Question about BOSS AUDIO SYSTEMS BV7325B Car Video Player
Install a boss bv7325b - BOSS AUDIO SYSTEMS BV7325B Car Video Player
I installed a Boss Bv9976b in my 1995 Honda accord,have no sound out speakers?
if you are sure the speakers are good and the wiring to the speaker is correct then you need to look at the Boss.. a volt meter on the output either at the speakers or the harness should tell you, as it fluctuates with the volume of the unit, hopefully you do have power to the Boss...
Dec 30, 2014 | Honda Cars & Trucks
How do you update the software for a boss 638UA car stereo
Software for car radio usually can't be updated. If Boss have a new firmwire, you can go to their website and install it via USB.
Feb 28, 2011 | BOSS AUDIO SYSTEMS 638UA Car USB Player
Replace damaged front fork lock on a 1996 harley davidson FXDS-CONV.
Ok, this is how you replace the lock on the front end.
1.Loosen upper triple tree clamp pinch bolts. Remove upper triple clamp and handlebars.
2.Loosen fork stem bolt and let fork stem drop down approx. 5 inches.
Note: On the left side of the steering stem there is a "half moon" indentation that has been machined into the steering stem for the lock. Let steering stem drop until this indentation is in full view.
3. Use a scribe and remove lead plug. (there is a flat looking place below the key lock. The lead plug is underneath this and it hides a set screw. Dig the lead plug out to get to the set screw)
4.Unscrew the set screw
5.Insert key in lock and turn partially.
6.Wiggle lock and pull until enough of the lock comes out to get a grip with pliers or other suitable tool.
7.Rotate steering stem slightly, while pulling on lock until lock is removed.
INSTALLATION
General
There is an internal boss in the left side of the steering head opposite the external boss. The end of the lock fits into this internal boss.
There is a hole in the bottom of the lock into which the set screw fits. This hole must be at the bottom when the lock is installed.
When the lock is correctly installed, a forward-facing flat on the lock will fit against a flat inside the external lock boss and the face of the lock will be flush with the face of the external boss.
1.Steering stem should be in above position. See steps 1 and 2 above.
2.Grease the end of the lock (the part that goes into the internal boss) and slide lock into external boss.
Note: Steering stem must be in locked fork position.
3. Move steering stem into locked fork postition. Rotate steering stem sligtly, while fully installing lock.
4.use Loctite 242 (medium strength blue) and install set screw
5.Use key in the lock and tighen set scrw until lock begins to bind; then back set screw out 1/2 turn.
6.Pound in lead plug (or use a good quality sealant)
7. Install fork stem, upper triple clamp and handlebars.
Right out of the book. Hope it helps. Good Luck.
Nov 13, 2009 | 2000 Harley Davidson FXDX Dyna Super Glide...
My computer doesn't recognize my boss micro br.
Have you installed the correct codec for it? Go to Microsoft site or Boss.com and download the codec and driver for it.
Good Luck
Sep 03, 2009 | Boss Micro BR Digital Recorder
I need to know how to install a Boss Audio
Hello viperman2004,
Just connect your speaker leads to the input of the B65N (gray and gray/white pigtail leads), run the RCA cables to your amp (red=right) inputs, adjust the left and right level controls to match the amp input without distortion, and mount the unit.
Hope this helps.
Aug 11, 2009 | Boss Car Audio & Video
How to install
you have to install it like u was going to install a deck i sugjest that if u have not gotenany experience whit audio equiment dent just take it to the shop
Jun 14, 2008 | Boss BV72M 7.2 in. Car Monitor
Bypass parking brake wire
Boss Audio is the easiest in-dash DVD on the market to bypass; all you do is ground the ebrake wire. I recently installed 12 Boss Audio in-dash BV-7300's and did this to all of the decks problem solved. By the way I did this because they were in the back of limousines where the driver couldn't ever even see one of them while he was driving. I don't think there will be a problem, try it.
May 20, 2008 | Boss DVD-7500 Car DVD Player
BOSS AUDIO SYSTEMS BV7325B Car Video Player Logo
18 people viewed this question
Top BOSS AUDIO SYSTEMS Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Kazim ERGUNEY
Kazim ERGUNEY
Jerry Umali
Are you a BOSS AUDIO SYSTEMS Car Audio and Video Expert? Answer questions, earn points and help others
