Question about Cell Phones
Recheck normal boot ptr mcode 0 - Cell Phones
Advent will not BOOT
The BOOT.INI file may be corrupt. Boot to a command prompt and rename original file c:\ren boot.ini boot.tmp. Now type edit. and insert the following script.
[boot loader]
timeout=30
default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /fastdetect
Save as boot.ini. Alt key gives you the menu options
You can also create the file elsewhere and copy to c:\ Remember to rename original.
Note! This is a single partition standard from factory configuration.
Oct 25, 2012 | Computers & Internet
880 ptr turns on all lights come on but nothing else happens
restart your printer and if it also creates the same problem then just reinstall the drivers it will work for you....
Jan 06, 2012 | Texas Instruments TI 880 Matrix Printer
I have a Dimension E521 and i get a crash wit a stock vid card
uninstall your video driver then update your driver for your stock video card
Oct 04, 2009 | Dell Dimension E521 AMD Athlon 64 X2...
My dell E521 is now getting STOP errors after installin a video c
there is an IRQ conflict(internal adressing all the hardware parts)
you may want to set all the IRQ options in BIOS to auto and let the BIOS handle the IRQ adressing, disable the plug'n'play OS feature too so that the computer hardware manages the IRQs instead of windows. The blue screen is a sign that windows is causing problems, but done the way described this no longer will appear.
good luck
Sep 29, 2009 | Dell Dimension E521 AMD Athlon 64 X2...
Power supply specification
the zebra part number is 105925G-002
Its auto-switching 100 ~ 240 Volts AC, 50 ~ 60 Hz external power supply
Phone: 44 (0) 1772-693-069
FAX: 44 (0) 1772-693-046
email: repairupdate@zebra.com
Jul 12, 2009 | ZEBRACARD,P120i COLOR CRD PTR,...
BSOD
Go here or here. Follow the instrucitons...
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
May 27, 2009 | Microsoft Windows XP Professional for PC
I don't have the installation disk to install my Lexmark Z610 Ptr
You should be able to find it in the Lexmark Australia's site. Not exact model but close: Z611.
http://support.lexmark.com/perl/support/support.cgi?ccs=15:1:0:0:0:0
Select Consumer Inkjet Printer, Page 4 and you'll find the Z611, when looking at the drivers they provide, it seems to be for Z600 series.
Good Luck!
Apr 12, 2009 | Office Equipment & Supplies
Hi there raysag..need ur help regarding my nokia 6070
IF THAT MCODE DID NOT WORK THEN YOU WILL HAVE TO TAKE THE PHONE AND HAVE IT RESET AT A MOBILE REPAIR STORE
Sep 05, 2008 | Nokia 6070 Cellular Phone
Hi!
SC458 PTR pressure
mechanism H.P.
detection error
• When the PTR pressure
mechanism does not
stop its H.P. after 15
seconds from the PTR
lift motor starts to return
to its H.P.
• H.P. detection sensor
does not on within 7
seconds after the PTR
pressure movement
starts.
does not off within 7
pressure release starts.
• Defective PTR lift motor
• Defective H.P. sensor
• Dirty H.P. sensor
feeler
• Defective main control
board
1. Make sure that sensor harness is properly
connected.
2. Clean the sensor, replace it if necessary.
3. If the sensor feeler is broken, replace it.
4. Replace the PTR lift motor.
5. Replace main control board.
Hope this is what your looking for
Thanks J
Jan 05, 2008 | Office Equipment & Supplies
Cell Phones Logo
50 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
