Question about ASUS WIRELESS ROUTER |WL-520G - RT (WL520G)
I want to change my passcode for my asus wireless router
How do i find my wep key
Most routers today no longer use the easily defeated WEP encryption. Most all use WPA/WPA2. Thar said, you must know the passcode as most routers will not display the code even internally (just shows a string of ******). The only thing you can do is go into router setup and change the passcode to something you know. But then all other devices attached to the wireless network must change passcode as well.
Aug 25, 2014 | Computers & Internet
Asus wireless router password change solusion
connect to your router via ethernet cable and open your web browser. In the address bar type which should bring up the router settings page. for user and password type in admin for both. Then navigate to the password settings and change it and save the changes.
Nov 09, 2012 | ASUS RTN10 wireless router
Just got my EEE PC yesterday and I am unable to wirelessly connect to my router at home. I can connect to other wireless networks with the pc and my router works fine with with other wireless connections...
Have you put mac access control on your router, if so turn it off? is the router g or n or b compliant and does your pc match? have you set the right security wep/wpa/wpa2? if using wep you may need to not use the passcode but the key 1 which is generated from it.
Aug 28, 2010 | ASUS Eee 4G Notebook
How to open asus wifi router home page?
In order to access the web interface of the router you should know the IP address of the router. Please try the following steps to check the ip address on the computer which is connected with the router (wired/wireless doesn’t matter).
1. Click on start the go to run and try cmd and click on ok.
2. Type ipconfig and press enter.
3. look for the default gateway numbers.
the default gateway is the address of the router. Open internet explorer and type http://default gateway numbers (for example
It should take you to the web interface of the router on which authentication is needed. The default user name and password is admin and admin.
Let me know if it help.
Aug 09, 2010 | ASUS WIRELESS ROUTER |WL-520G - RT...
Want 2 set a passcode
Is there any computer connected to the router ?
If not then you will need to connect the computer to the router.
Do not change any wireless settings on the router with the wireless computer.
you will need to connect the computer to the router with the Ethernet cable.
check the IP address of the computer.
open the router set up page of the router.
Here you can change the wireless settings of the router.
Now once you change the network anme and security on the router, you will need to connect to the wireless network on your wireless computers.
Click Here for step by step instructions
Jul 19, 2010 | Linksys Wireless-G WRT54G Router
I'm trying to figure out my network key for my router
log into the router to check/change the passcode. (example Linksys WRT54G)
1. plug a computer into one of the router ports.
2. open a web browser and go to
3. login (default is username: admin/password: admin)
4. go to 'wireless'
go to 'wireless security'
5. the passcode should be displayed, or you can edit it.
Dec 01, 2009 | Linksys Wireless-G Broadband Router
Need to secure wireless connection
1. Connect the computer to your Wireless router then using the internet explorer access the router gui 2. It is extremely important that you change the password for your router. Select a strong password using numbers and letters. This is the password that you will use to login and configure your router after this initial setup. 61e656e.jpg+
79ee205.jpg 3. Select a unique name for your wireless network. The name of your network is known as the SSID. This is what wireless users will use to identify which router and network they connect to. 94c0abe.jpg
Nov 17, 2009 | Linksys Wireless-G WRT54G Router
How do i change my settings
How to resed passcode on the WEP security code on a belkin 54g wireless router?
Mar 04, 2009 | Linksys Wireless-G Broadband Router
Computers & Internet Logo
32 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
