Question about Sentry Fireproof Safe
Need factory code for sentry S3710 - Sentry Fireproof Safe
5 Suggested Answers
SOURCE: sentry codes v260
You should have received two skeleton keys when you bought the safe. They will open the safe without the key AND without the code. If you don't have it, the only solution is to get help from Sentry. By following the instructions below, they will send you a skeleton key for your safe. First, find your safe’s Serial Number. The Serial Number is printed on the small label on the right side of safe (outside). Send this, a notarized letter(last name must be different) stating you are the safe’s owner, and a check or money order or $8.00 (U.S. funds) to:
Sentry Group Dept. 200
882 Linden Ave
Rochester, NY 14625-2784 If using a credit card (Visa/MasterCard only), call 1-800-828-1438.
Posted on May 27, 2010
  • 76 Answers
SOURCE: Need factory code for Sentry Safe Model 1610 -
If you need your lost combination, you must send a notarized letter stating you are the owner of the safe. The link below will tell you everything that you will need to get your combination back:
http://www.sentrysafeshop.com/Lost-Combination-Sentry-Safe-Combination-p/lost%20combination.htm
Posted on Jul 06, 2010
SOURCE: wats the factory code for a sentry s3807...
First, find your safe’s Serial Number. The Serial Number is printed on the small label on the right side of safe ( on paper tag near hinge) or under handle. just note your model # and the serial#. A good locksmith should be able to help you with It
Posted on Aug 09, 2010
  • 2509 Answers
SOURCE: i have a sentry safe model A3821 need factory code
The factory code is printed on the first page of your manual. If You don't have the manual you have to contact sentrysafe who will help here: https://www.sentrysafe.com/ContactUs/Call_Or_Email_Us
Posted on Jan 17, 2011
How do I change the combination on SENPL048E sentry portable security safe
Open your Sentry safe by typing the five-digit factory code (found in your owner's manual) on the keypad. It's always a good idea to change your combination while the safe is open, so that you don't inadvertently lock yourself out.
  • Delete any existing codes by pressing the "P" key and entering the factory code, followed by "00000." On older safes, press the "PROG" key and entering your factory code twice to delete old codes.
  • Press the "PROG" or "P" key again on your Sentry safe's keypad.
  • Enter your safe's five-digit factory code.
  • Enter a five-digit code of your choosing within 5 seconds. This is your user code. While the factory code cannot be changed, your user code can be changed as often as you like, and that should be your primary code to open the safe. Only you should know your safe's factory code.
  • Mar 24, 2016 | Home Security
    I have lost the combination for my safe model V330 my model number V330 Sentry safe
    • Open your Sentry safe by typing the five-digit factory code (found in your owner's manual) on the keypad. It's always a good idea to change your combination while the safe is open, so that you don't inadvertently lock yourself out.
    • Retype the user code to verify it is working, and then close the safe.
    Mar 19, 2016 | Sentry FIRE-SAFE Combination Safe DS3431,...
    What is the factory code for a Sentry SFW205GPC safe?
    You must call (800) 828-1438 for combination retreivals.
    If you need your combination, you must send a notarized letter stating you are the owner of the safe. (Note: the owner\'s last name must be different from that of the notary public). For locations that require a raised notary seal, use a pencil to shade the seal to insure that it is visible.
    The notarized letter needs to include:
    1. Your name, address and phone number.
    2. The model number and serial number from your safe. The serial number is typically found on the front of the door, lower right corner on a small sticker; the right outside wall of your safe; or under the keypad/dial on the front of safe.
    3. Please indicate how you would like to receive your combination. Options include first class mail, e-mail or fax. Your letter must clearly indicate which method you are choosing to receive your combination, as well as the mailing address, e-mail address, or fax number to which it should be sent. Note that failure to indicate the method in which your combination should be returned to you will result in delays to the process.
    4. Special Circumstances
      • In the event you need to open the safe after the owner is deceased, your notarized letter will also need to include that you are now the owner or executor of the estate and need access to the safe. You must also include a copy of the ***** certificate.
