Question about Brother XR7700
Fabric will not feed
Fabric jammed, wheel was hard to turn, after I cleaned it the fabric would not feed.
MakikiChris
  • 84 Answers
SOURCE: My fabric won't advance.
Hi Jodyk...Remove your flatbed so you can access your bobbin area. Open the cover of the bobbin area. The shiny/bright components consist of the Bobbin, which snaps into the Shuttle Hook, which is contained in the Race. Immediately right of the Race is a pewter/matte silver colored lever. Press the lower portion of the lever to raise the Feed Dogs. Pressing the upper portion drops the Feed Dogs, and is commonly used to accomplish free-hand applique work......good luck my friend.
Posted on Aug 02, 2007
SOURCE: the dog feeds will not
The first thing I would check is the button/switch on the back that raises and lowers the feed dogs. This has happened to me and I still don't know how they got lowered. If they are in the proper position then remove the cover plate and check for dust thread or other foreign objects... Hope this helps!
Posted on Oct 12, 2008
bargainbox
  • 1388 Answers
SOURCE: feed dog wont feed the fabric
Remove the needleplate and clean between the teeth of the feeddogs.
Ensure the feeddogs are not lowered for free motion sewing.
Don't know the make/model to be any more specific, so post back here or to the Contact Us page at  www.bargainbox.com.au if there is more to do.
Posted on Nov 24, 2008
  • 3 Answers
SOURCE: Brother XL-6562 sewing machine is not feeding fabric through properly
Oil might help but it sounds like you don't have enough pressure on the foot. You can take the casing off where the light is and there is a screw back there that controls the tension on the pressure foot. It is not meant to be changed by anyone but a professional. I've changed the tension but it wasn't easy. If you are still interested let me know and I will try to explain.
Posted on May 21, 2009
  • 52 Answers
SOURCE: fabric won't feed forward
Do the feed dogs move up and down? If they dont the plastic gear underenth has probably broken you can take this to a singer dealer and have them replace the plastic gear with a nylon one which would last longer than that did
Posted on Jul 16, 2009
I have been sewing all morning. Suddenly the fabric does not feed everything is clean
Look at the feed dogs to see if they are rising above the needle plate at least 1 mm. If not rising lint may have felted between the feed dogs and the needle plate. It could also be the feed dogs have been lowered, or the height has slipped. If the feed dogs are above the needle plate turn the hand wheel and see if they are moving from the front of the machine to the back. If not it is a length adjustment. If this is normal the pressure on the fabric may be too low. Another problem may be the timing of the feed dogs. The feed dogs should rise above the needle plate when the needle leaves the fabric and descend when the needle comes down into the fabric. This requires an expert to fix.
Mar 15, 2014 | Euro-Pro Shark 60 - 384
I have a Singer Stylist 533 and the feed dog isn't working properly. It is not jammed because if I turn the handle to use the machine manually I can see it moving below the presser foot. However, once I...
This could be a couple things. First it could be your presser foot pressure is not high enough or the presser bar is sticking and not pushing on the fabric properly. Second it could be broken feed gears. To check this remove the needle and foot and place a finger on the feed dogs. Then turn the hand wheel and feel if the feed dogs are still moving with the pressure of you holding them down. If the stop moving the you most likely have a broken gear or two. The first problem could be resolved by adjusting the setting of the needle bar pressure or oiling the bar if sticking. The second one needs a sewing machine repair person,
Sep 13, 2013 | Sewing Machines
Fabric not feeding
Check for jams on the bottom feed, if you do have a jam that could be why it's going slow. Or you may be using to thick of fabric.
Sep 20, 2012 | Sewing Machines
My machine is jammed, the wheel wont turn anymore - how do i get in there to clean it out?
if the needle broke into where the bobbin area is
you may have to try pulling the fabric out of the bobbin area or cutting the fabric loose
the machine needs to be serviced because the jam may have put it out of time
Jan 18, 2012 | Brother PE770 Computerized Sewing Machine
How do i fix my sewing machine when its not feeding properly
If it is a singer you can go to this site and enter your model no and view the user manul in a free pdf.
http://www.singerco.com/accessories/manuals.html
Jan 16, 2010 | Sewing Machines
Jamming brand new machine
the tension on the bobbin case needs to be adjusted to needle size and type of fabric the medium fabrics usually use a size 11, light fabrics need a size 9 and heavy like ( corduroy denim or upholstery fabric needs a 14 or 16 Heavy fabrics need a little less tension on the top side so it will feed properly just play with it until it looks good on a scrap of the same fabric
Dec 13, 2009 | Singer 1507
Feed Dogs won't feed fabric.
I can not find the screw. does anyone have a picture of where the screw is?
Nov 05, 2007 | Sewing Machines
Fabric not feeding and jamming occurs
When this happens it is because the thread tension was not right so it gets stuck under the bobbin case and the feed dogs. Use a bigger lint brush and take out the bobbin casing and clean out the shuttle. When you rethread pull slightly on the thread before you feed it through the needle. This will make sure the thread is properly in the tension discs.
Jun 13, 2006 | Kenmore 19233 Computerized Sewing Machine
Brother XR7700 Logo
21 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
