Question about GE FUF14SVRWW Upright Freezer
GE Freezer FUF14SVERWW
Freezer stop running and displays a symbol F and 0
2 Suggested Answers
walesarumi
  • 6993 Answers
SOURCE: GE fuf14sverww Running continuously, bottom stuff
It is a faulty thermostat. An open thermostat defaults to a high value, so it does not shut off. If it was a bad compressor, or low in freon, it would not "get ice cold". If it is low on freon, the low pressure switch would not let it start up.
The defrost timer either runs normally (cycles on and off cold) or is in defrost mode (heater elements turn on to temporarily heat the freezer in order to remove frost). Anyway, It is not the defrost timer if it "gets icy cold".
Unplug your Refrigerator remove the thermostat and take it to your local parts store. Hopefully it is cold outside where you live, if so you may put your food in a cooler outside your door until you replace the thermostat which you will find is an easy task.
Regards.
Posted on May 13, 2011
The upright frigdiare freezer displays -10 degrees and runs continusly i couldnt set it to 0
Good Afternoon Friend,
I understand your Frigidaire freezer, model# LFFH21F7HWJ, is displaying -10 degrees and runs continuously. I also see that you were unable to set it to 0 degrees. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Sometimes there can be a miscommunication between the different boards inside your appliance. Restore power and try the temperature to 0 degrees. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jul 02, 2014 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
GE Freezer stopped working
Obviously, the compressor is not running. Confirm the presence of power to the compressor itself. If it is getting power and unit does not run, you have an open motor winding OR if you have a start capacitor the latter could be defective. Let's hope that you have the capacitor because they go bad and are a lot cheaper to replace than the compressor!
Jan 19, 2014 | GE 7 cu. ft. Chest Freezer FCM7DR
Freezer runs for approx. four days with operation normal. Then the temp. panel of front door displays a symbol that looks like a short L followed by a period. Then the temp. gauge and the interior light...
From what I read, the "L." that you see on the control panel indicated that the controls have been locked. According to the manual if you hold down the "alarm reset" button for 3 seconds the "L." will disappear allowing you to control the temperature again. I don't as of yet know what is causing your overall problem though...
Nov 04, 2013 | GE FUF14SVRWW Upright Freezer
Temp display reads 92 (hi temp) but the interior temp is 0.
No. Sounds like the intern temp sensor is bad, missing, or not connected. 92 is probably the max reading it can display. The unit will probably operate continuously, be much to cold, and cost a ton to operate. I assume you bought this from Sears. Call them to replace the freezer. Should be no problem.
Oct 24, 2012 | Kenmore 20.6 cu. ft. Upright Freezer 2809
What is the normal temperature setting for a ge upright freezer, dial from 6 to off?
Your need to use a thermometer and adjust the dial till you have between 0 and 10 degrees.
Jul 10, 2011 | GE 20.3 cu. ft. / 575 liter Upright...
My GE chest freezer stop freezing. the light is on no sounds from the freezer. what could be the problem?
There are many reasons why is not working. 1.if the compressor is not running, Relay or overload burn, they are attached to the side of the compressor 2, thermostat may not be working. 3. if all of the part i mentioned are working fine your compressor may need to be replace.4 if the compressor runs but still don't get cool, there is a internal gas leak inside the freezer. The only way to find out theses issues, is by having the necessary tools and experience.
Jan 17, 2011 | General Electric Chest Freezer FCM7SU
Frigidaire freezer LFFH21F7HWG. the temp gauge outside registers only 0. I have 3 thermometers inside all register 18 degrees. ice cream is soft in the box. machine was delivered last Tuesday. the freezer...
these freezer are designed to run about 70 percent of the time the temp displayed can vary by +/- 3 degrees..make sure you have fan operation in the freezer and the air flow is not blocked or restricted. also make sure that the door is sealing properly
Aug 31, 2010 | Frigidaire 20.6 cu. ft. / 583 liter...
I was just given a ge chest freezer model # cb10 dk serial number vv186793. i cleaned it up and plugged it in about 5 minutes later it started buzzing . i turned the control to the lowest setting (0). and...
switch on and leave it to freeze.approx 24hours.buzzing could be compressor working overtime to get cold.or in fact the freezer is not on a level surface.
Mar 02, 2010 | GE Freezer  14.8 Cu. Ft. Manual...
GE FUF14SVRWW Upright Freezer Logo
123 people viewed this question
Top GE Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
Victor Nwachukwu
Victor Nwachukwu
Are you a GE Freezer Expert? Answer questions, earn points and help others
