Question about Garmin nuvi 260W GPS Receiver
My garmin nuvi 1410 keeps saying locating satellites
SOURCE: Garmin NUVI 660 - can not locate satellite
These are the instructions I got from Garmin as how to do the Master reset:
Here are the steps to backing up the favorites on your unit and then performing the master reset. First, you’ll want to plug your unit into your computer via USB cable. Once it’s plugged in, you’ll want to go to My Computer in your start menu or from your desktop and double-click on the Nuvi. At this point, you should see a few folders, but you’ll want to double-click on the Garmin folder. Here, you’ll want to look for the “GPX” folder and you’ll double-click on that. In this folder, you’ll want to drag and drop the file titled “Current.gpx” to your desktop to copy it. Now you are able to do the master reset.
To do that, you’ll want to start with the unit turned off and press and hold on the upper left hand corner of the touch screen. While holding the touch screen, power the unit on and continue to hold. You should get a message that asks if you really want to go into maintenance mode and you’ll want to select “Yes”. At this point, you’ll want to select “clear user data” and then select “Yes” when it asks you if you really want to clear user data. Now, the unit should restart and you’ll want to take it where it has a clear view of the sky and let it sit for up to 30 minutes to acquire satellites. If after 30 minutes it does not acquire satellites, you can go ahead and reply back to me.
Either way, once we have your unit back working again, you can follow the first set of steps again to get to the GPX folder and drag the “Current.gpx” folder from your desktop to that folder on your unit. This will replace your favorites.
Posted on Oct 07, 2008
SOURCE: Garmin nuvi 350-can not change the location it is stuck on
you may need to reset it, as in resetting the c340, turn off and then press back on again, if this does not work maybe the reset button is in the same place as it is on my c340, instructions for the c340 is as follows: place your thumb nail in the groove located under the Garmin logo on the face plate, gently pull off the face plat, press the reset button, turn the unit back on and hopefully it will operate normally
Posted on Dec 29, 2008
  • 40 Answers
Try this and see if it fixes your problem....first disable bluetooth then follow these steps.
1. Power off the unit.
2. HOLD down the power button and you will see "Pre Boot Mode" appear on the lower part of the display. KEEP HOLDING the power button down and the display will flicker, do this until the pre boot mode message disappears. This seems to take a long time (60 seconds at least).
3. Once the pre boot mode message disappears release the power button and your device will perform some activites to recover from the above problem.
Posted on Jan 03, 2009
bunnydawg
  • 5158 Answers
SOURCE: garmin nuvi 205 can't find satellites
you can get the manual at www.garmin.com
you'll also need to get yourself a usb cable... the normal end for the computer and i believe the other end is called a mini b connector.
Robert
please take a moment to rate this solution.. thanks
Posted on Feb 02, 2009
sharcnet
  • 2130 Answers
SOURCE: garmin nuvi can't get satellite signal
Please see this link:
http://www.sharc.net/gps_antenna_repair.htm
- Jim
Posted on Dec 23, 2009
I don't have Satellite signal! I tried to acquiere satellite signal with my Garmin Nuvi 1350! The screen always says locating satellites but nothin happens! The satellite bars are not green!What can I do...
Try fully charging the unit and leaving it stationary for about 20-30 minutes if you still dont lock satellites try giving the unit a firmware updates using Garmins WebUpdater software here is a link.
http://www8.garmin.com/products/webupdater/howtoinstall.jsp.
Hope this helps!
Feb 24, 2011 | Garmin nuvi 350 GPS Receiver
Tip
Garmin Nuvi 1490 Webupdate Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi 1245...
Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi 1245 , Nuvi 1250, Nuvi 1255, Nuvi 1260
Models: Nuvi 1300, Nuvi 1300, Nuvi 1310, Nuvi 1340, Nuvi 1350, Nuvi 1370, Nuvi 1390
Models: Nuvi 1410, Nuvi 1440, Nuvi 1450, Nuvi 1490
Does your Garmin Nuvi 1490 GPS get stuck or freeze at startup, or when loading maps?
Looking to reflash the firmware / system software for your Garmin GPS device?
