Question about Hotpoint First Edition FEW12 Front Load Washer
I had a blockage at the outlet which i have now cleared. however when i select a programme and switch it on the machine is only displaying the 'programme end/rest' light. tried resetting but no joy - any ideas?
5 Suggested Answers
murdozzz2
  • 75 Answers
SOURCE: Display panel (cont.)
hi there try pressing and holding the start button for about eight seconds
Posted on Dec 10, 2007
barkencoa
  • 3463 Answers
SOURCE: water not pumping out
Filter is located at bottom rear right of washer, inside large black hose.
Remove lower rear panel to gain access.
Please rate my solution.
Thanks.
Posted on May 31, 2009
barkencoa
  • 3463 Answers
SOURCE: will not spin
You probabl;y need to clean filter.
Remove lower rearcover of washer.
Remove large black hose fastened to bottom of drum.
Remove and clean filter inside hose.
Remove hose onto pump, and check for obstruction here and in the pump.
Thanks.
Posted on Nov 19, 2009
barkencoa
  • 3463 Answers
SOURCE: I get a message saying check outlet pipes. If
If you need to clean the filter, then remove the lower rear cover.
Remove large black hose fastened to drum.
Remove hose onto pump, and check for blockage or obstruction here, and check inside the pump as well.
Hope this helps with your prob, Good luck.
Thankyou.
Posted on Nov 26, 2009
I have Model AWZ410 Washing machine, the washing cycle now takes up to 6 Hours!
i have experienced a machine doing this it was caused by the outlet hose pipe not alined it was syphoning water intermittently so check the hose outlet. 2nd
the wash heater may be open circuit causing the wash cycle to stop, the timer is then manually turned to continue washing .3rd check the pressure switch hose for blockage by taking it off the switch and blowing down to clear any blockage.
Feb 17, 2015 | Whirlpool AWZ410 Front Load Washer/Dryer
Hi, we have a AEG Lavamat 74630. It didn't empty last time we used it so we checked the drain and took out a small coin. It displayed error E10 or E20 at the time. I've tried to use it again and it is...
Easy solution, your pump filter is blocked. There is usually a tube behind a panel at the bottom of the machine, undo this and drain into a suitable container, then unscrew the drain plug and clear the blockage (usually fluff or sweetpapers!). This is probably in your handbook under emergency emptying/drain pump clearing. Beware lots of water can come out!!
Feb 07, 2008 | Washing Machines
How do i reset washing machine AEG 64840
You can choose the right programme for any type of laundry following the descriptions on the washing programme tables (see «Washing Programmes»).
Turn the programme selector dial to the required programme. The programme selector determines the type of washing cycle (e.g. water level, drum movement, number of rinses) and the washing temperature according to the type of laundry.
The pilot light of button 8 starts blinking.
The selector dial can be turned either clockwise or anticlockwise. Position "0" to Reset programme/ Switching OFF of the machine.
At the end of the programme the selector dial must be turned to position "0", to switch the machine off.
If you turn the programme selector dial to another programme when the machine is working, the yellow pilot light of button 8 will blink 3 times and the message Err is displayed on the display to indicate a wrong selection. The machine will not perform the new selected programme.
Dado
Jan 15, 2015 | AEG Washing Machines
My Whirpool Duet front loader will begin a wash cycle, but stops when cycle switches to rinse with water in the drum. Door remains locked & light by the 'wash' flashes 9 times...
when the machine is stopped can you empty the residue water that remains by the programme selector? if not check for blockage in the pump(coin), the hose internal blockage ,or at the outlet under sink. I hope this help
Jan 15, 2015 | Whirlpool duet Washing Machines
Err code displayed and fails start
or counter-clockwise. The green pilot light of the button
9 starts flashing: the appliance is now switched on.
when the appliance is working, the red pilot light
of the button 9 will flash 3 times and the message Err is displayed to indicate a wrong selection.
The appliance will not perform the new selected programme.
• To switch the appliance off, turn the programme selector
dial to the position .
To cancel or change a running programme, switch the
appliance off by turning the programme selector dial to the
position
. Select the new programme by turning the selector
to the desired programme. Start the new programme
by pressing the button 9 again. The water in the tub will be
not emptied out.
Dado
Sep 25, 2014 | Zanussi Washing Machines
My machine never complete the washing cycle just stop and show Error 2 on display screen
Sounds like there is a blockage in the outlet pipe. Check the outlet is clear.
Mar 13, 2011 | Microwave Ovens
My LG Intellowasher does not finish programme.
Switch off and restart. Or circuit problem of the micro controller.
Mar 29, 2010 | Washing Machines
My Hotpoint Ultima Washing machine - When I switch it on all the lights keep flashing and I can't get rid of them !! When the machine then starts the cycle it still flashes but then stops half way and says...
I would advise you to check the drain outlet hose for a possible blockage, or the pump itself could be blocked or faulty.
Drain any surplus water in to a bucket or similar before removing hose or pump.
Also try resetting washer if there is a reset button, hold it in for at least 3 seconds, this should clear any programme held in the memory.
Hope this helps.
Feb 01, 2010 | Hotpoint Ultima WF860 Front Load Washer
Kenmore 70 series Washer will not drain or go into the spin cycl
There is a pressure switch that inhibits the machine from doing something stupid like spinning with a load of water in it.
Quick test is to blow hard down the outlet pipe, put a tissue around it to protect you mouth
If you hear air bubbles inside that machine it meand there is not a major blockage.
If there is a blockage such as a sock or underwear then the hoses need to come off to clear it
Take out the filter and see if there is a coin or a hairpin or similar holding back the impeller of the pump.
If you can reach the impeller with your finger see if you can turn it (Or use a skewer)
If air goes through and the impeller turns then it is either the programmer or the pump coil.
To fix that you need a test meter and some knowledge
May 21, 2009 | Kenmore 22422 Top Load Washer
Hotpoint ultima wt741
washing machine WT741 ultima all light are flashing and it won't do anything else
Nov 12, 2007 | Washing Machines
Hotpoint First Edition FEW12 Front Load Washer Logo
18 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
