Question about WHITE-RODGERS DIV White Rodgers 1F86-344 Non-Programmable Thermostat, Hardwired or Battery Powered
Can not set the tempeture in the room - WHITE-RODGERS DIV White Rodgers 1F86-344 Non-Programmable Thermostat, Hardwired or Battery Powered
How or what setting do you turn on to get cold air
Make sure the thermostat is turned to below what the room tempeture is. Make sure that the unit is in the cooling and not just the fan.
Good luck,
Marty
Jun 20, 2014 | Arcticpro Ypc-07c Faac7 Portable Air...
I change thermostat, water pump, housing coolant sensor, but yet when i start driving the tempeture goes up and down and the heat gets kind of cool not all
poor coolant flow water pump? air lock in system? bring to operating temp shut down than open air bleed screws.
Jan 02, 2014 | 1997 Pontiac Sunfire
I installed the RTH 7400D thermostat according to wire direction for heat pump. I have wires C,G,Y,O,R,L AND THE L IS JUMPED TO AUX. THE BLOWER COMES ON BUT AFTER THE ROOM GET TO TEMPETURE THE UNIT SHUT...
did you set dip switchs on new stat for ht pump with electric ht back up if that is your type of heat. newer t stats might not have dip switchs but a sequence of programing steps to set up new stat to match your needs ps when set up correctly the fan will run for a few minutes after cycle over to discharge residual heat from unit n ducts .
Nov 04, 2013 | Heating & Cooling
Hello, The fan on the outside condensor (38tkb042300) runs for about 45 mins and stops. Turning it off and back on will produce the same results, might you help me understand what could be causing...
There are many possible reasons why it happens that way. Basically, when the unit have reached the desired room temparature,compressor stops as will as the condenser fan.Please try to set your thermostat at its coldest setting, if the fan at the outside condenser still stops, consider replacing your thermostat, it migth be defective.
Aug 12, 2011 | Carrier 38CKC042 Air Conditioner
My name is Sonny i have a question i just installed strip heat Rheem RXBH-1724A10J 10KW 208/240/1/60 and then tempeture ran up 3 degree and stop dose not ran anymore what wrong with that can you help me...
Check temp setting must be +5 degree than room temp and also in heat "mode".
Check heating sensor placed perfectly. If not fix it in it's place. As it's running for 3 degree, your wiring no fault will be there.
Jan 19, 2011 | Heating & Cooling
I have a kenmore elite electric dryer it is not generating hot air, its just room tempeture? Is this something I can possibly fix or should I just have it repaired?
Depends on your abilty to troubleshoot... Might be a bad temp sensor, might be the element itself, then again might be the controller all of which require you to disassemble and use a digital multi-meter to figure out what failed.
Peace,
J
Mar 09, 2010 | Dryers
Oven will not reach set tempeture. I set it for 350, but after 2 hrs it had only reached a tempeture of 230.
HI, You will need to check the oven sensor wires that link the actual sensor to the main control board. Make sure that the contacts are connected properly, and not loose, or corroded. If all the wiring checks out, test the sensor for the correct resistance readings.(you will need a multimeter for this test)
The most common oven sensor should be approximately, 1100 ohms when at room temperature. The others may be close to as follows:
100°F - 1143 ohms
200°F - 1350 ohms
300°F - 1553 ohms
350°F - 1654 ohms
400°F - 1753 ohms
500°F - 1949 ohms
If the sensor test is adequate, and the wiring is Ok at the control, this will lead to a failed control board. replace the control in this case.
Sensor location
The sensor is, generally, located inside the oven, mounted on the back wall, on the top right, or left corner. There will be two screws holding the housing on the back of the oven wall. Once the screws are removed, the sensor will need to be extracted from the back side of the unit.
Dec 13, 2009 | Ovens
Freezing at any tempeture
I ordered a new thermostat (about $40 with shipping) & installed it. It's pretty easy to replace. The fridge has been working fine since.
Jan 14, 2009 | Sanyo SR-4910M Compact Refrigerator
WHITE-RODGERS DIV White Rodgers 1F86-344 Non-Programmable Thermostat, Hardwired or Battery Powered Logo
Top WHITE-RODGERS DIV Heating & Cooling Experts
Lawrence Oravetz
Joe Lane
Are you a WHITE-RODGERS DIV Heating and Cooling Expert? Answer questions, earn points and help others