      • If you hold Power of Attorney for the safe owner and need to access the safe, your notarized letter will also need to include that you are acting on behalf of the safe owner. You will need to include a complete copy of the Power of Attorney documentation to confirm that you have the authorization to act on their behalf in this type of circumstance.
      • If you also need a key for your safe, you can order them online:
        REFERENCE THE ACTUAL KEY LOCK (WHERE THE KEY IS INSERTED) FOR SMALL SAFES AND CHESTS
        For Personal, Home and Home/Office Safes: (Model numbers will begin with: S0 (S0310, S0400, S0407, S0408, S0409, S0410), S3 (S3300, S3310, S3401, S3410, S3417, S3421, S3460, S3467, S3470, S3710, S3807, S3870, S3877, S3910), S4, S5; I0, I3, I4, I5; A3, A4, A5; J3, J4, J5; L0, L3, CS, CSW (CSW3460), DA (DA3831, DA3930), DS (DS3410, DS3431, DSW5781), KSW, MS, MSW, OA (OA3810, OA3821, OA5848), OS (OS0407, OS0410, OS0810, OS3407, OS3421, OS3470), SC, and X (X031, X075, X105, X125)): Indicate your model number and the safe serial number is found on the front right-hand side of the door, between the hinges.
    Keys Sentry Safe Replacement KeysLost Combination My Sentry Safe Combination Sentry Safe Shop Keys Sentry Safe Replacement Keys Lost Combination My Sentry Safe Combination Sentry Safe Shop
    Feb 10, 2015 | Sentry Fireproof Safe
    How do I open a sentry s3877 safe when the battery is dead and safe is closed
    The factory code combination to your electronic lock will remain in the memory of the unit - even if the batteries go dead. Any use programmed codes will be lost if the batteries lose power. The Sentry programmed factory code is always your default code.
    If you do not know your factory code, you can follow this link for your combination retrieval:
    Sep 23, 2012 | Sentry Fireproof Safe
    Lost factory code for sentry safe model #d8W5840
    did you ever find the factory code? I lost mine also. if you have the factory code for this model please message me on facebook.com/vernhartjr
    Sep 09, 2012 | Sentry Safe Sentry Fire-Safe Combination...
    We have a S3877 Sentry safe. The battery appears dead so I can't use the code. I also have the key but since the battery is dead it is no help. What can I do?
    Dec 07, 2010 | Sentry Fireproof Safe
    Need factory code for Sentry Safe Model 1610 - know its 5 digits but cant remember - never changed it from factory code but cant find the darn owners manual!
    Jun 13, 2010 | Sentry Fireproof Safe
    Lost codes
    would you know the factory recovery code for sentry 1610 as
    i lost it or it is locked in my safe. My battery has been dead
    for some time and I think it lost it's memory.
    Jul 17, 2009 | Sentry Fireproof Safe
    Need to open a Sentry keyless combination safe
    First, has the factory combination been changed? Sentry has the code for the factory combination that they can supply you.
    If the factory combination has been changed to something else, then Sentry won't have it.
    In that case you need to ask Sentry for a 'reset' code combination. There is (at least) one back door to your safe -- a reset code.
    The reset code will not tell you what your combination is, it will simply reset the combination to the factory combination.
    You can take it from there.
    Now, this isn't as hard as it may sound. There is an actual department that handles this at Sentry because you aren't the only one that cannot open his safe.
    They'll want some proof of ownership, some $$ for the service, the safe serial number, and probably a notarized form claiming that the safe is yours.
    Get 'hold of Sentry on the web and the rest is just process.
    BTW -- this is exactly what the locksmith would do.
    Apr 10, 2009 | Sentry Fireproof Safe
    Sentry Fireproof Safe Logo
    94 people viewed this question
    Top Sentry Home Security Experts
    Jim London
    Jim London
    Computer Repairing
    Computer Repairing
     Brian Main
    Brian Main
    Are you a Sentry Home Security Expert? Answer questions, earn points and help others
