoming call
My GE cordless handset won't ring when it's on the base charging but it will when I take it off. I've taken off the battery and disconnect the phone from the wall to try to reset it, but it still doesn't ring.
Posted on Nov 19, 2009
SOURCE: phone won't ring with incoming calls
I just bought a new Uniden DECT 6.0 phone and had a similar problem. It wouldn't ring when plugged into my Linksys voip router, but my old 5.8 GHz did ring. It would get a dialtone and make calls, but when called via an outside line, it would appear as if it was ringing. If I picked up during this "silent ring," it would answer and take the call. It wasn't a ringer volume issue. I called tech support, they said on the main headset, unplug the battery, then unplug power from the base, then unplug the phone cord from the base. Wait 15-30s. Plug the phone cord, then power, then reinstall the battery. Press the End button on the phone. Put the phone on the base for 15-30s. Pick up the phone. Press and hold the Find button on the base. Do this Find thing 3 times. Put the phone back on the base. Wait 10-15 minutes. Then try calling it to see if it rings. Worked for me, finally got it to ring before I decided to return it.
Posted on Jan 13, 2010
SOURCE: Incoming calls only ring once then hangs up. Can call out/not in
reset your mobile
Posted on Jan 29, 2010
Have purchased this producct plugged it in no ringtone no flashing to indicate incoming call have operational line with dialing tone, help please asap as only line into work
I am assuming that you can hear dial tone on the handset, and you can make calls on the phone. If this is correct, then I would recommend contacting BT and getting the phone replaced with one that works. http://www.bt.com/help/home/landline.html
Apr 16, 2015 | BT Duet 210 Corded Telephone - White
I have BT line and have call divert but can't remember how to divert calls, HELP please
Check which services are active [System X] *#001#
Charge advice (before call) *40* (Number)
Charge advice (All calls) *411#
Charge advice (During call) "R"(to hold call) *40#(Call will be reconnected)
Cancel all calls charge advice #411#
Reminder call *55*(Time in 24 hour format)#
Cancel reminder call #55#
Call Divert - all calls - activate *21*(Number to divert to)#
Call Divert - all calls - to check *#21#
Call Divert - all calls - to cancel #21#
Call Divert - on busy - to activate *67*(Number to divert to)#
Call Divert - on busy - to check *#67#
Call Divert - on busy - to cancel #67#
Call Divert - on no reply - to activate *61*(Number to divert to)#
Call Divert - on no reply - to check *#61#
Call Divert - on no reply - to cancel #61#
Call waiting on *43#
Call waiting off #43#
Call waiting - to check condition *#43#
Call waiting - to answer 2nd caller Recall + 2
Call waiting - remove beeps during call Recall + 0
"Ring back" (Camp on busy) 5
Cancel ring back #37#
Caller display on *234#
Caller display off #234#
BT call minder (voice mail) 1571
Check called number 1471
Release CLI 1470 + dialled number
Withhold CLI 141 + dialled number
Access "Choose to refuse" 14258
Call barring on (outgoing) *341 + option number #
(options are 1 = allows 999 and operator, 2 = allows 999 & local, 3 = allows 999 & STD, 4 = bars all operator calls, 5 = bars *, 6 = bars premium adult lines, 7 = bars premium information lines)
Call barring off (outgoing) #341*(PIN code)#
Incoming calls barred off [System X] #261#
Incoming calls barred on *261#
Incoming calls barred off #261*(PIN code)#
Feb 19, 2015 | BT Lands Phones
CO problems
Check your Phone if connected to Jack 01 to do programming below:
on KX-T7730 phone Press Program *# (enter Password) default is 1234
Press 400 SP-Phone(CO NO.? will be displayed) Press *(Mixed or Connect will be displayed), Press AUTO ANS/MUTE untill (NOT Connect will be displayed) Press AUTO/STORE. Press HOLD(SYS PGM will be displayed) Press 400 (CO Connection will be displayed) Press SP- Phone(CO NO.?) Press SP-Phone (Not Connect will be displayed) Press AUTO ANS/Mute until (Connect will be displayed)Press AUTO/STORE PRESS PROGRAM to return to NORMAL Display.
For the incoming Calls PRESS Program *#1234 (ENter Sys PGM will be displayed) PRESS 408(Day IN CO will be displayed) Press SP Phone (CO No? will be displayed) Press SP Phone (CO1:#01:DISABLED if this is displayed PRESS AUTO ANS/MUte the Enabled will be displayed) Press AUTO/STORE. Press Program to return to normal display. In this Manner All Calls will ring to extension which is connected to Jack 01. you dont need to press the button anytime there is an incoming call.
Dec 04, 2013 | Panasonic KX-T7730 Corded Phone
My phones only light up on my panassonic business phones
If you have a PTPM or the maintenance console, you can program ringing. It's a dealer only product in the U.S. Incoming calls are made to ring ICD (incoming call distribution) groups where the ringing is controlled per extension. In our version, even the manager does not have access to that level of system programming.
Apr 05, 2010 | Panasonic KX-T7633 Corded Phone
Stop ringing at main phones when outside calls come in.
Here is a link to program line ringing.
It sounds like your extension is forwarded (confirmed by the one beep you hear on an incoming call.
From any display phone, press Feature 11
then enter your extension number 2 times. So if you are extension 20, do this:
Feature11-20-20
see if that does it.
May 28, 2009 | Lucent PARTNER18 Corded Phone
Incoming calls ring on intercom rather than appropriate line.
Somehow you might have taken the lines off the extension. I would double check that under line appearance, that extension is set to "appear and ring" for each line.
Dec 08, 2008 | NorStar M7310 Corded Phone
bt cordless phone i have pressed something and it has locked can anyone tell me how to unlock it
Dec 08, 2008 | Uniden Cordless Phone
Incoming Call not Ringing
Either call line 3 first, or make your phone ring :-)
What might be the easiest is to swap modular plugs in the back room between 2 and 5. That way, you get your old extension back and everything will work as it did.
If you can't do that, then you're going to have to do some system programming to turn on the ringing on your phone. If you have a TA series system, you should be able to do it from either the PC or a phone connected to jack $1. If you have another model, you should have a system manual on how do make programming changes.
Carl
Jun 03, 2008 | Panasonic KX-T7731 Corded Phone
INCOMING CALLS
Not sure it this is a solution for ALL your problems, but...
I had a similar issue: Phone rings, caller ID info displays then seems to hesitate, then displays only "INCOMING CALL."
The issue seemed to be caused by interference with other devices on the same line (in my case, an alarm system).
Tech support had me change a setting on my TRU9466 base unit (this is one of the PowerMax 5.8ghz models). This is how we did it step-by-step on the base unit:
MENU
GLOBAL SETUP
IN-USE LINE SETUP
select LINE 1
switch to TYPE B
This seems to have solved the Caller ID "interference" issue -- my Caller ID now displays as it should. The Tech Support person suggested trying that TYPE A/TYPE B setting on "OFF" if TYPE B didn't solve the problem, but thankfully, it did.
Now Cheryl, it sounds like your issue is more involved than this -- I didn't have any connection problems -- but perhaps they're related -- you might try my solution.
Mar 07, 2008 | Uniden 5.8GHz Cordless Phone
Lands Phones Logo
54 people viewed this question
Top British Telecom Lands Phones Experts
honeybun1986
Are you a British Telecom Lands Phone Expert? Answer questions, earn points and help others
