Question about Samsung VG-STC2000
Will this work on my tv model #ln4oe55of7fxza
I have usb port in back of tv
I can not find an HDM1 port on my Sharp TV. Can I use the USB Port?
No, the HDMI plug will not fit into a USB port. (It's the wrong shape and the pins are different.) The micro-USB port can be connected to some USB ports for power, not data, with the appropriate cable (micro USB to type A). (Without the model of your Sharp TV, I do not know if the USB port has the right specifications. Some older TVs only have a "service port" which doesn't always provide enough power.)
There are HDMI to component video/audio converters that may work. They do not always work with copy protected (HDCP) content. See http://www.bhphotovideo.com/c/product/770115-REG/KanexPro_HDRGBRL_HDMI_to_Component_Converter.html for one example. (Composite video is not recommended since that will downgrade the signal to 480i. Component video supports 1080p signals.)
If you have 1 HDMI port, then a multi-port HDMI switch may work. Note: automatic switches often do not switch on their own with some sources. If the source never actually turns off, like some set-top boxes, you'll need to switch the unit manually.
I hope this helps.
Mar 05, 2016 | Amazon Fire TV Stick
I want to activate my USB tv Port on that model, and cant .
This should be in the settings menu on your TV. Just like a computer you need to format the drive for the TV.
Nov 14, 2015 | LG 32LD330 MULTISYSTEM LCD FOR 110-240...
I have a Vizio TV and would like to add a Chromecast streaming media player,the information I have shows the player powered via the USB IN 1 port,would the RGB PC port work? I have model #GV47L FHDTV
Chromecase is a USB 'stick' type device with a USB interface. The RGB port is a video only port on the TV and not compatible with USB signal levels or the physical plug type.
Jan 05, 2015 | Vizio GV47LF Television
Rca 19 inch led tv model detk 185r usb port wont work
Check your manual to see if the USB port is used for anything else besides upgrading the software in the TV. Some do and some don't.
Nov 19, 2014 | Televison & Video
I had buy sony bravia led tv 2 years back at that time usb ports are working properly but from 6 month tv is not detecting any usb device so how can i solve this problem.....?
U may need a new USB they get old overtime from removing and placing back in or try and default reset your TV,if that don't help then the port On the TV is bad
Jul 19, 2014 | Sony KDL32EX40B - BRAVIA KDL-32EX40B 32...
WHERE DOES MY STICK GO IN AN IBM THINKPAD LAPTOP
The model number is located either on the bottom of the right corner of the screen and on the label on the bottom of the laptop and the location and number of USB ports vary with different models.
The USB port is a connector/port that is 12x5 mm in size, some model thinkpad have onlt one USB port and some have 2 USB ports.
The USB ports are usually located at the back or at the sides of the laptop.
The T30 model has 2 USB ports at the back of the laptop located between the LAN and PS2 connectors.
The T40 model has 2 USB ports located at the left side of the laptop.
The A31p model has 2 USB ports located at the back left hand corner of the laptop.
The R32 model has 2 USB ports, one is located at the back left hand corner and the other is located on the left hand side of the laptop.
Feb 08, 2012 | IBM Computers & Internet
32LG3000 TV LCD - usb port ''service only''
Yes it's possible to use the USB port , you only have to change settings in TV setup to change it.
With software ver 3.15 it's very easy see link below how to change setup.
http://lgusb.wikispaces.com/#support
Feb 23, 2010 | Televison & Video
I want to know and identify the parts of my laptop
On the right hand side starting from the front to the back, the ports are
1. (2) USB Ports
2. TV/Cable jack if applicable, some models don't have.
3. RJ-11 Modem Jack
4. Security cable Slot
5. Power Connector
On the Left side Starting from front to back. the ports are.
1. Express Card Slot
2. Digital Media Slot (below the Express Card)
3. 1394 (firewire) slot (some models don't have)
4. USB Port
5. E-Sata Port
6. HDMI Port
7. RJ-45 Ethernet Port
8. Expansion Port Type 3 (attaching docking station etc.)
9. External Monitor Port
Oct 10, 2009 | HP Pavilion dv6-1030us Notebook
Samsung VG-STC2000 Logo
18 people viewed this question
Jerry Greenberg
Jerry Greenberg
