Question about Dishwashers
Top dishdrawer won't open no power
The top drawer of our F&P Dishdrawer won't open and there's no power, but bottom drawer is working. Top drawer had been making strange noises while running the night before.
  • Dishwashers Master
  • 3,247 Answers
The most logical explanation is the controller in top drawer has packed up or the power board located at the base of dishwasher housing (under bottom drawer) has partially packed up and stopped supplying power to the top drawer controller. But another explanation is that the thermal relay in the top drawer (located inside the heater element assembly has cut off. This stops power to the controller. This is the most expensive to fix as the entire heater element assembly has to be replaced as the thermal relay is not separately accessible. How you want to isolate the problem and fix it depends on how comfortable you are with fixing electrical and electronic systems. This is a very sofisticated dishwasher and a small mistake is irreversible. By the way you can open the drawer by forcing it open but keep in mind not to try to shut it firmly again until you restore the controller power. Otherwise the lid seal or actuator motors will be damaged. Whatever you do, make sure the mains power is turned off if you work on the dishwasher circuits.
Posted on Feb 16, 2014
  • Cat Torres V
    Cat Torres V Feb 17, 2014
    Thanks for this very helpful and informative response, Sam. We'll probably get an expert to do it, as I wouldn't dare to this myself.
  • 5 Answers
SOURCE: Dishdrawer
Hi there, If you have no power to the top drawer and it is difficult to open it may be that your heater plate has blown and requires replacing. If it has no power and opens easily you may have the child lock on and need to hold the lock button down till the lock emblem disappears of the display screen on the front of the drawer. regards KAR-Ltd
Posted on Aug 09, 2007
  • 58 Answers
SOURCE: My Fisher Paykel double dishdrawer dishwasher top drawer rubs.
The only thing you can do is push the plate back in place there are tabs in it and from time to time it works itself out. If the tabs are broken you should replace the plate. hope that helps
Posted on Jan 07, 2009
  • 3 Answers
SOURCE: Water leaking from top dishdrawer
This is very rare in any dishwasher. I use to repair most all dishwahers. First check your door seal for any cracks, cuts or splits. The water inside is under great pressure and can push out from the top of the door if that is is weak, flat, or has anykind of cut or crack. If the leak indeed is coming from the top then you will need to get someone to help you pull out unit and check top for cracks or splits. This entire housing is plastic and may have come with crack. If your washer has a hose at the top, then check it good. While its out from under the counter run it and watch to see if you can tell where leak is coming from. I may have missed something. Remember, always unplug this from wall outlet or turn off breaker if you are indeed moving it in or out. Good luck.
Posted on Mar 09, 2009
  • 22 Answers
SOURCE: turn on and off buy it self
If a Fisher & Paykel dishdrawer is having a problem, it will usually display a fault code beginning with a "U" or an "F". "U" codes are usually solvable by the owner by checking the definition in the owner's manual. "F" codes usually require a service technician. I can tell you from experience that if you have no idea what to do, you should leave this one to someone who does. It's very easy to cause more damage by trying to disassemble it incorrectly. Also, the DD603 utilizes a "smart tool" that enables a technician to use a laptop and F&P software to diagnose the problem correctly.
Posted on Apr 25, 2009
  • 3247 Answers
SOURCE: Fisher and Paykel dishdrawer, lid not retracting, no power.
By no power you may be implying there is no display etc and the swithces are not working. Most likely the controller of the top drawer has had it. The controller is mounted on the front of the drawer behind the door panel. Hope things are better than that.
Posted on Nov 10, 2009
Fisher and Paykel twin dishdrawer
there is water in the base setting off the flood sensor, you will need to remove the bottom draw and dry the water up with a towel (make sure the power is off and unplug it from the power point) then you will need to do a bit of testing to locate the cause of the leak, if your lucky the leak was caused by incorrect dish stacking or something too big in the draw
Jan 02, 2017 | Fisher and Paykel Dishwashers
Fisher paykel dishdrawer bottom drawer washes fine leaves water in top drawer
At some point the two drawers individual drain hoses are joined using a "Y' type connector. Check this, and everything beyond this point for restrictions or blockage. It sounds like the bottom drawer is pumping its drain water out normally, but some of that water is backing up to the upper drawer. This is an installation or plumbing problem that is external of the dishdrawers.
