Question about Wharfedale Titan 12 ACTIVE 12" 2-Way Powered Speaker
My wharfedale Titan 8 active keeps cutting out
Tip
Wharfedale M5 DVD Region Free Fix
Wharfedale M5 DVD Player Region Free Fix
Would you like to unlock your Wharfedale M5 DVD Player to Region Free?
Follow these steps to unlock your Wharfedale M5 DVD Player:
  1. Press the Setup button on your remote control.
  2. Press the buttons 6, 2, 8, 3 and then 6 on your remote control.
  3. In the Regions Setting - Factory Menu page, set a specific region or choose All for Region Free playback.
  4. Press the Setup button on your remote control to exit the menu.
Your Wharfedale M5 DVD Player is now Region Free.
I hope that helps.
on Apr 25, 2010 | Televison & Video
What are the available subwoofers for sony mhc-gnz88d
you need 'line level input .. left and right'
front speaker to subwoofer input = subwoofer works + speaker outputs Use The ( Wharfedale SPC-8 Active Sub)
Sep 02, 2017 | Sony Audio Players & Recorders
I have a Titan water heater model N-160. I turned the water off hoping to change the filter. Now There is no hot water and the screen reads : STAND BY FLOW=OFF how can I reset it?
Hey Shawn..did you turn the water back on BEFORE cutting the electricity back on? Cut the breaker off,,, wait 3-4 minutes before restarting.. MAKE sure the water is on ALL the way...
Troubleshooting the Titan tankless water heater
SCR3 160 Titan Tankless Water Heater
Jul 02, 2017 | Water Water Heaters
Wants to keep tripping out when turned on.
maybe heat built up make sure it's not too close to anything clean the heat sinks from dust too. do you hear a fan blowing at all
Apr 19, 2014 | Wharfedale Pro TITAN Sub-A12 Active...
Wharfedale problems
Take it to a repair shop. You have a short circuit or too small a fuse. Have an expert check it before you try to use it again.
Apr 05, 2014 | Wharfedale Titan 12 ACTIVE 12" 2-Way...
My wharfedale sw150 subwoofer cuts out in normal viewing, any suggestions
If your Wharfedale sub is powered, it gets its input from a subwoofer output on the rear of the Sony. At a certain level, your sub is turned on and sounds just fine until the level decreases during quiet passages of music then it turns off. I believe the theory is that this approach prevents start-up "pops" but in practice it is a poor solution. I have had several subs that have acted this way. I don't know of a way to fix this short of eliminating the level-controlled turn-on circuit
Sep 28, 2012 | Wharfedale SW150 Subwoofer
Wharfedale TV power problems
got a 32 inch wharfedale tv from argos also and it seems to boot up and then shut down and just loops, if i keep unplugging it i can sometimes get it on but with a high pitch wailing, only 15 months old, gutted!
Jun 16, 2008 | Televison & Video
Wharfedale Titan 12 ACTIVE 12" 2-Way Powered Speaker Logo
55 people viewed this question
Top Wharfedale Audio Players & Recorders Experts
jason
Are you a Wharfedale Audio Player and Recorder Expert? Answer questions, earn points and help others
