Question about Emerson 26" Class LCD 720p 60Hz HDTV and DVD Player, LD260EM2
Ld260em2 DVD works but none of the manual remote buttons works and remote control will not work any thing on tv?
2 Suggested Answers
  • 14 Answers
SOURCE: LD260EM2 - Red light on but tv will not power on
PULL THE COVER THERE IS A FUSE THAT MAY BE BLOWN INSIDE
Posted on Sep 12, 2012
I have a sylvania HDTV/DVD and I can't get the remote to program! It's a dish network remote and the tv model # is LD155SC8!!! What codes should I try? (PS:I tried the codes in the manual and none if them...
I had the same problem with my remote that would not control the tv. I tried the codes that I had and none would work. I called direct tv and they had more codes and one of those worked
Apr 13, 2014 | DISH Network Televison & Video
Sep 12, 2012 | Emerson 26" Class LCD 720p 60Hz HDTV and...
Hey there, I've tried programming my large BrookStone television remote with many different online methods, but none of the different solutions are helpful to my TV remote. Do you have any advice?
If the codes do not work then the only other option is to do the following steps to PowerScan through the remotes codes to see which one will work. If none work then the remote does not accept your tv.
Step 1: Manually turn off the device you wish to program (TV, VCR, DVD)
Step 2: Press and hold the appropriate device key (TV, VCR, DVD) until the red LED illuminates. This indicates that the remote is in programming mode.
Step 3: Press and release the power button. The LED flashes once and stays ON. Indicating that the remote is in PowerScan mode.
Step 4: Press either CH+ or CH- button repeatedly until the device switches on. The CH+ button searches upward in the code list while the CH- button searches downward.
Step 5: When the device turns on, press and release the OK button to store the new code and exit.
NOTE: If you press the CH+ or CH- again after the device turns on, the device will not be programmed and you will need to repeat steps 1 - 5.
Step 6: Press any other operable button (VOL+ or VOL-). If the device responds,
Feb 08, 2011 | Brookstone 538744 Remote Control
Cannot program dvd player. unit does not fully answer commands from remote.
To program the DVD player's remote control to operate your TV, follow these steps:
  1. Turn on the TV, and then aim the DVD player’s remote control at the TV.
  2. Press and hold the [TV Power] button on the DVD player's remote control.
  3. While holding the [TV Power] button, use the number buttons on the remote to enter the two digit code assigned to your brand of TV.
Note 1: If your DVD player's remote control can be programmed to operate a TV, the TV brand codes will be listed in your owner's manual. If you don't have your owner's manual available, click here to go to the download center and download a copy.
Note 2: Many TV brands have more than one code. If the first code does not work, try the next available code.
  1. If the TV turns off, the code worked correctly and your remote control is now programmed. If the TV stays on, repeat steps 1 through 3 with a different code listed for your brand of TV.
Note: If none of the codes listed allows your DVD player's remote to control your TV, then the remote is not compatible with your specific model.
Let us know if you want something more else please accept the suggestion.
Thank You for contacting Fixya.com
Jun 11, 2010 | Audio Players & Recorders
Universal remote + Quasar TV = no luck. pls help!!
Do Research on the remote with the tv brand name in google. you will find something such as an manual.
Jan 05, 2010 | Televison & Video
Rmt-d187a
I have this remote for my dvd player as well. The manual for my player is at this site http://esupport.sony.com/US/perl/model-documents.pl?mdl=DVP-NS710H&region_id=1. However it does not give a code for my tv. I've tried a bunch of codes and none of them work. I've tried codes for other remotes that seem to be all the same for my tv and they don't work. But if you go to the site above and click on "Operating Instructions" the manual will pop up. Go to page 15 and the codes and instructions are there.
Jul 26, 2009 | Sony (RMT-811) Remote Control
FIOS remote
I am a FiOs Technician from Pennsylvania.. The most common occurence of this problem I encounter is when the TV is a dual-device.. Meaning that it is a TV with a DVD player or a VCR built into it.. Whenever this occurs, I do the 922 method using either the DVD or the AUX button on the remote instead of the TV button.
By the Way, if this works you must change the volume control to the other device using the 955 code in the Motorola manual afterwards in order to control the volume
I hope this helps
Jul 16, 2008 | Televison & Video
New - parental lock LOCKED and password will nowr work can't use DVD
Problems with V-Chip/Parental Controls
The rating limits don’t work
• For rating limits to take effect, you must lock V-Chip settings to activate them.
I don’t remember my password and I want to unlock the TV
• If you forget your password you can reset it. Enter 5898 as the password and then change it
to a new one.
Dec 06, 2006 | RCA 20F510TD 20 in. TV/DVD Combo
Emerson 26" Class LCD 720p 60Hz HDTV and DVD Player, LD260EM2 Logo
22 people viewed this question
Top Emerson Computers & Internet Experts
Stan Skaggs
Stan Skaggs
ray gallant
FireballXL55
Are you an Emerson Computer and Internet Expert? Answer questions, earn points and help others
