Question about Yamaha RXV371
I hooked up my wii on av1 with a component cable with audio on audio 1 and i have sound but no picture.
I tried using the av1/audio1 and av2/audio2 combinations but I only get audio. Never any video after hooking up the Nintendo Wii. It works ok if I just hook it up to the TV but no picture thru the receiver.
    Sergeant:
  • 166 Answers
If I am reading this right, you are only hooking up one cable for audio. There is another cable needed for video. This jack is normally color coded yellow and labeled video out/in. You can use your audio cable to try this and then you will picture but no audio.
Posted on Feb 17, 2014
SOURCE: no picture from wii
The RX-V800 switches the various video signal types separately.
Since you are feeding S-Video to the TV the composite (yellow) input from your Wii is not going anywhere.
If you cant get S-Video output from the Wii then I'd suggest a simple Composite to S-video adaptor plug ($5 say). It worked for me with a Game Cube.
Cheers
BJ
Posted on Apr 27, 2009
MNfisherman
  • 11896 Answers
SOURCE: Tried to hook up a Wii to a Yamaha receiver and it
It is very possible the S cable is giving you problems. Is the receiver on the right input channel? Have you tried RCA's instead?
Posted on Dec 25, 2009
  • 127 Answers
SOURCE: RX-V465 output HDMI 1 will work but HDMI 2-4 won't
This receiver has only one HDMI output, but 4 HDMI inputs. If some inputs don't work, try connecting the equipment (DVD for example) to HDMI input which works with other equipment....
For the RCA (composite) video input - it won't work, because this receiver don't have any video processing circuit.
So HDMI input video goes to HDMI outout connector.
Composite (RCA) video input goes to Composite outout and no other video output.
S-video input goes only to s-video output.
Posted on Mar 02, 2010
SOURCE: I have a Yamaha Rx-v367.
I don't think the Wii outputs an RGB signal, so you may not be hooking it up to the correct port. But in any case, if you look on the left side of page 13, it appears that this unit will not convert from one signal type to another, only pass them through to the matching output port. I'm still trying to verify that this is the case - if so, it's pretty disappointing because then you need to switch both the audio and TV inputs to change from one source device to another.
Posted on Dec 29, 2010
SOURCE: I have a Yamaha Rx-v367. I have the Wii console
IN SAME SITUATION, EVEN WENT TO RADIO SHACK..NO SOLUTION, BUT WHEN I GET ONE, WILL POST.
Posted on Jan 02, 2011
Have satelite as AV1, Wii as AV2 - hooked DVD player up as component 1 using RCA plugs but it is only black and white and very grainy.
Connect the yellow RCA jack, which is actually called composite video, not component, to the DVD. If it's component, it's the wrong jack and you'll need the additional 4 cables to satisfy a component connection for HDTV.
Dec 23, 2010 | LG 32LG30 32 in. LCD HDTV
No colour
Hi, Definitely a TV issue for me. Changed Wii to another input on TV and resolved situation. Need now to check how to get my TV to recognize colour on AV2 & 3 because I prefer to keep DVD input as AV1!
I had to use the (RCA) video inputs and not the component inputs. These are the ones made for video games. If you want to use the component input (Component cables are Red,White Red, Green, Blue). If you don't have any, you should be able to purchase them at your local electronics store like Radio Shack or Best Buy. Hope this helps, read below:
TV (This is your cable connection or TV; coax)
Component 1 (Must use component cables for this input/output; Red and White for audio, Red, Blue, Green for Video)
Component 2 (Must use component cables for this input/output; Red and White for audio, Red, Blue, Green for Video)
HDMI 1 (HDMI Cable)
HDMI 2 (HDMI Cable)
Video 1 (Must Use RCA cables, or RCA jacks; Red and White for Audio, Yellow for Video)
Video 2 (Must Use RCA cables, or RCA jacks; Red and White for Audio, Yellow for Video)
Sample of Component Cables:
http://www.tigerdirect.com/include/AddCartfromGallery.asp?EdpNo=245214&csid=ITD&Sku=C184-27083&imgcart=1
Oct 07, 2010 | Nintendo Wii Console
I hook everything up to the tv for the nintendo 64, but I still have no picture on the tv or audio. Help!
make sure your cords are in properly. You may have to get a new set of cords from ebay or your local electronics store. Also NOTE: Most TV's have AV1, AV2, Component, then Cable. AV1 and AV2 are both ports(usually on the sides and back), thatyou plug the audio and video into. Make sure both of these have no video or audio before you go out to purchase new cords.
Hope this helps!
Aug 09, 2010 | Nintendo 64 Console
I have picture but no sound LG flatron TV and Pioneer DVD player.
connect audio output (RCA Jack white n red color) from the video, to the audio input of your TV. Make sure you use same AV channel for the video and audio.
i.e AV1 or AV2 or AV3
Apr 10, 2010 | LG Flatron MW-30LZ10 30" LCD Monitor
AV1 AV2 hook up
you should find them by seeing if you can find ports that are colored yellow, red and white
Apr 01, 2010 | LG 42LC2D 42 in. LCD HDTV
My component cable is not showing any video.
it is a a/v hook up not a component hook up
try that like av1 av2 av3
should work a lot better
ron
Aug 29, 2009 | Sony KDE-42XS955 42 in. Plasma HDTV
DVD is hook up and no picture on the TV.
You have to make sure that the RCA cables are properly connected to the TV. Check the TV/Mode if it's set to AV1 (Audio/Video1) or AV2. You may check the TV remote to set it to AV1 or AV2.
From the DVD, the cable should be connected to OUT. And on the TV...video and audio should be connected to IN.
Apr 05, 2009 | JVC XV-S300 DVD Player
XL1s and 4 channel audio
Hi!
Unfortunately, Premiere Pro CS3 can only handle two channels of audio at a time when capturing. You could try capturing with Scenalyzer or another program that can handle four channels simultaneously.
Hope this helps!
Nov 06, 2008 | Canon XL1S Mini DV Digital Camcorder
Hooking up dvd
Brad, AV-1 INPUT, be advised this will use up the AV1 port so if you have another item that uses regular AV cables you`ll then have to use AV2 for the video in and L&R audio in, enjoy, BMW Rider
Jan 07, 2008 | Philips Magnavox 27MT5405 TV
Wii gone black and white, no colour
I bought a wii a few days ago and like everybody else mine too was in black and white with a grainy picture. I have a Panasonic lcd flat screen and thought I had connected it corrected, I got somebody out to have a look at it and found out there are some connections on the side of the TV which I hadn't even noticed before, once I put the red white and yellow leads in these and set the TV to AV3 everything is in perfect colour. Hope this works for some of you.
Dec 11, 2007 | Nintendo Wii Console
Yamaha RXV371 Logo
88 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
