Question about Bosch Nexxt Premium WFMC6400UC Front Load Washer
Washer violently jumps around during spin cycle
The washer jumps off of the floor even during reduced spin cycles
SOURCE: WAY too much shaking
Take out the four "shipping\travel" bolts in the back of the machine. Read the manual- it will tell you how to do this. John
Posted on May 29, 2007
  • 1462 Answers
SOURCE: Bosch WFR 2460 washer - Drum does not move during wash/spin cycles
possibly the motor brushes.
take back panel off and motor is held in by bolts which undo - also disconnect electrical plug and socket.
check condition of brushes
Posted on Oct 16, 2008
SOURCE: Frigidaire front loader walking during spin cycle
Have you made sure that all the shipping bolts and stuff were removed? this happened with our Bosch and we found out we had kept three bolts installed that needed to be removed
Posted on Jan 25, 2009
  • 6277 Answers
SOURCE: During the spin cycle the
Although you say that the feet are adjusted I would nicely suggest you follow my guidance notes below ;-0)
It is necessary to ensure absolutely that the machine, even when empty, has all 4 feet very firmly on the floor, and I mean firmly ;-0)
Doesn't matter whether it is empty or not but switch it off then-
very firmly push one front corner diagonally into the centre of the machine (sorry about my UK spelling!) and see if the machine moves or rocks AT ALL, even the slightest. If it does you will need the open-ended spanner which came with the (new) machine........which of course went missing a long time ago?!! An adjustable spanner will suffice.
Adjust the foot under that corner downwards until it is very firmly- almost pushing- against the floor but not so far that the corner lifts up!
If this corner did not rock do the same to the other.
Once you cannot rock the machine the slightest little bit, screw the locking nuts up tight to the underside of the machine so that they will not move. Ideally the rear feet should also be locked.
If this has not cured the problem it is possible that the internal drum suspension is malfunctioning.
Good luck,
John C
Posted on Feb 26, 2011
caroldon
  • 17129 Answers
SOURCE: just bought a 500 series washer and its vibrating
It is so common that the washing machine can make terrible noise in many ways and is a common fault. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that machine is vibrating when it is running then the motor /drum suspension has to be inspected. Since these fittings are located on the underside of the machine it is important that you look for the noise with a good inspection lamp. Manually turn the motor and drum and listen for the noise, if so the motor bearings, the drum agitator shaft and fittings must be checked. Also the suspensions which include the shock absorbers and springs, the body clamps must be checked to be in correct alignment and not changed in position. Tightening of the mounting is also very important. Finally in most cases a drop of OIL or smear of grease on the moving parts cane solve most issues.
For replacement of bearings check for tips on this visual link: http://www.espares.co.uk/advice/washing-machines/a/7/1401/how-to-replace-the-bearings-on-a-washing-mach.html
Posted on Dec 19, 2011
Kenmore Whasher shakes on spin cycle
unfortunetly this is common , these new frontloads spin fast even with no pedestal these things move...
make sure the locking nuts for the legs on the pedestal are screwed securely up to frame on pedestal, also could be a floor issue depending on where it is, slooping or not solid floor.
Jan 28, 2010 | Kenmore Elite 45986 Front Load Washer
The drum shakes violently and is very loud during spin cycle
There are 2 shock absorbers/springs attached to the drum. If one of them breaks it will cause a loud banging noise when you wash heavy loads. This is an easy fix. The part is about $22.00 and it is accessed throught the front bottom panel.
Dec 01, 2009 | Frigidaire GLTF1670A Front Load Washer
Kenmore Oasis HE shakes violently during spin cycle
Machine legs should be adjusted so that machine is level and standing on all four legs. The load in the machine should be evenly distributed. Utube has an excellent video on washing machine repair.
Nov 20, 2009 | Kenmore Oasis HE 27082 Top Load Washer
On the spin cycle my miele walks acrossed the floor
make sure you loads are balanced, put heaviest clothes in first... if you can rock it by hand then the legs are not adjusted properly. If you stand 2 feet away from front of machine, jump up and down and see it move the floor is soft and you need 2 sheets of plywood to make 1 1/2 inches put under the machine
Aug 06, 2009 | Washing Machines
Front load washer shakes violently during spin cycle
On something like this you will need to remove the washer wrap to inspect the suspension springs & base assembly. Please see the link provided for accessing the inside of the washer. Be sure the shipping pins have been removed. The tub should float freely.
Apr 03, 2009 | Washing Machines
Whirlpool washing machine
Welcome hendrik,
You said, jumping around during spin cycle
How old is your GHW9150 washer?
Usually it is overload or load unbalanced due to uneven load.You must stop the machine and re-distribute the load and or weight!
Here are some Whirlpool reasons for you.
But if nothing helps you may have a mechanical problem to be serviced!
Try these ideas first!
Is the load balanced?
A single or bulky item may cause imbalance. Add more items
or redistribute the load.
Washer makes noise or vibrates
Is the washer level?
The washer must be level. The four feet should be properly
installed, and the nuts should be tightened against the
washer cabinet.
As water is drained from the washer, you may hear air being
pulled through the pump. This happens during the end of
draining. It is normal.
Are you washing items with metal snaps, buckles or zippers?
You may hear metal items touching the washer drum. This is
normal.
Is washer installed on a sturdy and solid floor?
Refer to the “Installation Instructions” for flooring
requirements. Noise and vibration may be reduced by placing
a piece of ¾" (19.1 mm) plywood underneath your washer.
The plywood may extend underneath both washer and dryer
to keep them at equal heights.
Let me know If you have any questions and what happens!!!
Huuum
Please remember to leave a rating!
Oct 11, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore washer shakes violently during spin cycle
syrny,
Not sure what you did, exactly. First, does the machine shake when spun empty...and then with water only? If so, you have probably failed to tighten something or misaligned something. Go over your work.
No shakes? Rearrange your load. You may have a pair of heavy wet jeans which is throwing the whole thing out of kilter. It only takes about a half pound of sodden clothing to do this.
Nov 26, 2007 | Kenmore 22422 Top Load Washer
Bosch Nexxt Premium WFMC6400UC Front Load Washer Logo
19 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