Replacing the brains of your Garmin GPS is the surest way to resolve freezing, hanging, and erratic behavior. Keeping the system software and firmware in your Garmin GPS current and up-to-date is also the best way to keep it performing well.
Your GPS may not start properly at all, and display a 'System Software Missing" message. This tip will describe how to restore your Garmin Nuvi GPS system software using Garmin Webupdater.
  1. The first step is to download the WebUpdater software.
  2. Plug in your Nuvi GPS into your PC with the USB cord.
  3. Run the WebUpdater program to install it to your computer and update the system software of your GPS.
Your Garmin Nuvi should now be running as good as new.
I hope that helps.
____________________________________
Garmin Nuvi 1490 Manual Download
Garmin Nuvi 1490 QuickStart Download
Garmin Nuvi 1490 Favorites Backup
Garmin Nuvi 1490 Hard Reset
on May 27, 2010 | Garmin nuvi 1490T GPS Receiver
Tip
Garmin Nuvi 1450 Webupdate Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi...
Does your Garmin Nuvi 1450 GPS get stuck or freeze at startup, or when loading maps?
I hope that helps.
________________________________________
Garmin Nuvi 1450 Manual Download
Garmin Nuvi 1450 QuickStart Download
Garmin Nuvi 1450 Favorites Backup
Garmin Nuvi 1450 Hard Reset
on May 27, 2010 | GPS
Tip
Garmin Nuvi 1450 Webupdate Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi 1245...
I hope that helps.
on May 27, 2010 | Garmin nuvi 1450 GPS Receiver
Tip
Garmin Nuvi 1390 Webupdate Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi...
Does your Garmin Nuvi 1390 GPS get stuck or freeze at startup, or when loading maps?
I hope that helps.
Garmin Nuvi 1390 Manual Download
Garmin Nuvi 1390 QuickStart Download
Garmin Nuvi 1390 Favorites Backup
Garmin Nuvi 1390 Hard Reset
on May 15, 2010 | GPS
Tip
Garmin Nuvi 1350 Webupdate Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi 1245...
Does your Garmin Nuvi 1350 GPS get stuck or freeze at startup, or when loading maps?
I hope that helps.
Garmin Nuvi 1350 Manual Download
Garmin Nuvi 1350 QuickStart Download
Garmin Nuvi 1350 Favorites Backup
Garmin Nuvi 1350 Hard Reset
Tip
Garmin Nuvi 1240 Webupdate Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi 1245...
Does your Garmin Nuvi 1240 GPS get stuck or freeze at startup, or when loading maps?
I hope that helps.
Garmin Nuvi 1240 Manual Download
Garmin Nuvi 1240 QuickStart Download
Garmin Nuvi 1240 Favorites Backup
Garmin Nuvi 1240 Hard Reset
Tip
Garmin Nuvi 1210 Webupdate Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi 1245...
Does your Garmin Nuvi 1210 GPS get stuck or freeze at startup, or when loading maps?
I hope that helps.
Garmin Nuvi 1210 Guide Download
Garmin Nuvi 1210 QuickStart Download
Garmin Nuvi 1210 Favorites Backup
Garmin Nuvi 1210 Hard Reset
Tip
Garmin Nuvi 1200 Webupdate Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi...
Does your Garmin Nuvi 1200 GPS get stuck or freeze at startup, or when loading maps?
I hope that helps.
Garmin Nuvi 1200 Manual Download
Garmin Nuvi 1200 QuickStart Download
Garmin Nuvi 1200 Favorites Backup
Garmin Nuvi 1200 Hard Reset
on May 14, 2010 | GPS
Tip
Garmin Nuvi 1300 Webupdate Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi...
Does your Garmin Nuvi 1300 GPS get stuck or freeze at startup, or when loading maps?
I hope that helps.
Garmin Nuvi 1300 Manual Download
Garmin Nuvi 1300 QuickStart Download
Garmin Nuvi 1300 Favorites Backup
Garmin Nuvi 1300 Hard Reset
on May 13, 2010 | GPS
Garmin nuvi 260W GPS Receiver Logo
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