Jul 25, 2016 | Fisher and Paykel 23 in. DD-603SS Built-in...
How do I reset the f1 flood button . Dd603ss
Not sure if you have managed to fix the F1 problem with your dishdrawer. This is a common problem and occurs mainly due to water leaking into the base of the dishdrawer under the bottom drawer.
But if it is occuring only in one drawer then the power filter at the base of dishdrawer is faulty and needs replacement.
Otherwise make sure the mains power to dishdrawer is turned off. Pull out the bottom drawer and stack in some towels behind it if you can to remove the moisture sitting on the base. The flood switch is located there. Then take a hair dryer and run it down behind the drawer to dry things. Push drawer back and turn power back on. Now if you cannot reach the back of the drawer then you will have to pull the drawer out from its rail. Refer the installation manual for this. See link page 7.
You need to find the source of the lead, Fisher Paykel DishDrawer Installation Instructions ManualsOnline com
Jul 05, 2014 | Fisher and Paykel 24 in. DD603H W Built-in...
Dishdrawer cannot open
the power board at the base of the dishwasher under bottom drawer appears to have blown up. Take the bottom drawer out carefully to access the power board. Make sure the mains power is turned off.
The reason the bottom drawer is not getting back in is that lid seal actuators are stuck as the motors are in close position. Will reset to normal position once the power is restored. So don't try to push the drawer in as the lid seal will be damaged.
Feb 15, 2013 | Fisher and Paykel 23 in. DD-603SS Built-in...
Faulty top drawer on fp dishdraw can I disconnect powet to top unit to disable it
Unfortunately the power is distributed from the inside to the two drawers.
You will have to address the cause of the problem in the top drawer.
If you are good at electric repairs you could disconnect the power from the dishwasher power board itself, but this is not for the faint hearted (no offence). Might be helpful if you can provide a little details about the problem with top drawer. Generally if you are getting F1 message on the panel on bottom drawer and top drawer display is blank (ie no power), then the power board at the base of dishwasher is blown and needs to be replaced. Please clarify model number as the one you provided is for single drawer unit. Make sure the mains power is turned off when you work inside the diswasher.
Feb 05, 2013 | Fisher and Paykel DishDrawer DS605FDSM...
Greetings. I have a Fisher & Paykel dishdrawer - the top drawer appears to have lost power mid cycle and the lid has not retracted - no led display - no response from the buttons. The bottom drawer...
Describethe inside of unit,any wear on it anywhere, the rack the dishes go on is it plastic coated? is it wore with rust comeing though on tips here and there?
Mar 07, 2011 | Fisher and Paykel DishDrawer DS605FDSM...
My model number is DD603 The top dishdrawer is draining into the bottom dishdrawer. What is the code to reset the drawers?
the check valve in the bottom drawer may be clogged or defective. the two drain hoses are probly connected to become one.
Jan 20, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Oct 16, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Top Drawer light is out-display eratic powers on and off at will.
Below is the service manual link and a web site that I found. refer to the lower section where a person writes in that the fixed the flooding with a hairdryer. I hope this helps, they seem like fantastic dishwashers.
http://www.scribd.com/doc/6462163/DD601V2-Manual
http://fixitnow.com/wp/2004/10/25/appliance-repair-revelation-fisher-paykel-dd602-dishdrawer-f1-code/
Mat
Please rate me
Nov 30, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
DD603HSS
there is only one power supply or input so you need to find out where the power stops from the bottom to the top drawer
Aug 18, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Dishwashers Logo
221 people viewed this question
Top Dishwashers Experts
