Question about Brother Office Equipment & Supplies
Unable to print 6A - Brother Office Equipment & Supplies
3 Suggested Answers
caroldon
  • 17130 Answers
SOURCE: my problem is that my
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer ONLY WHEN PROMPTED, to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Activate head cleaning before a test is taken. Sometimes it is possible that the head is not reacting to the need of the PC command or can be an issue with ink drying or poor ink cartridge contacts. Sometimes the power supply unit must be checked as a poor SMPS unit can deliver low voltage and cause issues to the printer function. Check all the leads and connections of the mother board , the tags to the ink cartridge. Also check the mechanical settings of the ink cartridge , if jammed or tight remove motor and manually free the drive before it is set back.
Thank you for using Fixya
Posted on Sep 17, 2011
caroldon
  • 17130 Answers
SOURCE: printer write on the screen
Unable to program Universal Remote (NSE URC22C-6A )to Medion TV
find another remote where medion tv are included in code programming list.
Dec 04, 2016 | Universal Televison & Video
Need audeo driver
Vista and XP drivers are available here - http://support.toshiba.com/support/modelHome?freeText=1484717. I am unable to find Windows 7 or later.
Jul 06, 2014 | Toshiba Satellite P105-S6114 Laptop DC Car...
I have a Brother DCP 8020 Multi printer. Im getting machine error code A6. After replacing the fuser
This is what is written in my service manual for Error Code A6:
Error code 6A
Print Unable 6A
Turn the power off and then back on again.
Fuser unit failure (The side thermistor does not detect 60degreesC within the specified time.)
Dec 05, 2012 | Brother DCP-8020 Laser Printer
Error message on mfc-8890dw unable to print 6A
Hello Robert! Welcome to FixYa!
Unable to Print 6A error in Brother Printer is an error of Fuse Failure.It is due to problem of Fuse Assembly. This error is usually solved by the following procedure:-
1. Turn off printer
2. Hold down MENU button on front panel and turn on power while continuing to hold.
3. Release button after 5 seconds (after the Please Wait message)
4. If error still occurs:
5. Press 91
6. If error still occurs:
7. Press 99
If above procedure doesn't work then sometimes it solve by given procedure:-
1) Unplug the printer power cord.
2) Hold down the menu key while plugging in machine at same time.
3) Enter 99 while holding down menu key
4) After menu says " wait" push the stop/exit button to get out of the maintenance mode.
If that does not work too, it means that the fuse assembly must be replaced. If your printer is still in warranty then claim the warranty. If it is out of warranty then you have to contact authorized service center of Brother Printers to replace the Fuse Assembly.
I hope this solution helps you and you have clear picture in your mind now
Let me know if you have any confusion in your mind.
Sir, Your Rating as FIVE Stars for this solution and words of appreciation will be esteemed
Thank You for taking my service
Concerned: Muhammad Uzair
Team : FixYa
Jan 03, 2012 | Office Equipment & Supplies
Brother 7450 unable to print error 6a Problem
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Activate head cleaning before a test is taken . Sometimes it is possible that the head is not reacting to the need of the PC command or can be an issue with ink drying or
Jun 25, 2011 | Office Equipment & Supplies
Brother HL-4040 Laser Printer -- Print Unable 6A Error
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 05, 2009 | Brother HL4040CN Laser Printer
18 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
