Question about Home
Sanipro xr: When connecting power on, a motor keep running all the time, not ending.What could be a problem?Thanks for help, Ari
jeff_drakesr
  • 155 Answers
SOURCE: sanipro xr massirato the problem is the pump is
You must remove the lid to gain access to the blades. Make sure you unplug the unit first. When reinstalling the lid place a little soap water around the gasket to help with the seal. thanks for using FIXYA. Jeff
Posted on Apr 07, 2010
  • 115 Answers
SOURCE: Sanipro xr is less than 6 months old been working
Water pressure makes the unit kick on and off. Somehow water is draining back into the pump casing, check the flapper on the check valve inside the discharge elbow, it may not be closing properly or may be obstructed allowing waste water to drain back into the pump. Also check the flapper on the flush valve inside the toilet tank (water closet) the flapper may be leaking water into the bowl and from the bowl into the pump casing sitting behind. As far as making a loud noise, there could be a blockage on the drain pipe, blade or impeller. The discharge pipe may be loose, not clamped against the wall and is rattling against the wall when in use.
Posted on Jan 11, 2011
  • 115 Answers
SOURCE: sanipro xr pumps for 15 mins then wont start up
Definitely there is a problem with the pressure chamber, it may need to be replaced. The pressure chamber is were all the electrical components are sitted and is what turns the unit on and off. You can always order parts throught Saniflo's technical dept. 800-571-8191
packrat1948
  • 528 Answers
SOURCE: i have a sanipro xr its not making the sound it
The pump in the lift chamber has quit working. Check the power to it and if that's not the problem then you will have to get into where the pump is to see if the float is hung up. I know it's a nasty job but someone has to do it.
Posted on Jan 30, 2011
packrat1948
  • 528 Answers
SOURCE: I just had a brand
Number one don't pay that plumber, number two get a new plumber as the last one has not a clue what he's doing. I would go through what I would do but not knowing what kind of a mess the last so called plumber left the pipe joint in it may make things worse. I know this is a pain in the A but you have no other alternative but to clean things up and wait for a new plumber. I hate when people that call themselves plumbers do this to people, it gives all us Plumbers a bad name.
Posted on Mar 20, 2011
I have a Sanipro,it sounds like it pumps real weak and goes off quickly instead of emptying out everything. then it will come on again after aseveral seconds . Could it be the Condenser on the motor?
  1. Saniflo & Saniplus&... Repair Questions - Fixya
    www.fixya.com/.../p1064016-saniflo_saniplus_macerator_pump_002 Saniflo & Saniplus& Macerator Pump - Recent Questions, Troubleshooting & Support ... My saniflo does not flush properly always leaves the toilet paper behind.
Jul 20, 2015 | Saniflo SANIPRO Macerating Pump
I just had a brand new sanipro installed in a newly created ensuite, this is its ist week and the pipe keeps bursting out, called the plumber back and he refixed the white pipe to the wall,now it has burst...
Mar 20, 2011 | Saniflo SaniPlus-Round SaniPlus Macerator...
I have a symmetra RM UPS with 2 extended run battery frames. I am constantly getting a "XR frame fault" on the power view panel and an error code E0 is being displayed on extended battery frames...
The first thing is to make sure the interconnection between the main module and the extended run is properly making contact
Next is to verify the XR battery cabinet voltage is according the battery charging voltage (normally 137 Vdc). Power View will confirm this voltage.
My favorite is to load test the batteries module individually and make sure the batteries are good.
If there is a +/- 3 volts difference between the UPS and the extended run module E0 alarm would be indcated.
Feb 17, 2011 | APC Symmetra RM 6kVA UPS System
I have a sanipro xr its not making the sound it use to when i use to flush and the waste doesnt go down.
Jan 28, 2011 | Saniflo SaniPlus-Round SaniPlus Macerator...
Sanipro xr pumps for 15 mins then wont start up again have to turn the power off and back on for it to pump how do i fix it
Dec 30, 2010 | Saniflo SaniPlus-Round SaniPlus Macerator...
Sanipro xr massirato the problem is the pump is not pumping on makes a stuck sound, how do we clear out the massrator?.
Mar 11, 2010 | Saniflo SaniPlus-Round SaniPlus Macerator...
I just did a top end rebuild and my 1997 honda xr200r wont run; i think its timing related but am confused on how to do it can you please help
When you replaced the top end, when replacing the cam gear and timing chain, did you align marks on the timing gear and the cam? The motor should be at top dead center when this is done, at this point the piston is at the highest point and the valves are closed.
Jul 05, 2009 | 2002 Honda XR 200
Need to know how to set timing on 1989 xr 250 r motor cycle
The ignition timing on your bike is CDI based and cannot be changed. Absolutely no way to change it. Valve timing is a different matter and involves static timing marks on the OHC gear. If the bike runs at all then the valve timing is set properly as is.
Pleas rate this solution. Thanks!
Mar 29, 2009 | 1987 Honda XR 250 R
Home Logo
37 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
