Question about Pool & Spa
Gd 7005 manual
Pump 3 not working
Singer sewing machine model 7005, dog feed is not working. Where is the lever to adjust the dog feed.
The Singer Imperial 7005 does not have a feed dog lever. Instead there is a feed dog cover that gets placed over the needle plate. To remove the cover, raise the needle and presser foot. Open the slide plate, then lift up the front edge (closest to the bobbin) of the cover. Then pull the feed dog cover away from the sewing machine.
See page 10 of the manual; it's page 12 of the PDF. The manual is available at the Singer manual search page: http://www.singerco.com/support/instruction-manuals . The direct link to the manual is http://www.singerco.com/uploads/download/676_7005.pdf .
I hope this helps.
Sep 13, 2017 | Singer Sewing Machines
On leisurerite spa pool what does code 1-3 mean
If your system is equipped with a circ pump, it may be configured to work in one of three different ways: 1)
The circ pump operates continuously (24 hours) with the exception of turning off for 30 minutes at a time
when the water temperature reaches 3°F (1.5°C) above the set temperature (most likely to happen in very
hot climates). 2) The circ pump stays on continuously, regardless of water temperature. 3) The circ pump
will come on when the system is checking temperature (polling), during filter cycles, during freeze
conditions, or when the blower or another pump is on.
Dec 06, 2016 | Pool & Spa
How do I replace a fuel pump in a 1992 Nissan Hi Rider 2400 Bakkie
install a electric fuel pump pick up 2 -3/8 fittings cut the line
reconnect with 2 6" 3/8 rubber lines with clamps now find
the ignition wire that comes on when the key is on ground
the other side make sure its bolted to the frame or fender
the pump will now work
Sep 16, 2014 | Electric Eyeware Onan 1492592 Electric...
How do I activate the auto el on a Casio 350 1b
Hello there. I don't know what 'auto el' is but if it is not in the manual, it doesn't do it !!!!
Manual on the Casio GD-350-1b here http://www.casio-intl.com/asia-mea/en/wat/watch_detail/GD-350-1B/
On this page, 1) click 'operatiion guide' 2) agree to terms 3) download the pdf format manual.
Good luck
Sep 10, 2014 | Casio Watches
My lxi-h won't draw rinse aid through the pump
You need to replace the squeeze tube on the rinse aid pump
May 23, 2013 | Hobart Undercounter/Lxi Warewasher 24"W x...
Install GD 1200
Hi:
The GD-1200 is the hardware. This is the fax option that would need to be installed and configured by an authorized Toshiba Dealer. It is not sold directly to the public.
Jun 12, 2012 | Toshiba eStudio 281C
How do I connect Marantz AV7005 to Marantz SR9600
Remove the little black jumpers on the 9600 that link the pre amp section to the main amplifier inputs. They are the top row of rca inputs on the back. Using single rca cables from the pre out of the 7005 into the main amplifier of the 9600 connect all the channels you have wired speakers for, L,R,C, SL,SR, etc up to 7. Connect all your sources to the 7005 with whatever cables you have it doesn't matter. Turn off the 9600 volume and use only the 7005 to control the volume. It works perfectly giving an awesome amp a new lease on life. Good luck!
Oct 17, 2011 | Marantz Audio Players & Recorders
Pool & Spa Logo
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
