Question about Keurig B30 Mini Coffee Maker
Doesn't work After 13 months the machine no longer works - red light flashes, it sounds like coffee will drip out but nothing happens...
SOURCE: heating light stays on
I contacted Keurig at 866-901-2739. Based on my serial number, I was still within my 1 year warranty. They determined that my heating element was bad, based on the fact that the the area above the power cord was not at all hot, which it would be if it was truly heating.
My new machine will arrive via FedEx in 3 days!
The Keurig rep did also mention that the heating elements are sensitive to hard well water, which I have. They have seen issues where hard water requires you perform more frequent de-scaling of the brewer, depending on water hardness. Alternatively, we may switch to bottled water.
Posted on Aug 21, 2008
BarrettDenCo
  • 1772 Answers
SOURCE: coffee just drips out of
wer
Sorry to read about your issue.
The brewer should be de-scaled at least every 3-6 months. Scale is harmless, but if left unattended, it can hinder optimal brewer performance. De-scaling your brewer regularly helps maintain the heating element, removable water reservoir and other parts of the brewer that come in contact with water. Better water quality and water heating means a better cup of coffee, tea, hot cocoa or iced beverage. We recommend de-scaling your brewer at least every 6 months (every 3 months if your water has a high mineral content). The de-scaling process involves using 48 ounces of undiluted white vinegar.
Take 48 oz of white vinegar. place in tank. pretend you are making coffee (Do No Use K Cup). let the water fill you mug. then empty that mug. Do it again until tank is empty. then let sit for 4 hours.
Then fill with fresh water to the top. let that tank of water run thru. towards the end taste the water.
If you taste vinegar..use more clean water, until the taste is ok.
I tried to help you. Please help me and Vote/Rate this response. Thanks and good luck
Posted on Dec 25, 2010
SOURCE: Coffee maker not working
I've got a B50 as well, and none of these solutions are quite accurate. The problem is with the ball valve directly above the top needle. You first need to remove the handle by taking out the screw on either side. Mine is some size of torks. Then open the hood and remove the two screws from under it. The hood then lifts right off the body. There is a rubber hose that goes into the top part of the ball valve; this must be removed. You can then use a slightly bent paper clip to reach in carefully and push the ball down to unstick it. It is being pushed up by a spring from underneath, so coming from the bottom with a paper clip just pushed it up tighter in the seat. Once it is clear again, put the hood and handle back on.
I think Keurig should send free replacement valves, maybe better designed as well so they don't stick anymore. If not, I am going to see if I can purchase a replacement.
Posted on Jan 06, 2011
heatman101
  • 43501 Answers
SOURCE: I received a Kuerig coffee
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Posted on Aug 07, 2011
heatman101
  • 43501 Answers
SOURCE: coffee brews but doesn't fill cup, already
heatman101
Why wont red light come on EM6910 coffee machine?
Sounds like a thermostat is no longer working. Needs to be repaired!
Jul 15, 2014 | Sunbeam Cafe EM6910
Light on but nothing happens
Sound like the diodes stuffed FOR THE MAIN UNIT.
I'd be taking back to the supplier/ STORE
Apr 30, 2012 | DeLonghi BC0261 Espresso & Coffee Maker
The power button lights up but absolutely nothing else works..NOTHING!...had machine for 8 months..these are too expensive to be disposable..help?...
The problem is often that the machine develops a leak in the hose that is rightover the transformer...the water drips onto the transformer and kills that...then you have no power to run the machine.
Here is a tip that I wrote about this problem...
Keurig OneCup Coffee Brewer will not turn on
heatman101
Sep 22, 2011 | Keurig B60 Coffee Maker
I have the Vienna Superautomatica. It turns on, the green "on" light ilights the red light blinks on and off. The grind button has no effect. Nothing is clogging the grinder - sometimes there...
Hi
Blinki9ng red light usually something is not in place. The water tank empty. grinder empty or cloged, the brew unit not seated, dredge drawer not in place, or the usual cluprit is the drip tray. There can be something behind the drip tray that is keeping it from seating ( it has to lock into the 2 holes in the bottom of the base) Try to push the drip tray in and down and see if it will work.
May 16, 2011 | Saeco Vienna SuperAutomatica Coffee...
I have a red light and nothing is working no cofee and no milk nothing
I have a Saeco Easy. Maybe the solution for my machine will help you. You did not specify which light is red I will assume it is the "Alarm" light.
Alarm light (looks like an "!" exclamation point)
• permanently on: signals the machine is out of coffee, the water tank is
empty, the drip tray is full or the dregdrawer is full.
• slowly flashing: signals that the brew group is not inserted, the dregdrawer
is not inserted, the coffee bean hopper lid is not on, the service door is open
or the steam/hot water knob is not correctly turned to the desired position.
• quickly flashing: signals the need to prime the water circuit
Apr 19, 2011 | Saeco Talea Giro Espresso Machine
Red ! light comes on and will not work
If it is a steady light water tank is not properly in OR dregs counting and drip tray is full. Pull out the drip tray and wait for the red light changes in to flashing, then put back the drip tray.
Mar 18, 2010 | Saeco Odea Giro Plus Coffee Maker
New Saeco Odeo Go has solid red exclamation mark, doesn't budge
You have to 'manually' prime the pump: When the red exclamation mark shows, press the water switch on the right side (the picture of the water drip), then open up the steam nozzle and let the machine pump hot water into a cup until the red light goes out.
Jun 11, 2009 | Saeco Odea Go
Braun kf 580 coffee maker
If the hot plate is tilted then it should be able to be pushed back down until it is completely level. If not then it is damaged. Check to see that it is screwed in properly underneath.
Apr 15, 2008 | Coffee Makers & Espresso Machines
Water steams away and nothing drips into the caraffe
I had this problem too and finally found a fix for it.
I don't know if the cause of this issue is the same for everyone experiencing the problem, but the issue for me was hard water. The fix is to run vinegar mixed with water through the machine quite a few times, until it starts to run normally.
If you do have hard water issues, it's recommended that you run vinegar or citric acid through the machine about once a month, to keep deposits from building up.
Feb 15, 2008 | Krups Caffe Bistro 867 Espresso & Coffee...
Keurig B30 Mini Coffee Maker Logo
18 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
